Bilstein 5100 / Eibach Gallery
Discussion in '1st Gen. Tacomas (1995-2004)' started by tcBob, Sep 6, 2011.
  1. Aug 10, 2012 at 1:44 PM
    #901
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    I told you you couldnt stay away, honey.
  2. Aug 10, 2012 at 2:17 PM
    #902
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Same with 5150s too. All have the same valving.
    5125s come in much more sizes then 5100s or 5150s
    5150s have external resi for better cooling
  3. Aug 10, 2012 at 2:19 PM
    #903
    J88logue
    J88logue NorthWest Member
    Johnny
    HWY 30
    02 D.C. TRD
    Clicko BUILDo
    ^^^ 100% Accurate! ;)
  4. Aug 10, 2012 at 4:07 PM
    #904
    brannman
    brannman Well-Known Member
    Chesapeake, VA
    01 TRD
    another question for ya'll. i have been doing my research and read these 50 pages a couple of times but I think I am ready to order some Eibachs. I already have 5100s and a spacer for another inch or so of lift. So gonna do away with the spacer and stock TRD coils and replace them with Eibachs.
    For the rear I am working with stock frowning leafs and a 1 inch block I will be doing away with and replacing with a new leaf pack...thats the question, which leaf pack?
    I have had the 5100s and blocks for about 50,000 miles so there may be some sagging. I was looking at getting the OME leaf pack from toytec's website so I can save on shipping for that and the coils, but then i was wondering if deaver or alcan might be better?
    I won't do that much offroading so don't need a ton of flex, just a better ride so when i hit bumps the truck doesn't dance around.
    Opinions?
  5. Aug 10, 2012 at 4:10 PM
    #905
    brannman
    Chesapeake, VA
    01 TRD
    Sorry, forgot to add this. The main goal is to not have a rake or bro lean, I am sitting level now and want to retain that...but with better ride quality. I like the amount that it is lifted in the front which is around 3 to 3.5 inches.
    I guess my biggest fear is ordering a new leaf pack, install it, and then have a crazy rake because of the fresh pack. I only need no more than 2 inches in the rear.
  6. Aug 10, 2012 at 4:19 PM
    #906
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    Im in almost the same boat as you
  7. Aug 10, 2012 at 5:47 PM
    #907
    Blackdawg
    Monte
    Wyoming/St. Louis
    The OME leafs or Dakar leafs are great leafs.
    As a general rule to keep the rear level you want about 1" less lift out back then front to get keep it level.
    I believe, not sure cant remember, the Dakar leafs give 2.25ish lift? So you should be pretty close to level with them.
    But when you first get them make sure you wait a week at least before decided you need longer shackles or something to increase the lift as the front eibachs do settle
  8. Aug 10, 2012 at 6:03 PM
    #908
    brannman
    Chesapeake, VA
    01 TRD
    Yeah i didn't get that much lift out of the 5100s set at 2.5 with stock coils back when I got them. I trimmed a hell of a lot and still rubbed with 285s so i jumped down to 265s.
    Just as an easy fix I added the 1 inch spacer on top for that extra lift since the coils were old as hell anyways. But now I just need that better ride so the Eibachs are the no brainer. Just gonna have to experiment/research more with the rear leaf packs
  9. Aug 10, 2012 at 6:14 PM
    #909
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ya you have a lt of options.
    Allpro
    Dakars
    Alcans
    Wheelers premade(made by alcan)
    If you have the money contact alcan and have them make you a custom pack to fit your needes(ride height and weight capacity)
  10. Aug 11, 2012 at 5:42 PM
    #910
    white toy taco
    white toy taco 505 Member
    Albuquerque, NM
    '06 OR and '02 OR (sold)
    really!? did you get them from DSM? i got mine from wheelers and they did not come with the bushings
    are you 4x4? 3.5" on the front is too much, unless your a prerunner
  11. Aug 11, 2012 at 6:07 PM
    #911
    Blackdawg
    Monte
    Wyoming/St. Louis
    Eibachs tend to actually give 3.5-3.25" of lift..but yes cv boots take a hit.
    I bought my bushings separate for fronts from toyotech and they came with from DSM for me as well for my 5150s
  12. Aug 11, 2012 at 6:21 PM
    #912
    white toy taco
    Albuquerque, NM
    oh ok gotcha :thumbsup:
    im using bushings from my old ranchos and they seemed to fit well. how crucial do you think it is to have the recommended bushings? also, does the top nut have to be all the way down the threads or can it be up a little bit (mine are all the way down, im just curious)
  13. Aug 11, 2012 at 6:36 PM
    #913
    Blackdawg
    Monte
    Wyoming/St. Louis
    Nah I bet they they will be fine. It's just nice to put new ones in while you have the chance.
    And top nut? You mean the three top ones? Yes very important they are snug. You don't want there to be play to be between the coil over and the mount.
    Or are you talking about the main bolt that holds the top plate down?
  14. Aug 11, 2012 at 6:50 PM
    #914
    white toy taco
    Albuquerque, NM
    yea i mean the main bolt
  15. Aug 11, 2012 at 6:56 PM
    #915
    J88logue
    Johnny
    HWY 30
    02 D.C. TRD
    Clicko BUILDo
    My All-Pro leafs will be on in a week or so. Id be happy to report on pros and cons to you.
  16. Aug 11, 2012 at 6:57 PM
    #916
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    not like your going to be using them to full potential... TSF biznatch.
  17. Aug 11, 2012 at 7:01 PM
    #917
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ya I'd want it all the way down
    I have heard mixed things about the standard leafs. Will be interesting to see how ya like em.
    haha
  18. Aug 11, 2012 at 7:01 PM
    #918
    J88logue
    Johnny
    HWY 30
    02 D.C. TRD
    Clicko BUILDo
    Getting my pecker wet at a wedding :) i'd be happy to test the flex on ur hood!
  19. Aug 11, 2012 at 7:02 PM
    #919
    Bennett707
    Oregon
    We will see about that :p
    I got a few weeks head start :)
  20. Aug 11, 2012 at 7:05 PM
    #920
    Konaborne
    Cody
    Kealakekua, Hawaii
    check the link under all the pictures in the OP. I compiled a list of rear non-SUA spring/shackle options
