Bilstein 5100 B110 / Allpro Expo
Discussion in 'Suspension' started by Yotski, Jun 6, 2014.
  1. Jun 6, 2014 at 12:25 PM
    Yotski
    Yotski [OP] Well-Known Member
    Alex
    Hilo, Hawaii
    13 SSM Access Cab V6 6 Speed 4x4 TRD Off-Road
    Wet Okoles, Toytec BOSS 3in Kit, Allpro Standard Leaf pack, Ext Bilstein 5100, OEM Skid Plate(destroyed), Thule Racks, Method NV, KM2s, Rigid Grille & Light Bar
    Will the Bilstein 5100 B110 work with the AP Expo pack? What bumps will I need? Thanks
  2. Jun 7, 2014 at 4:41 PM
    bueller
    bueller Well-Known Member
    AZ
    I'm also interested in this. I'm considering the same leaf pack and wondering about rear shocks that will get the most out of the pack as possible.
  3. Jun 7, 2014 at 6:55 PM
    Skunkman
    Skunkman Well-Known Member
    Syracuse - Tug Hill
    2007 Tacoma Access Cab ,
    I had the regular 5100's,0-2" on when I went to Expo's,and within a couple weeks one of them blew a seal and started leaking. Even with a load on the truck, I had 3-4 inches over stock and it was too much for the shocks. I went to the pair that is made for that much lift, I believe they are still a 5100,might be wrong on the part number, but they ride great and have held up well for a relatively inexpensive shock.
  4. Jun 7, 2014 at 8:43 PM
    Yotski
    Alex
    Hilo, Hawaii
    Yea the 5100 B110 is a shock for 3-4in rear leafs and has 11in travel. Looks like the right one just want more input before I make a decision
  5. Jun 18, 2014 at 11:31 AM
    tmreyes1
    tmreyes1 Well-Known Member
    T-Rey
    TX
    2017 TRD
    Have my expo pack and thinking about these too. Price is good too
  6. Mar 24, 2021 at 9:59 AM
    BSC_808
    BSC_808 Active Member
    Brennen
    ‘07 Tacoma V6 4x4
    Bilstein leveling kit
    Does anyone have photos? I’m wanting to install the Allpro expo pack and can’t afford to do anything in the front at the moment. Will this look funny??
    I have 5100 set to the 4th clip (I believe) I can only see one ring from under the truck. does anyone have a center of wheel measurement to check what clip it’s on?
    I’m just sick of flattening my stock leafs every time I have a small load in the truck. Thanks!
  7. Mar 25, 2021 at 2:08 PM
    BSC_808
    Brennen
    ‘07 Tacoma V6 4x4
    Do you still have this setup? And if so what do you have on the front/how much lift?
    I’m wanting the expo pack but only have 1.75” lift on the front. Wondering how weird this will look until I can lift the front also.
    Thanks
