Bilstein 5100 driveline vibrations ???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hot2na, Mar 16, 2013.
  1. Mar 16, 2013 at 2:45 AM
    Hot2na
    Hot2na [OP] Well-Known Member
    In the "suspension" forums there was a guy complaining that he experienced drive line vibrations with the 5100's set at only .85..
    he said he had to replace a bearing on the front diff inorder to solve the problem..
    only one inch of lift can cause this?
    Anyone else get this ?? most posts I have read say -everything is fine after the install
    getting ready to pull the trigger on a set of 4....this has me thinking..any help appreciated
  2. Mar 16, 2013 at 4:18 AM
    scottw1
    scottw1 Well-Known Member
    Scott
    Norfolk, VA
    2010 SR5 Tacoma 4x4
    Lighted 4wd dial, Sirus XM radio
    Did he say how many miles were on his truck, what the truck was used for (mainly highway or mainly off road)? From what I have read, the .85 setting should be okay but anytime you change the factory geometry of the suspension, you will have some degree of additional wear and tear.
  3. Mar 16, 2013 at 11:46 AM
    Hot2na
    bump...any others??
  4. Mar 16, 2013 at 12:04 PM
    scottw1
    Scott
    Norfolk, VA
    2010 SR5 Tacoma 4x4
    Looks like some have had luck replacing the bearning in the boot. Seems to be a common solution.
  5. Mar 16, 2013 at 1:26 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    im going through the same thing, and now have a torn c/v boot. i didn/t lift much, maybe 2 inches but it is a noticeable vibe
    eascoastgearsupply has the only fix that i am aware of
  6. Mar 16, 2013 at 3:51 PM
    scottw1
    Scott
    Norfolk, VA
    2010 SR5 Tacoma 4x4
  7. Mar 16, 2013 at 4:34 PM
    P9HST2
    P9HST2 Well-Known Member
    Iowa
    2012 MGM AC TRD OR
    WeatherTech floor liners, tailgate hoseclamp, Famous Fab sliders, Brute Force Fab rear bumper, Icon "3T" suspension.
    The small lift didn't cause the front diff bearing problem, it just revealed it.
  8. Mar 16, 2013 at 4:54 PM
    OldGeezer42
    OldGeezer42 Well-Known Member
    Adam
    Louisiana
    07 DCLB Silver Base
    Husky mats,30% tint all around, DTRL,OEM Bed mat,UWS Tool box,OEM fog lights,5100's,Wheelers 3leaf HD springs.OEM cruise control,OEM wipers,,Avid light bar,Flyzeye Leds,4x4 illuminated switch.Matt123 skids,bed lights,Ome 884s
    I just installed Bilsteins in front set@ 1.75 and rears with 1.5 aal in rear, I have no vibs, there are tons of set ups like these and you seldom hear of any thing serious , but changing cv angles will amplify a worn bearing,etc, that was there to began with. I researched for months before I did mine , Very happy with it ,
  9. May 18, 2013 at 11:00 AM
    Monster1
    Monster1 Well-Known Member
    San Antonio, Texas
    2012 Texas Edition DC Tacoma 4WD
    Weathertech digitals front and rear, TRD exhaust, Coverking dash mat, Oem Tacoma bedmat, Better Built tool box, bed extender, Toytec 1 1/2" AAL, Bilsteins front and rears, fronts set at .85, K&N filter, aluminum skid plate, EGR vent shades, locking tailgate handle, TRD emblems, Cal Trend seat covers front and back.
    What he said ^^^^
