Bilstein 5100 / Eibach Gallery
Discussion in '1st Gen. Tacomas (1995-2004)' started by tcBob, Sep 6, 2011.
  1. Sep 30, 2013 at 10:58 AM
    #1941
    yote
    yote Washington State University
    Mark
    Tacoma, WA
    2002 Ext Cab TRD Off-Road
    ....it sure looks like he is :confused:
    You're gonna want it switched around :eek:
    Like so:
  2. Sep 30, 2013 at 11:36 AM
    #1942
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    I don't think there is technically a right side up but I run mine shaft down so that mud, dirt, and water don't sit on the seal where the shaft goes in the shock body and cause damage. I also took my boots off so mud and dirt don't get trapped in there. I only took it offroad one time before I ditched the boots and there was quite a bit in them already.
  3. Sep 30, 2013 at 11:39 AM
    #1943
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    I run mine with the body up and out of the way too
    I kinda have to because of the piggyback resi, but still
    it's kinda a preferential thing, but usually the shock body is on top
  4. Sep 30, 2013 at 12:26 PM
    #1944
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    there isn't really a right or wrong..
    that said, i recommend bodys up and shafts down. Water can poo on the top of the bodys and wear out the seals faster. Plus if you hit anything..id rather it not be body and blow the shock.
  5. Sep 30, 2013 at 12:36 PM
    #1945
    Konaborne
    Cody
    Kealakekua, Hawaii
    I'd rather water not poo on my shocks
    that would make me sad
  6. Sep 30, 2013 at 12:40 PM
    #1946
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea plus like you i have the resi that needs to be up.
    for those running the body down..ask yourself this..all the top brand shocks(fox, king, icon, ect) that have resi's..all mount body up..must be a good reason..
  7. Sep 30, 2013 at 12:47 PM
    #1947
    stikle
    stikle Well-Known Member
    Seth
    The Sovereign State of Eastern Oregon
    1997 LX Xtracab 4x4 V6 3.4L
    Eh, see my Build Thread sig link. Too many mods to list.
    Interesting...pretty sure the paperwork that came from Wheeler's with mine said that the boot goes down...and that's how my tech put them on.
  8. Sep 30, 2013 at 1:15 PM
    #1948
    Blackdawg
    Monte
    Wyoming/St. Louis
    Thats how they should be..IMO too.
  9. Sep 30, 2013 at 1:50 PM
    #1949
    Dietter700
    Dietter700 Well-Known Member
    Troy
    Montgomery County PA
    Taco TRD off road
    I think I'm gonna flip mine .hmmm ( currently boot up )
  10. Sep 30, 2013 at 8:37 PM
    #1950
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    These Bilsteins are nitrogen charged. This means they can be run shock body up or down. Old style shocks, the "emulsion type" like Rancho 5000s, have to be run with the shock body down due to their design.
    Given that choice,I would rather have the hardened shaft down and the shock body up out of the way. The shock body is much more vulnerable to damage.
  11. Sep 30, 2013 at 8:53 PM
    #1951
    yote
    Mark
    Tacoma, WA
    Soooo how I have it then :eek:
  12. Sep 30, 2013 at 9:00 PM
    #1952
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, but its a pretty easy swap if you think its worth it. If it was mine, I would flip them and remove the boots.
  13. Sep 30, 2013 at 9:00 PM
    #1953
    Konaborne
    Cody
    Kealakekua, Hawaii
    at least the rears are supah ez to do
  14. Sep 30, 2013 at 9:02 PM
    #1954
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    I think he's saying that it's okay to mount then like yours, but that the recommended way is boot down, body up (that's the way we like to....mount our shocks) :D
  15. Sep 30, 2013 at 9:03 PM
    #1955
    yote
    Mark
    Tacoma, WA
    I looked at how my Dad has his set up, boot side up. So that's what I did. I figured it would be better to have those up, or higher away from the ground. Still recommend removing the boot? Maybe just remove the zip ties and put newer (tighter) ones on there?
  16. Sep 30, 2013 at 9:04 PM
    #1956
    yote
    Mark
    Tacoma, WA
    Ah gotcha. Hmm well maybe after hunting this weekend I'll gather some energy and flip em. Like Kona said, the rears are supa ez to do
  17. Sep 30, 2013 at 9:13 PM
    #1957
    Konaborne
    Cody
    Kealakekua, Hawaii
    just that dirt/water can get trapped in the boot...so instead of them protecting the shaft they can end up doing damage.
    but if you clean and check them regularly, they should be fine.
    usually the wiper seals are enough to keep the shafts happy
  18. Sep 30, 2013 at 9:20 PM
    #1958
    yote
    Mark
    Tacoma, WA
    Ah dirt/water would be no bueno when it comes to the shock compressing/expanding. I'll just give Downsouth a ring tomorrow and see what they would usually recommend
  19. Oct 1, 2013 at 7:44 PM
    #1959
    Dietter700
    Troy
    Taco TRD off road
    Finished my truck today! Couldn't be happier ! As soon as learn how to post pics il be putting it on here!
  20. Oct 1, 2013 at 7:45 PM
    #1960
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    Fixed :D
    If you are a member here...your TRUCK will never be finished.
