Bilstein 5100 / Eibach Gallery
Discussion in '1st Gen. Tacomas (1995-2004)' started by tcBob, Sep 6, 2011.
  1. Nov 21, 2013 at 10:12 PM
    #2041
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    This ^^^ Seems like zip ties are harder plastic, with edges that will cause just as much, if not more damage.
    Some people have had mixed results from this. Usually, the clamp ends up cutting the boot because you have to tighen it down so miuch so it will hold the boot in place. Also, a standard hose clamp doesn't fit correctly in the groove.
    The original boot-slide mod involved welding a stop ring to the shaft so it keeps the small end of the boot from sliding back. The stop ring goes inside the boot. Of course, this method is a lot more complicated but it does mean that all the clamp has to do is keep grease from seeping out.
  2. Nov 21, 2013 at 10:19 PM
    #2042
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
  3. Nov 21, 2013 at 10:25 PM
    #2043
    yote
    yote Washington State University
    Mark
    Tacoma, WA
    2002 Ext Cab TRD Off-Road
    I've seen those installed on a few rigs here @ TW. I'd need to do a whole lot of reading before dropping $500 on CVs
    ...but that'd solve the main worry when it comes to lifting
  4. Nov 21, 2013 at 10:26 PM
    #2044
    PcBuilder14
    Brent
    Nor Cal
    Haha trust me, you won't break one. The only time I've heard of a boot tearing is from stuff like limbs stabbing them. Never from high angles.
  5. Nov 21, 2013 at 10:41 PM
    #2045
    yote
    Mark
    Tacoma, WA
    Sound investment then. Never have to worry about CVs again? Deal.
  6. Nov 21, 2013 at 10:44 PM
    #2046
    PcBuilder14
    Brent
    Nor Cal
    Yeah, I think the main reason people don't get them is because of the sticker shock and the fact that you can go through as many autozone cv's if you want and only pay for a set. But for me personally, I don't want to have to change my cv's every year or so haha
  7. Nov 21, 2013 at 10:54 PM
    #2047
    604YOTA
    604YOTA Well-Known Member
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    Grey wire mod, eibach, 5100's & 5125's, ome Dakar leafs, 1.25 rear shackle, Gibson exhaust, ram air intake, throttle body spacer, boot slide mod, poly bushing kit, extended brake lines.
    That is true what I had to do was use 2 clamps and attach them together to make one clamp with 2 screw down points they are slimmer than just having one and clamp in 2 different spots. Has worked so far they were new cvs andyat full droop i would pull the stock clamps off this was my best bet so far so good will seenin a couple 1000 miles.
  8. Nov 21, 2013 at 10:55 PM
    #2048
    yote
    Mark
    Tacoma, WA
    Yeah well I've already bookmarked that page. I'll keep it in mind for if my CV boot blows
  9. Nov 30, 2013 at 11:02 AM
    #2049
    tc98tacoma
    tc98tacoma Well-Known Member
    Nik
    San Antonio, Texas
    98tacoma4x4
    3inch toytec coils 5100's, aal(soon to be replaced), 33/12.5 km2s, + a money hole...
    It looks super tall with skinny tires but it looks awesome !
  10. Nov 30, 2013 at 11:04 AM
    #2050
    tacomaes843
    tacomaes843 Well-Known Member
    03 Prerunner SR5
    3.5' lift in the front w/ Bilstein 5100 Shocks & Eibach Coils, 1.5' in the back with blocks & billies. Tinted windows. Tinted Tail-lights. Blacked out corner lights. Uws tool box. Whip Antenna. 2nd gen 16' wheels. Flowmaster 40 dual exhaust. 1.25' Wheel spacers all around.
    Thanks man I appreciate it! I'm loving the skinny's.
  11. Dec 2, 2013 at 3:27 PM
    #2051
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    Finally a part of the club
  12. Dec 2, 2013 at 4:23 PM
    #2052
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    Are they 500 each or for a pair?
  13. Dec 2, 2013 at 4:24 PM
    #2053
    PcBuilder14
    Brent
    Nor Cal
    $500 each.
  14. Dec 2, 2013 at 4:27 PM
    #2054
    TACOMABOSS
    96 SR5 4x4
    Wow
  15. Dec 2, 2013 at 4:30 PM
    #2055
    PcBuilder14
    Brent
    Nor Cal
    I've been told if you call them they will work with you a little bit. Still worth it to me to not have to replace axles pretty much ever again.
  16. Dec 2, 2013 at 4:49 PM
    #2056
    TACOMABOSS
    96 SR5 4x4
    Yeah, that's just hard to justify 1000 bucks on a set of cv axles
  17. Dec 2, 2013 at 4:51 PM
    #2057
    PcBuilder14
    Brent
    Nor Cal
    To each his own I guess.
  18. Dec 2, 2013 at 5:08 PM
    #2058
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    Ive seen RCVs in action and if I were staying IFS id drop the coin in a heartbeat,, and they have lifetime warranty so even if you do break one throw in a cheap autozone till a new one comes but I believe its pretty damn hard to break them!
    They too are 1k/pair
  19. Dec 2, 2013 at 5:11 PM
    #2059
    PcBuilder14
    Brent
    Nor Cal
    A friend of mine bought them, and when he was talking to the company I think 2 had been broken in South America and 1 broke somewhere in Europe. Very awesome company to deal from what I've heard.
  20. Dec 2, 2013 at 5:19 PM
    #2060
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    What happens after a year when the warranty is up? and there's no warranty on the boots I thought that was the real issue?
