Bilstein 5100 / Eibach Gallery
Discussion in '1st Gen. Tacomas (1995-2004)' started by tcBob, Sep 6, 2011.
  1. May 16, 2013 at 10:05 PM
    #1661
    Rebel Taco Man
    Rebel Taco Man Well-Known Member
    Tyler
    Western Kentucky
    2002 Manual TRD SR5 4x4
    Bilsteins front and rear, Eibachs up front, 2" Toytec AAL in rear, Diff Drop, Grey Wire Mod
    Startin on mine tomorrow! im pumped guys!
  2. May 16, 2013 at 10:15 PM
    #1662
    Rebel Taco Man
    Tyler
    Western Kentucky
    what about problems with tearing boots? how many have done this?
  3. May 17, 2013 at 11:52 AM
    #1663
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Are you saying that the 5100's are able to accomodate a rear lift?
    I was planning on either replacing my leafs or putting an AAL to help reshapy my old worn pack and provide enough lift to have the truck sit level after I lift the front about 2 - 2.5 in the front.
  4. May 17, 2013 at 12:00 PM
    #1664
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Southern New Mexico
    2018 Tacoma TRD Off Road 4x4
    I'm running 5100's with 2" of lift in the rear, no problems at all with them.
  5. May 17, 2013 at 7:18 PM
    #1665
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    5100s should be able to handle 0-2" of lift with no issues
    I also run 2" in the rear with 5100's
  6. May 22, 2013 at 4:38 PM
    #1666
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    And in the front, what do you have up there?
  7. May 28, 2013 at 9:05 PM
    #1667
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    I'm running 5100 w/ eibachs in front. 5125's in back w/ OME Dakar leaf springs.
    I love it, Ride and looks.
    Here's mine with the lift. New/ bigger tires are comming soon, once the money tree is ready for pickin
  8. May 28, 2013 at 9:07 PM
    #1668
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    You will rip boots, comes with the territory.
  9. May 30, 2013 at 8:14 AM
    #1669
    Rebel Taco Man
    Tyler
    Western Kentucky
    my rake is back!!! :( i have bilstein 5100's i ordered from DSM, and eibachs and a 2" leaf from toytec. and my rake is back, why is my rake back?! every other truck running this is level, or under level. :mad:
  10. May 30, 2013 at 10:55 AM
    #1670
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    01 4wd trd, 255/85/16 km2s
    5100's with eibachs. And 255/85/16 km2s
    They will probably settle a little
  11. May 30, 2013 at 2:40 PM
    #1671
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    What spring pack did you add the AAL to?
  12. May 30, 2013 at 8:51 PM
    #1672
    Mainmoe02
    Moe
    Austin, Texas
    Did you add new leaf packs or AAL? Some people have to set the billies on the 2nd notch (1st gens only have 3 notches). Not sure why but maybe that would help? I have mine set on stock ride height with the coil providing the 3" lift. My new leaf packs added exactly 2.25" to the rear. Before adding the new suspension I was stock everything and for whatever reason I was sitting very close to level. After the new susp. I'm sitting 1/4" higher in the front.
  13. May 31, 2013 at 8:28 AM
    #1673
    Rebel Taco Man
    Tyler
    Western Kentucky
    i have eibach coils up front, so my shocks are on first setting, but i added the 2" aal to my stock leafs and it really re-arched them. cause i have a rake now.
  14. May 31, 2013 at 8:35 AM
    #1674
    Digiratus
    Roaming the PNW
    The RedHead
    A little rake is good as it makes it easier to get a good alignment. Too much does look a little goofy tho.
    A simple easy fix would be to add some weight to the back to get it down some. Might also help to get the AAL broken in and settled.
    Do you have a pic of it from the side?
  15. Jun 5, 2013 at 1:48 PM
    #1675
    DUCKSHOT
    DUCKSHOT Well-Known Member
    TX
    01' Tacoma PreRunner
    So I have read all 89 pages and I have only one question....
    Since I just found out that Eibach springs everyone is using are not made for the Tacoma.
    "Why is everyone using Eibach/Bilstein combo instead of just the Bilstein Height adjustable shock with the stock spring?
    The Bilstein shock was designed to be used with the stock spring and you would think the the company would have designed it right so it would work without using a heavier duty spring. I wonder if there is a possibility of future damage to the front end.
    I will getting the Eibach/Bilstein combo with Dakkar Leaf packs just because it seems the only way to lift and level the truck without an AAL. I need new leaf packs since mine are flat so it seems this is the best option for me.
    Tell me what you guys think, especially y'all that have had it on for a while and do some serious wheelin.
    EDIT:
    So Eibach says they don't make one for my truck but when I mention Toytec and the part # they said I have to get all info from Toytec.
    Bilstien said the same thing and have to talk to Race Car Dynamics. That guy was helpful.
    I just wanted to know for warranty purposes and cause when you hear something isn't made for that you wanna check it out. He basicly said go to who sold it to me for a warrant purposes.
    Sorry I y'all knew this already or don't care but I hope it helps!!
  16. Jun 5, 2013 at 5:42 PM
    #1676
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    The 5100's have the option of lifting with stock coils but it really is a temp solution because it is doing the same thing as spacers do, precompressing the spring. The 5100 is longer than stock allowing it to work with the Eibach coil which has a different spring rate which lifts the truck without all the precompression. As far as the coils go they are made for tacomas. Eibach exclusively produces this particular spring soley for toytech which is why the springs have Toytech part number and not an Eibach part number. The Eibachs and Bilsteins were made to go together just like the OME springs and nitrochargers. The snap ring is just a function that allows for lift with stock spring. People buy them because of the length, not the snap ring.
  17. Jun 5, 2013 at 6:11 PM
    #1677
    DUCKSHOT
    TX
    Now that makes a lot of sense and no one told me that and didn't read it or overlooked it somewhere. Thanks a lot for the info.
  18. Jun 5, 2013 at 6:12 PM
    #1678
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    No problem man. I found out some of it the hard way too haha.
  19. Jun 10, 2013 at 1:54 PM
    #1679
    Kirk1589
    Kirk1589 Well-Known Member
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Pasti-Dip Grille, K&N drop-in, Magnaflow 14", Custom tail light mod, Fog light mod, diff vent mod, Alpine Components, Sequoia JBL radio
    My set up with one issue. I have a maxed out UCA ball joint I think. I have a loins squeak, squawk on a bushing or metallic. It happens if I rock the front up and down, turning the wheel driving and stopped. Mainly putting a down pressure load and releasing that load.
    Setup
    5100's with Eibach @ Zero. Bottom
    5100's rear
    Allpro 3" leaf pack rear
    Toytech rear brake line
    BPV bracket
    Have not installed diff drop yet
  20. Jun 10, 2013 at 3:23 PM
    #1680
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    I originally replied to your post in the "What have you done to your Taco" thread but I guess this is a better place.
    I can't tell from your pic but it is possible to install the black lower spring seat on upside down resulting in a lot higher ride height than anticipated.
    One side of the seat (the lower side) has a groove on the inside intended to slide over the c-clip. This feature "contains" the clip preventing it from spreading apart, popping out of the groove and then sliding down the shock body under the weight of the truck. A dangerous situation to say the least.
    If the yours is upside down you should be able to see it. Look closely up under the seat, if you see the majority of the outside edge of the clip it's a boo boo. We are talking about 2" or more lift than anticipated.
    Just a thought.
