Bilstein 5100 front only
Discussion in 'Suspension' started by RRDave, Dec 31, 2010.
  1. Dec 31, 2010 at 7:37 AM
    RRDave
    RRDave [OP] Well-Known Member
    Halifax, NS
    08 Black TRD
    CAI, AT2525XL, 2.5" spacer, 1.5" AAL, DNX6140 HU c/w rearview cam, Fog Light Mod, Custom rear dog seat,
    Hey everyone,
    I'm looking for a budget friendly way of lifting/leveling my taco that's not a spacer lift. Has anyone here started out by installing 5100's in the front only? If so do you have pics? What size tires are you running? Are there any concerns/comments with this set up? I have an 08 TRD DC.
    Appreciate any input
  2. Dec 31, 2010 at 7:45 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    You can put them on all for corners as they will only lift the front.
  3. Dec 31, 2010 at 8:16 AM
    RRDave
    Halifax, NS
    08 Black TRD
    Thanks for the reply,
    I understand that they will only lift the front, my question is, will I encounter any problems if I replace the fronts only and leave the rear stock?
  4. Dec 31, 2010 at 8:21 AM
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    I'm installing 5100''s on the front set at 2.5 and add-a-leaf on the back.
    From what I understand, if you just want to level your truck, you can put 5100's on the front set at 1.75 with no add-a-leaf. With the 5100's set at 1.75, you shouldn't need new UCA's. However, if you set them at 2.5, you may need new UCA's
    Mine arrived today. I'll be posting pics of my install when I get to it.
    Cheers.
  5. Dec 31, 2010 at 8:22 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    You won't encounter any problems.
  6. Dec 31, 2010 at 9:31 PM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    I'm running 5100s on the front only set at .85 and the ride is fine. The rear is a little softer feeling but it is not an issue.
  7. Jan 1, 2011 at 8:33 AM
    itsjoe
    itsjoe Member
    Joe
    winnipeg
    2010 TRD o/r 4x4
    35% tint, TRD skidplate, whether techs, AFE-stage 2 intake, 5100's set at 0, eibach springs,17'' atx crawl,265/70/17 nitto trail grapplers, color matched grill
    I just installed my 5100's last week set at .85 no problems at all. a 32'' tire on a stock rim will be fine at that height.
  8. Jan 3, 2011 at 4:51 PM
    lynyrd3
    lynyrd3 Strength ,Determination ,Merciless,Forever
    Bill
    Upstate New York ,Columbia County
    2008 SR5 AC SUPER WHITE V6 4x4
    Bilstein 6112s at top setting ,1/4" top plate spacer driver side,Total Chaos UCAs ,SS extended brake lines ,Rear 4 leaf Suspension TSB,Wheelers 2" AAL, Bilstein 5125s , SS extended brake lines rear , Toytec dif drop , Hayden high performance transmission fluid cooler,aFe pro dry filter , ,Powerstop drilled and slotted rotors.N-Fab light bar with 4 Hella OR lights , Devil horns by Andres ,Weathertecs floor protector, American Racing wheels Baja 17x8,4.5 BS , 285/70 Falken Wildpeaks AT/3W .Body Armor rear bumper . Extra D rings in bed ,Blue sea fuse block and 100amp breaker ,G-Tek Fab door sill protectors ,blacked out grille , painted pinch weld.Shorty antenna ,HVAC knob mod ,LED dome and map lights , Tri Fold bed cover ,UltraGauge ,Morimoto XB LED fog lights ,
    I started with the bilsteins set @ 1.75 and the 4 leaf pack TSB. My front sat higher than the rear by 1 ". So I added the 1 1/2" Toytec AAL now it sits 1/2 higher in the back perfect. Went with 265 /70 16 check out my newer pix . Also put the bilsteins in the back just so I have the same shocks all around. Rides is still good just stiffer. make sure you have an alignment after .
  9. Apr 17, 2011 at 3:44 PM
    504taco
    504taco Active Member
    Jacob
    N.O.L.A.
    2011 Prerunner SR5
    -Fog light mod -Yellow laminx fog -shorty antenna -maglight mount -tinted windows -alpine head unit -8" JBL sub -laminx yellow fogs -power inverter installed behind rear passenger seat -TX PRO rims -BFG All Terrain KO
    This may be a bit late but I thought I'd post it anyway. This guy put 5100's on the front and kept the rear stock. I think that's what I'm going to do also.
    http://www.tacomaworld.com/forum/suspension/83609-5100s-front-only-no-rear-mods-1-75-lift.html
    Byb127 likes this.
