Bilstein 5100 Help
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacoman101, Dec 17, 2009.
  1. Dec 17, 2009 at 6:51 AM
    tacoman101
    tacoman101 [OP] Well-Known Member
    scott
    vermont
    2001 Tacoma sr5 xtra cab 4wd
    blue led headlights, 285/75/16 grabber AT2's, custom pedals, custom shifter, flowmaster 40 series muffler, bedlinered fender flares, 2.5" lift kit via shackles and spacers, custom exhaust out the back, chrome exhaust tip, and Herculined bed, Weathertech floormats, Cabelas Trail Gear Camo Seat Covers ... Nice thing was I got the truck for $4000
    So i'm getting tired of my shitty spacer lift becuase the ride is pretty stiff, and I swear that the front of my truck is sagging. I don't have the money for fancy coilovers or something like that, I wish I did, but for the mean time, I want some bilstein 5100 shocks for the front. First I have some questions.
    1st. Can I run the bilstien shocks just in the front, or do I have to get all 4
    2nd. If I just buy two front shocks, can I install them in my existing strut tower, or do I need new coils and everything.
    3rd. I might get flamed with this one but can I run both the bilstein shocks and the spacers. If I do will this give me more lift?
    4th. Does anyone want to buy these for me for christmas
    Thanks guys for all the help
  2. Dec 17, 2009 at 6:54 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Yes, you can run just the up fronts
    No, you don't need new coils
    and finally
    Are you out cha damn mind son? :smack: (if you leave them set at 0 you can, but what's the point since they are adjustable?)
    :D
  3. Dec 17, 2009 at 6:55 AM
    CJH9980
    CJH9980 Well-Known Member
    Clint
    Shreveport, LA
    2010 TRD OR 4x4
    5100's, Eibach springs, Toytec AAL, Total Chaos UCA's, MetalMiller Skid
    1. You can run them just in the front, or all 4
    2. You can use your existing coils
    3. Stacking lifts is generally frowned upon, however a small top plate spacer won't hurt anything...by small i mean 1/4" to 1/2"
  4. Dec 17, 2009 at 6:58 AM
    tacoman101
    scott
    vermont
    Alright, mabye I'll get a small 1/2" top plate
    would something like this work:
    "3/8" Thick Steel Top Spacer Pair: 41.00 [​IMG] A chrome plated steel spacer pair, 3/8" thick. For your front suspension. Stackable. Fits on top of the upper strut plate. Requires longer stud set shown below. Provides approx 1/2"-5/8" lift. "
    This is taken from wheelers website
    And would this give me a rough ride like my old spacers
  5. Dec 17, 2009 at 7:03 AM
    CJH9980
    Clint
    Shreveport, LA
    2010 TRD OR 4x4
    Should be fine. It'll sit on top of the strut so it won't preload the spring anymore...This is what I researched when building my setup, however I went w/ the toytec 1/2" top plate spacers
    I would assume it would be much smoother than your previous setup
