Bilstein 5100 idea
Discussion in 'Suspension' started by KeystoneGoodie, Jul 25, 2018.
  1. Jul 25, 2018 at 6:40 AM
    KeystoneGoodie
    KeystoneGoodie [OP] Well-Known Member
    Ben
    '09 AxCab with meat shoes and axe handles
    Lots of dollars and no sense...
    For anyone who has removed an old set of 5100 may or may not feel my pain. There is a allen socket at the top of the 5100 and when that shock spends it's life collecting dirt salt and whatever other foreign objects, good luck fitting an allen key back into that factory slot in order to hold the spindle from spinning while removing the top nut.
    The sawzall and I took care of that issue. But next time I have to replace these I'd really like to not have to use the sawzall.
    My idea, probably done before, is to put a little strip of rubber and zip tie it over the top of the spindle protecting the allen slot from shmust so when it's time to replace the shocks you can get right in there. Is there any reason this can't be done? Or does anyone have something they already find works to keep that slot clean?
    -Goodie
    2002Tacoma4x4 likes this.
  2. Jul 25, 2018 at 7:58 AM
    2002Tacoma4x4
    2002Tacoma4x4 TRD 4x4 double cab
    C K
    Limited Edition Double Cab TRD off road 4WD
    Worth to sell and\ or suggest the idea to Bilstein ... proper documentation and pictures .... sounds functional. Just saying ...thanks for sharing :thumbsup:
  3. Jul 25, 2018 at 8:01 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    A properly sized rubber nipple would do the trick and look better. *proceeds to google “rubber nipples”*
  4. Jul 25, 2018 at 11:58 AM
    gotblika
    gotblika Well-Known Member
    Maui
    2015 DCLB Sport 4X4
    5100'S 887 SPC B110 EL096R
