Bilstein 5100 / Eibach Gallery
Discussion in '1st Gen. Tacomas (1995-2004)' started by tcBob, Sep 6, 2011.
  1. Nov 5, 2013 at 3:07 PM
    #2001
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Wut?? :der:
    No...Sway bars have nothing to do with moving the LCAs..they stop them from moving..
  2. Nov 5, 2013 at 3:13 PM
    #2002
    Tacoma1995
    Tacoma1995 Well-Known Member
    Lucas
    NC
    Tiffany The Tacoma
    The pressure from the sway bar has cause my bushings in my strut to wear out...
    or so I thought
    am I crazy or something??
  3. Nov 5, 2013 at 3:16 PM
    #2003
    Blackdawg
    Monte
    Wyoming/St. Louis
    yes..your crazy hahahaha
    nah..but the sway bar doesn't make the bushings in the shocks go bad. They just wear out from the suspension cycling. Only thing to do is..get new shocks.
  4. Nov 5, 2013 at 3:25 PM
    #2004
    Tacoma1995
    Lucas
    NC
    Tiffany The Tacoma
    I ordered toytec coils and 5100 today and for some reason I thought I was gonna have to have something to make my sway bar sit further down to compensate for the lift..
    thanks for the info
  5. Nov 5, 2013 at 3:30 PM
    #2005
    Blackdawg
    Monte
    Wyoming/St. Louis
    oh...no not at all.
    In fact i would recommend just taking off the sway bare AFTER you put on the Eibach coils. Will ride much better.
  6. Nov 5, 2013 at 4:18 PM
    #2006
    Tacoma1995
    Lucas
    NC
    Tiffany The Tacoma
    would you recommend a diff drop?
  7. Nov 5, 2013 at 4:38 PM
    #2007
    Blackdawg
    Monte
    Wyoming/St. Louis
    They can't hurt and are cheap. id do it
  8. Nov 20, 2013 at 2:04 PM
    #2008
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    Is anyone having issues with blow CV boots? I just replaced mine not to long ago and another one just blew today. And I have a diff drop
  9. Nov 20, 2013 at 2:07 PM
    #2009
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    My driver side inner boot has been leaking for over 7 months now, but nothing has completely blown. My inner seals are also gone, but that doesn't surprise me considering they're the oem cv's with over 130,000 miles on them.
  10. Nov 20, 2013 at 2:37 PM
    #2010
    TACOMABOSS
    96 SR5 4x4
    Well by blown I mean torn, grease leaks out
  11. Nov 20, 2013 at 2:41 PM
    #2011
    PcBuilder14
    Brent
    Nor Cal
    Ah, yeah. I wouldn't be too worried about it. Some people have gone over a year with them leaking and it still works fine. When it tears is when issues can arise by allowing dirt to easily get inside.
  12. Nov 20, 2013 at 2:43 PM
    #2012
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea..its a common thing. All about the risk. Our trucks aren't meant to be lifted over 2.5'' otherwise boots explode.
    I blew two.
  13. Nov 20, 2013 at 2:44 PM
    #2013
    TACOMABOSS
    96 SR5 4x4
    Should it really be happening so frequently?
  14. Nov 20, 2013 at 2:44 PM
    #2014
    TACOMABOSS
    96 SR5 4x4
    At least I know nothing is going to rust... lol
  15. Nov 20, 2013 at 2:47 PM
    #2015
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well seeing as you had one blow..and then another different one id say it makes sense?
  16. Nov 20, 2013 at 2:49 PM
    #2016
    TACOMABOSS
    96 SR5 4x4
    When the two inners blew I replaced the whole CV axle with new boots, so everything was new. well, "remanufactured"
  17. Nov 20, 2013 at 2:53 PM
    #2017
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    Im just curious as to what makes the boots rip quicker? I know lifts put the CV's at higher angles but is it that the gills are touching and rubbing together that makes them cut open? Or is it something else?
  18. Nov 20, 2013 at 2:57 PM
    #2018
    BrttClne22
    BrttClne22 Well-Known Member
    Britt
    Asheville, NC
    2015 Barcelona Red DCLB 4x4 V6
    I believe it's when the friction rubs a hole in the flaps. The higher the angle the more they touch and thus more friction. I could be wrong, but I think I read that somewhere
  19. Nov 20, 2013 at 3:00 PM
    #2019
    PcBuilder14
    Brent
    Nor Cal
    That's exactly it. But mine aren't ripped at all. The driver side inner boot slid back allowing grease to leak out of the end of the boot.
  20. Nov 20, 2013 at 3:01 PM
    #2020
    TACOMABOSS
    96 SR5 4x4
    The first time my inner boots ripped, they tore completely off of the collar that holds it on the axle, so the smaller part of the boot. If that makes sense
