Bilstein 5100/Eibach Coilover Question
Discussion in 'Suspension' started by Sapper Six, Sep 4, 2011.
  1. Sep 4, 2011 at 7:54 AM
    Sapper Six
    Sapper Six [OP] Active Member
    VA
    '11 TRD Off-Road TX
    Debadged; Weathertech Floor Liners; Misc. Paint Modifications
    As of right now, my truck sits at factory rake, etc with the exception of a TSB. I measured the ground-to-fender distance at the centerline of each wheel and my front measurements came out at 34" while the rear was at 37.25"
    My question is this: If I want to lift the front and level it, will I be able to sit level by installing the Toytech/Bilstein coilovers in the front, with the 5100s set at .85 and Eibachs, giving the standard lift of just under 3" (I have a DC so I won't get the full 3")? I also would install standard 5100s in the rear for improved ride, I just would skip an AAL because I prefer the look of leveled as opposed to lifted with the standard rake.
    I know this likely is a stupid question but I'm just relying on the somewhat limited knowledge I have of suspensions and the common sense calculation that if I have 3.25" of rake now and raise the front by ~3", I'll more or less level it out. I want to see if the experts here have any advice as to whether I missed something and would get a "bro-lean" if I did this.
    I really appreciate any responses, always great advice here on TW.
  2. Sep 4, 2011 at 12:53 PM
    wolfdog2314
    wolfdog2314 Well-Known Member
    2011 Tacoma 4x4 Sport
    Eibach coils. 5100's all around. AAL. WickedFlow
    So u do or don't have the rear tsb?
    I sit with slight rake with eibach/5100 @.85 and a 2inch AAL.
    If u don't have anything in the back, or just the tsb... I'd just get the eibach springs which lift 1.6 inches themselves.
  3. Sep 4, 2011 at 12:57 PM
    Sapper Six
    VA
    '11 TRD Off-Road TX
    Sorry, I wasn't clear about the TSB. I meant that with the exception of the TSB which I had done, I sit at factory rake.
    Thanks for your advice, what do others think about that idea? I hadn't thought of that because typically I had been seeing shocks as the primary or first upgrade.
  4. Sep 4, 2011 at 7:22 PM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    I have the 5100s at .85 with Eibachs and tsb springs in the rear. My hub to fender measurements are exactly the same at 23" all the way around but I'm looking for 1/2-1" of rear lift so I have a little rake.
    Best of luck with your decision!
  5. Oct 7, 2011 at 1:01 PM
    ser240z
    ser240z Well-Known Member
    Scott
    Monterey Park, CA
    '23 TRD Pro 6spd
    I'm setup stock with the TSB leaf pack, and I like the stance right now, but was thinking about adding a small lift. Was going to run 5100's, Eibachs, and the 1.5" TSB AAL from Toytech, but I'm concerned about the stance of the truck after.
    Anybody got pictures of this setup? What setting should the 5100's be to keep my rake? Or assuming that I have the same measurements as the OP, I can run just 5100's and Eibachs at 0 to get the 1.6 from the spring and my rear will still be slightly higher? So if I ran Eibachs and 5100s at 0 with the 1.5, I should just be lifting the front 1.6 and rear 1.5, so I'd be about what I am now, just a little higher?
    Thanks
    Scott
    Sorry if I'm thread jacking, just thought it would fit with this.
  6. Oct 7, 2011 at 1:46 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You won't get 3" of lift out of Eibachs and 5100's set at .85. You'll be just under 2.5" (1.6" of lift from Eibachs and .85 from the 5100's).
  7. Oct 7, 2011 at 2:06 PM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    Here is a crappy pic of my setup. 5100's @ .85" with Eibach's, Toytec 1/2" spacer (driver side) and 1/4" spacer (passenger side). Toytec 1.5" AAL with 5100's. No TSB leaf pack.
    edit: Also have Light Racing UCA's installed.
    My measurements from hub to fender are 23" front and 23 1/2" rear
  8. Oct 7, 2011 at 2:35 PM
    NC15TRD
    Nick
    PA
    Ajohnson what size tires are you running? Did you change your upper control arms?
  9. Oct 7, 2011 at 2:42 PM
    ajohnson
    Andy
    Charlotte, NC
    Yea I forgot to mention I have Light Racing UCA's.
    265/75/16 Duratracs. I will probably step up to 285's when these are done but that will be a while.
  10. Oct 7, 2011 at 2:47 PM
    NC15TRD
    Nick
    PA
    Thanks I'm planning on adding the bigger spacer to the driver's side and moving the smaller one to the passenger side when I can afford the light racing arms. New skins are a bit more of a necessity first though
  11. Oct 7, 2011 at 3:03 PM
    Fletcher007
    Fletcher007 Well-Known Member
    Fletch
    Phoenix,AZ
    17 Access cab 4x4 4cyl 5spd Magnetic Grey
    Fox 2.0 coilers, Fox 2.0 rear shocks, 17" 4Runner Trail Edition 7 spoke rims, 255/75 17 Yokohama All Terrains. Secondary air filter removed and AFE pro Dry S installed. Lower Air valance removed. Secondary smog pump mod done. Cali Raised ditch lights and amber fog lights installed with On off switches installed in 2 of 3 factory blank slots!
    i have ome 885 with 5100's set to stock and the rear tsb done. i am exactly 1 inch high in the rear...it bugs me!!
