Bilstein 5100/Eibach w/ Icon RXT
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Edewouldgo, Jan 13, 2022.
  1. Jan 13, 2022 at 8:27 PM
    Edewouldgo
    Edewouldgo [OP] Member
    What up?
    Currently I have a 2013 with 3” spacers and an AAL in the rear. “3/1”. Leer cap, tools and ladders in the back. @200lbs. I was very happy with the stance when first installed. Also have some airbags in the rear for my cabover camper when it’s go time.
    Just ordered a set of Bilstein 5100 w Eibach springs built to have 3” up front. Haven’t gotten them yet. Also picked up a set of Icon RXT leaf packs today.
    Spoke to icon and they have their little chart. I get it. It’s adjustable to your needs. A very smart package.
    My goal is to have my truck sit level. 3/1 is the number to me.
    On the fence about leaving the packs the way they are or swapping out the extra one for option 2.
    Thanks in advance.
  2. Jan 14, 2022 at 5:51 AM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    How the hell did you get a hold of rxt’s?? I’ve been waiting for months
  3. Jan 14, 2022 at 7:11 AM
    kraftorama
    kraftorama Well-Known Member
    Longmont, CO
    2015 Tacoma TRD OR DCSB
    GFC Camper Icon RXT leaf pack 3rd gen suspension 2022 Trail Edition wheels
    I installed RXT’s in option 1 about a month ago. I have a GFC (270 lbs) but my 2nd gen is otherwise stock. Hub to rear fender is 23” which is about 1.5” higher than my slightly sagging oem springs. If I add another ~100 lbs to the bed the rear sits at 22.5”.
  4. Jan 14, 2022 at 7:11 AM
    RedWings89
    RedWings89 Well-Known Member
    Luke
    SE Virginia
    2014 SR5 DCLB
    I'm in the process of doing a similar suspension upgrade. I ordered 5100s all around (should get delivered next week) and a set up RXTs (around a week or so to get them delivered from Wheelers). I'm planning on going to the highest setting on the 5100s and going with stage 2 on the RXTs. I have around 250 lbs of constant weight in the back and want to keep a little bit of rake. It won't be quite as much rake as the factory. If my math is right and the estimates from bilstein and icon are close I'll still have around 5/8" of rake.
  5. Jan 14, 2022 at 7:30 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Just had icon stage 8 installed... factory 2" coiliover height up front and option 2 on the rxt leafs in back. With the weight of a SnugTop canopy and 100lbs of sandbags the truck has close to a 2" rake. I think a 3" front and option 2 is your best bet... should be close after break in. My numbers right after install were 22" hub to fender front/ 24" in back. The back has dropped down another 1/4" after adding another 100lbs of sandbags (200lbs total.)
  6. Jan 14, 2022 at 8:36 AM
    Edewouldgo
    Thanks. Much appreciated. Looks like I’ll go option 1. I’m at @ 22 1/4 in the rear now.
    I picked them up at off-road warehouse yesterday.
