Bilstein 5100 help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RyanBelliston, Dec 18, 2011.
  1. Dec 18, 2011 at 6:59 PM
    RyanBelliston
    RyanBelliston [OP] Well-Known Member
    Diamond Bar
    2005 PreRunner
    Retrofit OEMs w/ 5000K bulbs HID 4300 Fogs Fog Light Mod LED Gauge Swap (Blue/Green/White needles) -Jerez 10'' Kenwood Subwoofer 1500W Planet Audio Amp Debadged Tinted Windows Mudflap delete AFE ProDry S intake Engage front LT 8inch Kings with 2x2 King bump stops. Strapped at 16 inches Engage 4-Link rear 16inch King coil overs strapped at 22 inches Custom Engage bumpers LED reverse lights LED license plate lights LED dome and map lights Flyzeye-Design (blue/white)
    I am ordering all 4 pre-loadable Bilstein 5100 shocks from DSM. Im going to set the front to 2.5 setting. Buying a set of used 285/75/16 tires from a buddy. My overall goal is to get the truck up a little bit with some bigger tires but with good shocks as i will be doing very little offroading, but def some.
    Also I am going to run the stock coil springs. Does that work, or do I need a new set of coil springs?
    What exactly do I need to purchase from DownSouthMotorSports for the rear. (want to level up the back as well). AAL?
    Also will these tires fit fine with that setting?
    Sorry for the noob questions.
    Thanks for the help guys!
  2. Dec 18, 2011 at 7:19 PM
    GoDeacsWFU23
    GoDeacsWFU23 Well-Known Member
    Jonathan
    Clemmons, NC
    2013 Tacoma PreRunner TRD Sport
    Go with spindles and then get the 3" leaf kit from all-pro.
  3. Dec 18, 2011 at 7:25 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    With 2.5" in front it is recommended you drop the front differential.
    What this does is it brings the front differential down (about 1") and
    takes some of the stress of the front CV's (and for some cures vibrations after lift). The kit runs about $30 from Toytec, Wheelers ect...
    If you have the TSB rear spings the 1.5" AAL should bring you level.
    If you have stock rear springs the 2" AAL bring it level.
    So how do you know if you have the TSB springs?
    EASY, count the number or leaf springs, you will have 3 or 4.
    If you have 3, then you do NOT have the TSB springs.
    If you have 4 you DO have the TSB springs.
    3 = STOCK
    4 = TSB Rear Springs.
  4. Dec 18, 2011 at 7:27 PM
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    Your stock coils are designed to work with the 5100's.
    The 285's are gonna cause you some trouble. 275's will fit on the stock rims and decrease the likelihood you will need to trim mudflaps.
    You'll need new UCA'S
    a REAR aal will also be in order. 1.5-2"
  5. Dec 18, 2011 at 7:34 PM
    ffemt2987
    ffemt2987 Shut up Hippie!
    Austin
    Golden
    Cement 3rd gen that was supposed to stay stock
    Rack, sliders, softopper, tjm bumper, eibach temp suspension
    I run 285's at 2.5 and my UCA's are fine. I do have some rubbing, however, I have 16x9 rims. But, you can always trim where you need it.
  6. Dec 18, 2011 at 7:35 PM
    GoDeacsWFU23
    Jonathan
    Clemmons, NC
    You don't need new UCA's for a 2" lift.....
  7. Dec 18, 2011 at 7:45 PM
    Hairy Taco
    North of Hell
    08 TRD
    you mean 2.5?
  8. Dec 18, 2011 at 7:47 PM
    GoDeacsWFU23
    Jonathan
    Clemmons, NC
    you don't need it on that either
  9. Dec 18, 2011 at 7:55 PM
    Hairy Taco
    North of Hell
    08 TRD
    Yeah , some guys say new uca's aren't necessary .
    a lot of guys on TW have had alignment issues with stock UCA's on a 2.5 inch lift. More adjustable uca's solved their problems.
    Personally, I would spend the $350. Especially if I was also planning big tires
  10. Dec 18, 2011 at 7:58 PM
    TnShooter
    Deogee
    STOCK
    Depends on the tires you use..... with 285 it will rub some.
    With 2.5" lift, I'd go 275, I have read that you can use FJ wheels and run 285's with no rubbing at all. But don't take my word on that...
