Bilstein 5100 help
Discussion in 'Suspension' started by cchicoine, May 27, 2017.
  1. May 27, 2017 at 11:24 AM
    cchicoine
    cchicoine [OP] Well-Known Member
    Caleb
    Bozeman, MT
    2017 TRD OR DCLB
    GFC V2 Pro, OME Nitrochargers and heavy springs, Dakar heavy leaf pack, ECGS Bushing, Firestone airbags, MBRP cat-back Exhaust, FabFours Premium front bumper, Winch, Cali Raised LED ditch pods, CB radio, Motegi MR150 bronze wheels 16x8 0" offset, Falken WildPeak A/T4W 285/75 R16, Relentless Fab Tailgate reinforcement, painted headlights, AVS wind deflectors.
    I'm new here and am trying to figure out the best lift option for me and I think I have settled on the 5100s after reading a ton of forums on here. What I can't find an answer to is what components I need. My goal is to achieve around a 2" lift. Can I get away with getting just the front and rear shock set and not get new coils or AAL's and still achieve a 2" lift? I have a 2017 DCLB with a Leer 100XR and a steel front bumper, would putting the front and rear shocks on the third setting achieve about a 2" lift with no coils or AAL's? Sorry if this is a stupid question, I ask a lot of them but I really appreciate all of the help on this site...
    http://www.headstrongoffroad.com/st...air)_-_24-263108_for_2016__Toyota_Tacoma.html
    HeadStrong Off-Road and tcjacado like this.
  2. May 27, 2017 at 11:26 AM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
  3. May 27, 2017 at 11:28 AM
    outlawtacoma
    W. TN
    2018 T4RTRDOR
    If you have that much added weight get a leaf pack in the rear and some coils in the front.
    ensaladas likes this.
  4. May 27, 2017 at 11:31 AM
    cchicoine
    Caleb
    Bozeman, MT
    2017 TRD OR DCLB
    That's what I was looking at, thinking front and rear 5100's OME front coils, and Deaver 1.5-2" AAL. Would that be all I would need? Since Im staying under 3" I wouldn't need new UCA's correct?
  5. May 27, 2017 at 11:32 AM
    outlawtacoma
    W. TN
    2018 T4RTRDOR
    Yeah that's correct. I have 885s and 5100s on mine with a deaver aal. I don't have a shell tho....
  6. May 27, 2017 at 11:36 AM
    cchicoine
    Caleb
    Bozeman, MT
    2017 TRD OR DCLB
    Thanks for all the help, would you reccomend the 886 to achieve about 2" since I have all the weight or do you think that put me nose high?
  7. May 27, 2017 at 11:37 AM
    outlawtacoma
    W. TN
    2018 T4RTRDOR
    Mine is a 2nd gen so I will defer to a 3rd gen owner for their recommendation
  8. May 27, 2017 at 11:37 AM
    ensaladas
    ensaladas DarthT8er
    ‘23 Trail Edition
    Most recommend the 886s with weight up front.
    cchicoine[QUOTED][OP] likes this.
  9. May 27, 2017 at 11:39 AM
    cchicoine
    Caleb
    Bozeman, MT
    2017 TRD OR DCLB
    Thats what I'm thinking, thanks!
    ensaladas[QUOTED] likes this.
  10. May 27, 2017 at 11:39 AM
    outlawtacoma
    W. TN
    2018 T4RTRDOR
    True, I have the 885s with 100lbs added up front. Rides perfect and it's settled at 2.25 -2.5" so I can't complain. 886s if you have over 100 lbs would be my recommendation
    cchicoine[OP] likes this.
  11. May 27, 2017 at 11:41 AM
    cchicoine
    Caleb
    Bozeman, MT
    2017 TRD OR DCLB
    Cool, looks like I've got it all figured out now! Think Ill go with the 886's, 5100's front and rear, and the Deaver AAL's. On Headstrong the total is only $619, pretty good deal for a 2" lift! You guys helped a ton thanks!
  12. May 27, 2017 at 11:42 AM
    cchicoine
    Caleb
    Bozeman, MT
    2017 TRD OR DCLB
    My final question, I don't have any tools cause I'm away for the summer so how much do you think it would cost to have a shop instal this set up?
    outlawtacoma likes this.
  13. May 27, 2017 at 11:45 AM
    outlawtacoma
    W. TN
    2018 T4RTRDOR
    Depends on the shop. But you could always get with the local group from here and they will help you out. And you will make some new friends.
  14. May 27, 2017 at 11:47 AM
    cchicoine
    Caleb
    Bozeman, MT
    2017 TRD OR DCLB
    Didn't think of that, good point!
  15. May 27, 2017 at 11:53 AM
    eon_blue
    Azusa, CA
    I had a local tire and alignment shop install my 5100s all around (plus coils and AALs) for $260, which included an alignment.
    Some 'offroad specialty shops' in the area wanted upwards of $700 to do it...
  16. May 27, 2017 at 11:54 AM
    cchicoine
    Caleb
    Bozeman, MT
    2017 TRD OR DCLB
    Thats about what I expected. Thank you!
  17. May 27, 2017 at 11:56 AM
    eon_blue
    Azusa, CA
    I should mention that I had the shocks/coils preassembled through Headstrong, otherwise the shop will charge more.
  18. May 27, 2017 at 12:04 PM
    outlawtacoma
    W. TN
    2018 T4RTRDOR
    Definitely get headstrong to do that
    HeadStrong Off-Road likes this.
  19. May 27, 2017 at 12:06 PM
    cchicoine
    Caleb
    Bozeman, MT
    2017 TRD OR DCLB
    I'd like to do that, on their website, however, it doesn't look like the kit comes is available with the 886's... I can piece it together but then there is no option for the assembly. Maybe I'll just call them after the weekend.
  20. May 27, 2017 at 12:13 PM
    outlawtacoma
    W. TN
    2018 T4RTRDOR
    Put it in your cart and then it should give you the option
