Bilstein 5100 help
Discussion in '4 Cylinder' started by 27taco1988, Feb 15, 2011.
  1. Feb 15, 2011 at 4:55 PM
    27taco1988
    27taco1988 [OP] Active Member
    Cody
    Stafford, VA
    '10 2.7L 4x4
    Ok, so ive read up on the forum, but i thought id try to get some reg cab feedback. ive got a '10 4x4 reg cab and just ordered some 5100's. i wanna set them at 2.5 but there are some guys out there that swear you need aftermarket UCA's. Ive also heard you only need aftermarket UCA's if you're goin 3". What do y'all think?? Thanks
  2. Feb 15, 2011 at 5:43 PM
    HomeGrown
    HomeGrown Well-Known Member
    Bill
    South Bend, IN
    2014 Reg Cab 4WD
    I'm pretty clueless regarding lifts, but am just now starting to look into them. I read from more experienced members that you don't need UCA's for lifts under 3".
  3. Feb 15, 2011 at 5:44 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    It's hit or miss at 2.5". Some need new UCA's some don't.
  4. Feb 15, 2011 at 5:45 PM
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SP... CaL
    11 TRD sPort
    5100's@1.75 Horns (Andres) Satoshi TRD cat back BHLM
    For benefit of doubt just get them
  5. Feb 15, 2011 at 5:46 PM
    27taco1988
    Cody
    Stafford, VA
    '10 2.7L 4x4
    ya..but im not droppin 500+ bucks if i dont have to
  6. Feb 15, 2011 at 5:47 PM
    KPT
    09 Prerunner
    Or see how close they can get the alignment without them, keeping in mind that you might have to pony up and buy them.
  7. Feb 15, 2011 at 5:48 PM
    creeper
    creeper Well-Known Member
    Why would you spend (at minimum) $400+, for something you likely don't need?
  8. Feb 15, 2011 at 5:48 PM
    rmahoney2013
    rmahoney2013 Well-Known Member
    Robert
    California
    Speedway Blue Tacoma
    you dont need them bro.. unless your going to be bashin up your rig you will be fine. if you want to take it and kill it (front end) then you should get some
  9. Feb 15, 2011 at 5:51 PM
    BrettBretterson
    BrettBretterson Wild Ginger
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    Most people get them for alignment reasons, not offroad capability.
  10. Feb 15, 2011 at 6:00 PM
    The1youluv2hate
    Peps
    SP... CaL
    11 TRD sPort
    If ur alignment is jacked up your tires will also be jacked up So if ur gonna drop $$ on nice tires get a good alignment and if it's all good don't waste ur money on uca's
    My .02 is that everything should be properly done
  11. Feb 15, 2011 at 6:02 PM
    KPT
    09 Prerunner
    So you install the lift, get it aligned, and if the alignment is out of spec, get new uca's....
  12. Feb 15, 2011 at 6:33 PM
    dgr540
    dgr540 I've got the FUNK
    Friendswood, TX
    2013 Wrangler Unlimited
    XDs Trail grappler 35x12.5x18 Winch 8K lbs Front bumper 4in Lift
    Mine is set to .85 and I swear I still see my wheels angled. Thats after 2 alignments. They guy at NTB told me I might need an aftermarket kit to get realigned.
  13. Feb 15, 2011 at 6:33 PM
    KPT
    09 Prerunner
    Take it to someone else :cool:
  14. Feb 15, 2011 at 6:44 PM
    dgr540
    Friendswood, TX
    Well I am thinking about getting the Toytec/Eibach front coil lift springs. Do I need new ucas?
  15. Feb 15, 2011 at 6:49 PM
    KPT
    09 Prerunner
    the adjustable ones, or the 1.6" eibachs?
    If you go over 2.5, you will likely need new UCA's.
  16. Feb 17, 2011 at 9:45 AM
    27taco1988
    Cody
    Stafford, VA
    '10 2.7L 4x4
    thanks for all of your help guys. im just gonna take my chances. I'll get new UCA's if needed
  17. Feb 17, 2011 at 9:49 AM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    aye Cpl, you adapt and overcome! [​IMG]
  18. Feb 18, 2011 at 12:40 AM
    27taco1988
    Cody
    Stafford, VA
    '10 2.7L 4x4
    Kill :D
