Bilstein 5100 / Eibach Gallery
Discussion in '1st Gen. Tacomas (1995-2004)' started by tcBob, Sep 6, 2011.
  1. Sep 26, 2011 at 3:48 PM
    #201
    Alpha Q Up
    Alpha Q Up Well-Known Member
    Ruben
    San Jose
    2003 4WD DC Tacoma
    Did you guys have to get extended brake lines?
  2. Sep 26, 2011 at 3:54 PM
    #202
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
  3. Sep 26, 2011 at 7:39 PM
    #203
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    no up front. Out back, yes i did/do. But i have like 4'' of lift
  4. Sep 26, 2011 at 8:26 PM
    #204
    magikbean562
    magikbean562 once flirted with danger, danger got clingy
    greg
    socal
    pinto
    33" mudders
    this is the setup ill most likely go with. my question is, how many of you guys are running a diff drop? is it necessary?
  5. Sep 26, 2011 at 8:27 PM
    #205
    Konaborne
    Cody
    Kealakekua, Hawaii
    I am. Never ran the lift without it, so I can't say for sure what it did (went with the "better safe than sorry!" attitude) but still ended up with 2 blown CV boots :pout:
  6. Sep 26, 2011 at 8:32 PM
    #206
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    I had spacers before without the diff drop and i noticed a difference when i put the coils and diff drop in. For how cheap it as, might as well do it
  7. Oct 5, 2011 at 7:57 AM
    #207
    Tylan
    Tylan Active Member
    Tylan
    Wakefield, MA
    2012 DCLB Nautical Blue - "Bella"
    Weathertech Floor Liners, Access LightRider, 235/85/16 DuraTrac
    I just finished my lift and went with the 5100s @ 1.75 with the stock coils in the front and got the rear leaf TSB in the rear. Pretty simple, but what I forgot about is the weight of the cap in the back... Now with the bed empty I am barely level or even a slight bit nose high. I want a little rake so I am not riding low in the rear when I have weight in the truck.
    What are the best/easiest/cheapest options? Lower the front to .85? Add a block or another leaf to the rear to go back up about 1-1.5"? Suggestions?
  8. Oct 5, 2011 at 8:07 AM
    #208
    Blackdawg
    Monte
    Wyoming/St. Louis
    Blocks are never the answer...EVER. Unless you just want to have to buy new leaf packs in a few months or a year or so.
    And you already have an AAL?
  9. Oct 5, 2011 at 8:17 AM
    #209
    Tylan
    Tylan Active Member
    Tylan
    Wakefield, MA
    Already have the TSB AAL, but not enough to even it out with the 5100s set @ 1.75. I guess the easy road is to lower the fronts to .85, but now that I am up there, I kind of want to stay up there. Just not sure if there is a 1" option for the back, or if the best option is to go with the ...
  10. Oct 5, 2011 at 8:26 AM
    #210
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    you can add a 1 inch block...
    but i wouldnt, raise the front to 2.5 and get the 1.5 aal and you will be set:)
  11. Oct 5, 2011 at 12:07 PM
    #211
    ilove_taco_ma
    ilove_taco_ma Well-Known Member
    fresno, california
    95 tacoma 4wd LX
    nothing, all stock expect got a OE replacement air filter K&N.
    how many of you guys have this combo installed on the 4cycl? can you guys post a pic and say the inches of lifts. i'm deciding to get the eibach's and take out my ome 881s i currently have on now.
  12. Oct 5, 2011 at 12:10 PM
    #212
    Konaborne
    Cody
    Kealakekua, Hawaii
    check the pics of 97yota in the OP, he's an I4 with the eibachs.
  13. Oct 5, 2011 at 1:12 PM
    #213
    Blackdawg
    Monte
    Wyoming/St. Louis
    You get a bit more lift then us v6s. just go through the pics.
    I have no idea what TSB is..but the Wheelers AAL is great or the toyotec one.
  14. Oct 5, 2011 at 1:13 PM
    #214
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    TSB is Technical Service Bulletin. Meaning changes to certain parts should be considered
  15. Oct 5, 2011 at 8:59 PM
    #215
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    If you were a 1st gen, I would suggest adding an extended shackle to the rear. Not sure if they make them for your 2nd gen, but I would think they do. They are typically available as 1", 1.5" and 2" lift sizes.
  16. Oct 5, 2011 at 9:06 PM
    #216
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    this is a sweat thread
  17. Oct 5, 2011 at 9:23 PM
    #217
    Konaborne
    Cody
    Kealakekua, Hawaii
    Updated the rear lifts post.
  18. Oct 5, 2011 at 10:57 PM
    #218
    Blackdawg
    Monte
    Wyoming/St. Louis
    The what?? lol
    and dude id get a wheelers AAL. And then maybe shackles.
  19. Oct 5, 2011 at 10:59 PM
    #219
    Konaborne
    Cody
    Kealakekua, Hawaii
  20. Oct 5, 2011 at 11:13 PM
    #220
    Blackdawg
    Monte
    Wyoming/St. Louis
    ahh okay lol
