Bilstein 5100 / Eibach Gallery
Discussion in '1st Gen. Tacomas (1995-2004)' started by tcBob, Sep 6, 2011.
  1. Nov 22, 2015 at 3:07 PM
    #2621
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    NOOOO
    Do NOT stack lifts. You want to get rid of those damn spacers anyways
  2. Nov 22, 2015 at 3:08 PM
    #2622
    Blackdawg
    Monte
    Wyoming/St. Louis
    No he won't. It'll be like 3.5'' of lift and destroy his ball joints and CVs.
    if he is dying for 3'', get 882s.
  3. Nov 22, 2015 at 3:10 PM
    #2623
    Jwood2020
    Jwood2020 Well-Known Member
    Justin
    Alabama
    01 1st gen dblcab
    2' spacer lift 285/70/17 nitto trail grapplers m/t
    I'm not really doing for it just want all the clearance.I'm looking at toytec and I'm not seeing an option for 882s just 880,881, and 883s
  4. Nov 22, 2015 at 3:17 PM
    #2624
    Blackdawg
    Monte
    Wyoming/St. Louis
    Okay, well let me explain this too you.
    Lifting does not make you clear tires better.
    The cycle of the suspension stays the exact same, so your going to rub with bigger tires no matter what. Staying lower in the travel of the truck is better so you try and split the travel of the truck. So you have almost as much down travel as up travel.
    As for more clearance for the skid, okay you'll gain a bit. But you gain 0'' from the rear diff. That is all tire clearance. So its kinda pointless.
    Really 2-2.5'' of lift is ideal on our trucks. The ball joints are happy with it, the CVs are too, and you have plenty of down travel still and lots of up travel.
    The short version is, don't over lift your rig. you gain nothing from it. And since you have NO extra weight up front and are a 4 banger, you don't need a 620lb coil like the eibachs. That is WAY to much coil for you. the 882 is a 500 rate coil and will give you your magic 3'' most likely since you re light weight. And still ride nice. Add some weight and they will hold it fine.
  5. Nov 22, 2015 at 3:37 PM
    #2625
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    he's right
    i was at 3.5" for awhile
    tore CV boots every couple months, had no downtravel, and ride was pretty damn rough
    lifts don't change the size of the wheelwell or any of the turning mechanics/overall suspension geometry
  6. Nov 22, 2015 at 3:43 PM
    #2626
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    I have a DCSB V6 4x4 with adjustable 5100's in the front on the 0 setting and 3" Eibach coils and it rides just fine. But I do have an aftermarket Trailgear low pro rock defense bumper and Camburg UCA's. But I never got the UCA's cause it rode like crap. I got them so I could be within alignment specs.
  7. Nov 22, 2015 at 3:48 PM
    #2627
    Sicyota04
    Morgan
    California
    04 DC 4x4
  8. Nov 22, 2015 at 3:50 PM
    #2628
    Jwood2020
    Justin
    Alabama
    01 1st gen dblcab
    I'm not searching for the magic 3'. In general I was more or less asking about different coil and strut option to be close to the amount of lift. I know how suspension works.
    After this discussion and going through the toytec option it seems like if I go with 880s and 5100s @ 1.25. After they settle alittle I should hopefully be around 2.5 total
  9. Nov 22, 2015 at 4:00 PM
    #2629
    Blackdawg
    Monte
    Wyoming/St. Louis
    Id just go with 881s if that's what you want. Will ride better.
  10. Nov 22, 2015 at 4:01 PM
    #2630
    Blackdawg
    Monte
    Wyoming/St. Louis
    Your also a v6 with armor.
    Different story.
    Also I can see your cv boots wearing in the ohoto you posted. Won't be much longer till they blow. You can feel the lip being rubbing into them I bet.
  11. Nov 22, 2015 at 4:04 PM
    #2631
    Jwood2020
    Justin
    Alabama
    01 1st gen dblcab
    881 on stock 5100 setting . sounds like a plan.
    I've owned a few lifted wranglers before. This is my first taco, just been needing these different opinions for these springs on the 5100s
    Blackdawg[QUOTED] likes this.
  12. Nov 22, 2015 at 4:08 PM
    #2632
    Sicyota04
    Morgan
    California
    04 DC 4x4
    That picture was taken hen I had them on the 2nd setting until I realized it's not worth preloading the coil for a little more lift. After that I put them back down to the 0 setting. Are you an off road mechanic or Toyota mechanic? Or do you just know everything?
    devinzz1 and Jwood2020 like this.
  13. Nov 22, 2015 at 7:06 PM
    #2633
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Ive seen u post that pic soo many times ahaha.
  14. Nov 22, 2015 at 7:31 PM
    #2634
    Blackdawg
    Monte
    Wyoming/St. Louis
    Go look at my build sometime and you'll see why I..know.
    And actually I bet your cv boots still are wearing just the same. Mine blew after about a year of daily driving.
    Sloth likes this.
  15. Nov 29, 2015 at 1:32 PM
    #2635
    Redyota01
    Redyota01 Member
    Phil
    Jefferson County TN
    sr5 Trd 4x4
    Kenwood Double Din Magnaflow cat Super 10 Flowmaster
    My 2001 v6 taco with billy bobs
    devinzz1 and Sicyota04 like this.
  16. Nov 30, 2015 at 10:27 AM
    #2636
    Frostbyte
    Frostbyte Well-Known Member
    Northern Utah
    18 Super White TRD OR Manual
    SOLD - 03 Black SR5 4x4 TRD OR RIP - 07 Radiant Red SR5 4x4 TRD Sport Fabtech 6" lift, 33x12.50.18 Toyo M/T on All black XD Hoss wheels
    whats your set up, tire size and all? i like it
  17. Nov 30, 2015 at 10:52 PM
    #2637
    Redyota01
    Redyota01 Member
    Phil
    Jefferson County TN
    sr5 Trd 4x4
    3 inch Bilstein/eibach with a AAL. 18x10 moto metal 962 with 265/65/18 nitto G2s. No rubbing at all
  18. Dec 1, 2015 at 6:15 AM
    #2638
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    You need some weight on there, your cv's are not going to be happy and I'd be willing to bet it rides like you have bricks for suspension.
  19. Dec 1, 2015 at 6:29 AM
    #2639
    devinzz1
    devin
    2023 aclb trd or mt
    I have same conf. V6 4x4 ext cab. Rides pretty good. Better than stockers preloaded to 2.5.
  20. Dec 1, 2015 at 7:31 AM
    #2640
    Redyota01
    Redyota01 Member
    Phil
    Jefferson County TN
    sr5 Trd 4x4
    Yeah I'm thinking about a plate bumper and some rock sliders soon. I never did install the diff drop because I've read so much about it not doing crap lol. The ride is a little firm but not to bad!
