Bilstein 5100 Instal Problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CoachMuddy, Jun 12, 2024.
  1. Jun 12, 2024 at 4:30 PM
    CoachMuddy
    CoachMuddy [OP] New Member
    2014 Tacoma TRD Sport DCLB
    I have been creeping this site for at least 10 years. Y'all helped me pick my truck as well as saving me a ton of money by teaching me fixes along the way. I will post pictures shortly. I have a 2014 TRD Sport DCLB that I bought in 2016. It came with a OME Nitrochargers, Dakar pack, and total Total Chaos UCAs. I added a 1/2 inch spacer in 2019 when I jumped to 285's. Just got new tires, and needed to replace the shocks. Can't get Nitrochargers anymore so I switched to Bilstein 5100's so I could keep using the 885x springs and not have to start from scratch. Installed them Sunday, removed the spacers at that time because I realized I was sitting a little over 24" hub to fender. The install went fine, (struts are set at lowest setting) but here's the problem:
    At droop the passenger side dust boot slides down and then back up, as does the washer that sits on top of it, making a nice rattle/clang every time. The rubber bushings above the top hats are secure but not compressed even though I have bottomed out the nut to the edge of the threads on the shaft. Not sure if this is the cause of the problem, but I doubt it's helping. Under load the dust covers are solid with no play at all.
    Was there something I missed about switching from OME to Bilstein?
    Did the 1/2 inch spacer compress the rubber under the top hat so that it's not as thick as it needs to be?
    How do I take up the space needed to compress that washer without adding the spacers back in?
    I appreciate any ideas y'all may have. I've read just about ever thread on here about shocks and struts, and called and emailed Bilstein, but they won't respond.
  2. Jun 12, 2024 at 4:36 PM
    Toyoland66
    Toyoland66 Well-Known Member
    Colorado
    09 GX470
    Mostly stock on 35s
    The nut needs to be tightened more, the nylock portion will go past where the threads start. There’s a flat on the shaft to keep it from spinning while you tighten the nut.
  3. Jun 12, 2024 at 4:46 PM
    CoachMuddy
    I hear what you're saying, but it's metal on metal and there are no more threads. The shaft is smooth and the nut isn't going any farther.
    I backed the stupid thing off and removed the rubber bushing just to make sure I wasn't imagining things.
  4. Jun 12, 2024 at 5:12 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    Are you talking about the shock shaft or the tophat?
  5. Jun 12, 2024 at 5:44 PM
    CoachMuddy
    I'm talking about the shock shaft.
  6. Jun 12, 2024 at 6:06 PM
    Toyoland66
    Colorado
    09 GX470
    Mostly stock on 35s
    I think you must be missing some parts for the bushing assembly.
  7. Jun 12, 2024 at 6:09 PM
    SlippRott
    SlippRott Well-Known Member
    22 Silver OR
    Planning...suspension, front slimline bumper, winch, full skids, 2" lift, SCS Ray 10's, Pizza cutters, Power Tray, Switch-Pro, Alu-Cab Contour Canopy.
    This ^
    Need pics...
  8. Jun 12, 2024 at 6:22 PM
    sparkystaco
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    Sounds like you assembled the top of shock wrong.
  9. Jun 12, 2024 at 6:23 PM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    Not sure if this applies but I recently changed to OME springs on my 5100s, this time around I opted for new strut mount kits from by KYB, my upper shock bolt was almost to the point of bottoming out on the threads and there's some age cracks in the bushings, they were the original spring hats and hardware. Compared to the bushings I took out the new ones had a nice improvement on how the truck feels on small bumps.
  10. Jun 12, 2024 at 6:40 PM
    CoachMuddy
    Thanks. I was wondering if I just needed to replace the mount kit. I assembled the strut according to the directions, but I don't remember what all came out with the old struts and that's all in the trash.
    I'm not familiar with KYB, but since it can be here tomorrow and I'm leaving for Port Aransas on Saturday I'll give it a shot.
    Thanks again.
    ridefreak likes this.
  11. Jun 12, 2024 at 6:40 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
