Bilstein 5100...HELP!
Discussion in 'Suspension' started by custer, Jan 22, 2011.
  1. Jan 22, 2011 at 10:42 AM
    custer
    custer [OP] Member
    2010 Tacoma SR5 4X4
    Flowmaster 40 series muffler K&N CAI Powder coated Rims DeeZee Bed Mat Front Tints to match rear Husky Liner Catch-All floor mats Custom built removable bed rack by Sunfire Off-Road.
    Hello All!
    I am thinking about throwing some 5100's on the front of my tacoma, however, I am not willing to make mods or change anything major on suspension. This truck is my daily driver when I am home and I really just want to keep it simple. I am looking for the safest, most reliable way to level the front-end without causing any "death-wobble"...great experience I had with my long-arm suspension on my jeep!
    From what I have researched Bilstein 5100 may be the way to go. Any advice on this process would be great. Will I have to change anything else if I get 5100's, or can I just bolt them on, set/adjust and go??
  2. Jan 22, 2011 at 10:48 AM
    dmz1241
    dmz1241 Well-Known Member
    Dan
    SE, Connecticut
    01 Gold DC TRD
    Bilstein 5100's all around, Eibach coils, 2" shackles, Flowmaster 60 Series
    I have my billies set at 0 with eibach coils, but i still didnt have to change anything else. its a pretty simple set up. if you are going for a level look i think you will be happy with the 5100's
  3. Jan 22, 2011 at 10:51 AM
    vermintrex
    vermintrex Well-Known Member
    Vancouver
    TRD SPORT Shorty
    BFG A/T KO 265/70/17, '11 FJ wheels, 5100's all four corners, Eibach springs, 1/4" Taco lean spacer, Leer 100XR, WeatherTech liners, trimmed mud flaps and I farted in it.
    There's a lot of threads on this.
    Short answer..no, you won't have to mod anything, especially if you don't higher than 1.75" of lift. Even at 2.5" you probably won't have to do anything more than remove the old shocks, set your desired lift and reinstall. It's a remote possibility that 2.5" might make a factory spec alignment difficult. Some new UCA's would take care of that. Since you've got a 2010, you'll be able to reuse all of your stock bushings.
    The only other thing that might require modification is your fender wells if you want to stuff some bigger tires in there after the lift.
    You'll have to is get it realigned no matter what lift you set them to.
  4. Jan 22, 2011 at 10:57 AM
    BryWi
    BryWi Psalm 109:8
    Earth
    2011 TRD off-road DC SB w/JBL
    5100s, black valance
    There are a lot of threads on this topic. Go to "suspension" in the forum list and do a thread search in that forum for exactly what you may want to know.
    That way you will get many different opinions on all the options when lifting your truck.
    I had the rear TSB (4th leaf) done and set my 5100s at 1.75. My truck has a very slight rake. I changed nothing else with the suspension.
    Here's a pic:
    There are many more options out there for lifts. It depends what you are looking for. Good luck ;)
  5. Jan 22, 2011 at 12:29 PM
    boxxed
    boxxed Well-Known Member
    Denver, CO
    09 Off Road
    Whats the difference between setting the billies at 0 vs .85 or 1.75? I might know but rather not guess.
    thanks
  6. Jan 22, 2011 at 12:33 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    It is .85in of lift, 1.75in of lift, or 2.5in of lift
