Bilstein 5100 / Eibach Gallery
Discussion in '1st Gen. Tacomas (1995-2004)' started by tcBob, Sep 6, 2011.
  1. Dec 21, 2013 at 11:37 AM
    #2081
    Deo volente
    Deo volente Active Member
    Low Country
    97' SR5
    Thanks for the info. I have looked around for a UCA install on a 1gen but only found 2gen. Is there any differences?
  2. Dec 21, 2013 at 8:43 PM
    #2082
    Deo volente
    Low Country
    97' SR5
    Found what I needed. Now if I could only get the ball joints out of the knuckle.
  3. Dec 21, 2013 at 8:49 PM
    #2083
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    I haven't researched much about upper ball joints but I think they have to be pressed in. If they are pressed in then I think they can be pressed out. I've used the autozone kit to press ball joints in and out on my dad's ford ranger. It's a simple process once you figure out how to work the pieces on the ball joint press.
  4. Dec 22, 2013 at 4:43 PM
    #2084
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    the process is pretty much identical but the parts are not interchangeable.
  5. Dec 28, 2013 at 7:43 PM
    #2085
    cr500taco
    cr500taco Well-Known Member
    D
    Northridge
    4WD
    Just purchased 5100 Bilsteins to install on my 97 4WD Tacoma. Was looking into the 3" Eibach lift springs for them. Was told by a couple of vendors on here that they do not recommend running the Eibach lift springs with the 5100s and neither does Bilstein. For the reason that the struts are valved for the OEM COs and that the heavier Eibach springs will wear out the struts faster. I was also told that aftermarket UCAs are needed, because the stock BJs can't handle the angle of the lift.
    Do you guys recommend aftermarket UCA's and what are your experiences with the setup and any issues of the Eibach springs and 5100s?
  6. Dec 28, 2013 at 8:03 PM
    #2086
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    These are all valid concerns but people are doing it anyway. I would add that you will likely end up with more than 3" of lift which will result in fairly steep axle angles. that is why many who have done this combo have also had cv boot issues.
    Not trying to be a debbie downer here just stating what I have observed.
  7. Dec 28, 2013 at 8:05 PM
    #2087
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    You'll want to add a bumper winch and or skids to run them safely. I've had no real issues since I have.
  8. Dec 28, 2013 at 8:15 PM
    #2088
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    You talking about ball joints? What does it do to them
  9. Dec 28, 2013 at 8:34 PM
    #2089
    Digiratus
    Roaming the PNW
    The RedHead
    Not sure what cr500taco was told but in general, as you add lift on an IFS suspension, a couple of things happen. One is, you loose caster adjustability. But that is true regardless of the type of lift. The more lift, the less caster.
    I suspect that whoever the vendors were that said it, were referring to the limited range of movement of the stock upper balljoint. A uniball UCA is the ideal solution but IMO not required.
    An aftermarket uniball UCA will get the caster back into the normal range tho and increase that range of movement of the balljoint.
  10. Dec 28, 2013 at 8:54 PM
    #2090
    LSC15
    Logan
    2008 TRD D-Cab
    Appreciate it man. Wandering if I need to check anything for wear after I have had eibach/5100s on for a month or so now
  11. Dec 28, 2013 at 11:14 PM
    #2091
    Blackdawg
    Monte
    Wyoming/St. Louis
    Us 95-97 tho tend to take the 3+" much better. I still had alignments in spec with stock UCAs.
  12. Dec 28, 2013 at 11:16 PM
    #2092
    LSC15
    Logan
    2008 TRD D-Cab
    I'm gonna check my ball joints though tomorrow. Kind of worried about them anyway
  13. Dec 28, 2013 at 11:19 PM
    #2093
    Blackdawg
    Monte
    Wyoming/St. Louis
    LBJs are always good to keep any eye on. Uppers tho usually fine unless the boots are ripped.
  14. Dec 28, 2013 at 11:19 PM
    #2094
    LSC15
    Logan
    2008 TRD D-Cab
    Ok man thanks
  15. Dec 29, 2013 at 11:40 AM
    #2095
    cr500taco
    D
    Northridge
    4WD
    All I was told was that the stock BJ can't handle the anything over 2.5" lift very well.
  16. Dec 29, 2013 at 11:44 AM
    #2096
    cr500taco
    D
    Northridge
    4WD
    Thanks for the input. Did they have the CV boot issues with the diff drop?
  17. Dec 29, 2013 at 11:46 AM
    #2097
    cr500taco
    D
    Northridge
    4WD
    Definitely want a different bumper and skids later on, but not sure if I am going to be getting a winch or not.
  18. Dec 29, 2013 at 9:19 PM
    #2098
    2stroketrush
    2stroketrush Well-Known Member
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
    Overland Purpose Built 97 going on 190K.
    Hope this isn't a Dumb Question, but is there any really Danger in this setup? I don't want to put strain on something that will break easily, And cost more money. Would i be alright with this setup?
    My plan is to do this setup with a AAL and Toyotec Axle Shim in the rear of my 97 4cycle, with a Diff Drop kit and Carrier Bearing Spacer. But i do have ARB bumper on the front and Trail Gear bumper on the back so i assume that would help??
    Maybe BlackDawg or someone else who knows there stuff could chime in? Thanks!
  19. Dec 29, 2013 at 9:27 PM
    #2099
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea you always run the risk of blowing a cv boot especially you being a 4 banger. The bumper will help.
    Diff drop won't help cv angles that much mostly just driveline vibes. Still worth getting tho.
  20. Dec 29, 2013 at 9:31 PM
    #2100
    2stroketrush
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
    Thanks man! Any other risks or common issues associated with this setup? it looks to be one of the most popular lifts on here though!
