Bilstein 5100 fronts with OME 885
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nammer, Apr 4, 2014.
  1. Apr 4, 2014 at 5:27 PM
    nammer
    nammer [OP] Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    hi there, so I'm reading a lot about people setting their bilsteins to .85 with the 885's to get the full 3'' or using a small top plate spacer, but is it possible to set the bilsteins at 1.75''? thanks!
  2. Apr 4, 2014 at 5:57 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Look at 887's. Same spring rate just taller.
  3. Apr 4, 2014 at 6:02 PM
    nammer
    Nam
    Bradenton, Florida
    in that case, wouldn't it be even more advised not to use any of the raised settings on the billies?
    like if I were looking at 887's could I go to .85 or 1.75 settings?
  4. Apr 4, 2014 at 6:31 PM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    Why do you want to go 1.75?
  5. Apr 4, 2014 at 6:40 PM
    nammer
    Nam
    Bradenton, Florida
    more lift :)
  6. Apr 4, 2014 at 6:42 PM
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    yes if you want to possibly get 3"+ of lift and preload the hell out of your cv's. I can see further bearing wear in the front diff and vibes. Doing this would not gain you any travel in suspension, it will do the opposite.
    People already preload with stock springs and it is really a stiff ride from what i hear. My question is why would you want to preload an even longer spring with a higher spring rate.
  7. Apr 4, 2014 at 6:51 PM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    See above ^
  8. Apr 4, 2014 at 6:52 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Get the 887s :)
    And set the 5100s at 0
  9. Apr 4, 2014 at 6:55 PM
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    Nam
    I wouldn't recommend preloading the 885's if you want a nice ride. Just set the 5100's @ 0 and put a small top plate spacer on top. You should also probably look into getting some spc upper control arms too if you are going to do this.
  10. Apr 4, 2014 at 6:56 PM
    Gearheadesw
    Davenport Fl
    I have 885x's at 0, how much taller;ie more lift are the 887's?
  11. Apr 4, 2014 at 6:59 PM
    nammer
    Nam
    Bradenton, Florida
    are 885x different from 885?
  12. Apr 4, 2014 at 7:02 PM
    nammer
    Nam
    Bradenton, Florida
    no cv's for me :)
    I'm not too concerned about the ride, I'm on pavement 99% of the time, so aside from ride quality, is it possible?
    basically, I just wanted the most lift possible :)
  13. Apr 4, 2014 at 7:03 PM
    nammer
    Nam
    Bradenton, Florida
    eyeballing a used set of 885s so i'd be working with that, but i guess the same question applies, can i preload to .85 or 1.75 with the 887's? other than ride quality?
  14. Apr 4, 2014 at 7:03 PM
    Gearheadesw
    Davenport Fl
    No, just an updated version. Fights sag better than the older 885's, I think. The main problem is your lifting your truck by eliminating down travel by moving the spring up. I would imagine you would top out the shock badly enough to damage it.
  15. Apr 4, 2014 at 7:11 PM
    inesshell
    you can try. from your responses i see that people advising you to set it as 0 will not change your mind but bear in mind the 5100s were never designed to handle anything preloaded outside of the stock springs.
    Being said, its your truck....and from observation with that kind of spring you want you will be reducing the life of the shock or some other component in your suspension. for something you want since you are without cv's i would suggest a spindle lift. If you are on a budget, i really would just advise you to wait and do a proper lift so you dont regret it later.
  16. Apr 4, 2014 at 7:12 PM
    BORNWILDGUY
    Rich
    Florida
    You say that now but after driving it awhile preloaded you probably won't like the ride.
    Yottamatt had his ebiachs set to 1.75 and switched to 885's set to 0 so you might want to ask him the ride difference
  17. Apr 4, 2014 at 7:15 PM
    inesshell
    trust me you dont want this....LOL
  18. Apr 4, 2014 at 7:17 PM
    nammer
    Nam
    Bradenton, Florida
    oh I def appreciate the input, its not that I actually decided on anything for sure yet, it's just that pretty much any post I've read says to set at 0 for 2''ish lift, and .85 if you want the full 3'', but no other reasons other than harsh ride, I just wanted to know if they could take them. I already did the spindle lift, but looking for a little more lift :)
  19. Apr 4, 2014 at 7:18 PM
    nammer
    Nam
    Bradenton, Florida
    :eek: that's terrible!
  20. Apr 4, 2014 at 7:18 PM
    nammer
    Nam
    Bradenton, Florida
    i'll ask him, thanks!
