Bilstein 5100 / Eibach Gallery
Discussion in '1st Gen. Tacomas (1995-2004)' started by tcBob, Sep 6, 2011.
  1. Sep 3, 2012 at 10:12 PM
    #1001
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    x2. without compression, how long are they?
  2. Sep 3, 2012 at 10:19 PM
    #1002
    99nmtaco
    99nmtaco Well-Known Member
    Patrick
    NM / VA
    2001 4 Runner
    ADS racing shocks ext travel front, ADS FJC piggyback shocks rear, Addicted Offroad front plate bumper, 4xinnovations rock sliders and rear plate bumper, SCS Stealth 6s
    I can finally join this group! Ive had my Bilstein 5100's and Eibach coils for almost a month now and Im lovin um!
    Before Lift:
    After Lift:
  3. Sep 4, 2012 at 6:41 AM
    #1003
    shahabshaukat
    shahabshaukat Active Member
    Lox, FL
    Tacoma
    for sure!
  4. Sep 4, 2012 at 7:49 AM
    #1004
    brannman
    brannman Well-Known Member
    Chesapeake, VA
    01 TRD
    stock ucas. alignment is close to perfect...we'll see about ucas in the future since they are so damn pricey
  5. Sep 4, 2012 at 9:04 AM
    #1005
    J88logue
    J88logue NorthWest Member
    Johnny
    HWY 30
    02 D.C. TRD
    Clicko BUILDo
    STOCK UCA - dead on!! No rub :)
  6. Sep 4, 2012 at 9:07 AM
    #1006
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    01 4wd trd, 255/85/16 km2s
    5100's with eibachs. And 255/85/16 km2s
    I'm bout to put a 1.5inch aal in the back. Am I gonna need new shocks?
  7. Sep 4, 2012 at 9:15 AM
    #1007
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    New shocks then stock? yes.
  8. Sep 4, 2012 at 9:56 AM
    #1008
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    Yeah I've still got the stock shocks. They are real shitty so I guess I need new ones anyway
  9. Sep 4, 2012 at 10:21 AM
    #1009
    marintacoma
    marintacoma Well-Known Member
    Marin
    2004 white toyota tacoma 4x4 trd
    Have you guys ran into any issues with the cv angles or anything? I have looked into the cv boot mod, but don't really want to mess with that
  10. Sep 4, 2012 at 10:22 AM
    #1010
    marintacoma
    Marin
    Also I just got new 265/75/16 tires, do you guys think ome 881 would be better since I do not plan on going up to 285 tire size?
  11. Sep 4, 2012 at 10:23 AM
    #1011
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yes. If your worried about CVs..don't get the Eibachs. The 881s will do just fine. Unless your wanting to add a bumper/winch..then you'll want 882s
  12. Sep 4, 2012 at 11:17 AM
    #1012
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    Do you think I'll clear 255/85/16 km2s without eibachs? I don't wanna tear cv boots all the time. I don't mind to use a hammer on the pinch weld
  13. Sep 4, 2012 at 3:00 PM
    #1013
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea if you don't care about cutting a lot and hammering a lot, they will fit.
    You'll end up hammering a LOT tho mostly due to the fact a 255/85 tire is like 33.5'' or something and 285/75 is 32.8 or so so it'll be taller and hit more of the fire wall.
  14. Sep 4, 2012 at 4:29 PM
    #1014
    J88logue
    Johnny
    HWY 30
    02 D.C. TRD
    Clicko BUILDo
    Holy Shit! SO many questions! Each question has already been answered if you just read from page 1 :cool:
    Also even though tire sizes say 285/70r17 = 32.8 inches tall, remember every tire is different. For instance mine is taller than a 33.
    Misstype!
  15. Sep 4, 2012 at 4:32 PM
    #1015
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    tread design height changes are minimal
  16. Sep 4, 2012 at 4:49 PM
    #1016
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    Yeah well didn't really feel like readin every page
  17. Sep 4, 2012 at 7:51 PM
    #1017
    white toy taco
    white toy taco 505 Member
    Albuquerque, NM
    '06 OR and '02 OR (sold)
    i have the 881's with the billies set at the middle setting and i got a little less than 2.5" of lift with my 65 lb tube bumper and approximately 140 lbs of sliders. i also have the same size tires and they fit perfectly, only minimal rubbing. this is the only pic i have of the front
    hope this info helps
  18. Sep 4, 2012 at 9:50 PM
    #1018
    marintacoma
    Marin
    thanks that does help, arent you not supposed to put it on the middle setting if you have a first gen? thought it would only give about 2 inches of lift if i put it on 0"? im guessing your rubbing on the frame at full lock? i noticed that too with my michelins
  19. Sep 4, 2012 at 10:04 PM
    #1019
    Blackdawg
    Monte
    Wyoming/St. Louis
    No he has OME 881 coils which give about 1.5'' lift on the 0'' setting. I wouldn't really recommend putting it on the 1'' setting with the OME coils..but whatever
    now the Eibachs..DON'T even THINK about running them on anything but 0.
  20. Sep 4, 2012 at 10:56 PM
    #1020
    white toy taco
    Albuquerque, NM
    i was rubbing on the frame but when i put 2" spacers, im now rubbing the pinch weld/plastic shit in the fender
    why dont you reccomend i have them on the middle setting?
