Bilstein 5100 install cost??
Discussion in 'Suspension' started by Tacoman1234, Mar 24, 2015.
  1. Mar 24, 2015 at 7:45 PM
    Tacoman1234
    Tacoman1234 [OP] Member
    Adam
    Tennessee
    Silver 08 Tacoma 4x4 access cab
    Aries black bull bar
    I just ordered some front Bilstein 5100s to level my 2008 tacoma and I was wondering how much I should be looking at to have them installed? I don't want to end up paying way more than I should be.
  2. Mar 24, 2015 at 8:05 PM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    Free if you do your own work.
  3. Mar 24, 2015 at 8:08 PM
    mistermanny
    mistermanny Well-Known Member
    Jalisco, Mexico
    05 AC 4x4 2.7 5spd
    OME 883/Nitros
  4. Mar 24, 2015 at 8:14 PM
    Taco Libre
    Taco Libre Well-Known Member
    JohnnyHildo
    Saskatoon, SK
    2008 Black 4x4 Access-Cab TRD OffRoad
    Rear TSB, 5100s @ 0, Toytec 3" lift, Total Chaos UCAs
    hells ya! if you have/can borrow a floor jack, torque wrench and some simple hand tools changing out shocks is a breeze.
  5. Mar 24, 2015 at 8:25 PM
    Hartford
    Hartford Well-Known Member
    Maine
    2011 Acc Cab 5spd
    It really isn't bad to do it yourself. Just nuts and bolts. Take half a day on the weekend and go for it. If you do it yourself spray all the nuts you will be taking off with something like PB Blaster, maybe do that even if you take it to a shop. Might not hurt to take a wire brush to the threads before you start backing thing off, especially if you are reusing anything.
  6. Mar 24, 2015 at 8:28 PM
    bootboiler
    bootboiler Well-Known Member
    Scott
    Santa Cruz
    Camberg UCA's, locking tailgate, hid driving lights, B 5100's, OME HD Leafs, bud built plates, Relentless rear bumper, sliders with kick, breathers on pumpkins, satochi grill, bed lights, JVC 730BT Head Unit, Finch Four Wheel Camper FWC, 1Up bike rack, 265/75 16 tires
    If your getting new tires too, I suggest you have the alignment, install, and tires all done at once... I was charged 1 hour of labor with the alignment.
  7. Mar 25, 2015 at 6:11 AM
    Tacoman1234
    Adam
    Tennessee
    Will I need a spring compresser?
  8. Mar 25, 2015 at 6:15 AM
    itzyoboipaul
    itzyoboipaul Well-Known Member
    Paul
    PFville, TX
    2020 TRD OR Cement
  9. Mar 25, 2015 at 6:24 AM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    to do it properly yes, however there are people who use the weight of the truck to compress the spring. I would not try that but I am not as mechanically inclined as some.... okay, as most.
  10. Mar 25, 2015 at 12:25 PM
    chowwwww
    chowwwww Well-Known Member
    Orange County
    03 Doublecab 4x4
    Billys 5100/Eibach and Wheelers Progressive 1.5 AAL with overload in
    Or you can just take it off then bring it to a local shop and see if they will swap out the coils for you for $10-20. Its really quick with a wall mount spring compressor. If not rent a free one from local auto shop. just make sure you know what you are doing.
  11. Mar 26, 2015 at 12:10 PM
    mistermanny
    Jalisco, Mexico
    05 AC 4x4 2.7 5spd
    OME 883/Nitros
    Local shops around here charge more then $20.
    At least I'd like to think I saved more then that...by performing the install myself :D
  12. Mar 26, 2015 at 12:13 PM
    John taco
    John taco Well-Known Member
    JT - Johnny
    King of Prussia PA
    You can rent the spring compressor from either autozone or advance auto parts for free.
    Well pay the deposit then use the tool then return it and get full refund.
    Fun fun good luck
  13. Mar 26, 2015 at 12:30 PM
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    this thing scared me and my buddy.....
  14. Mar 26, 2015 at 1:51 PM
    chowwwww
    Orange County
    03 Doublecab 4x4
    Yea, it was just a guess on cost. I didnt do it that way. I rented a spring compressor. But I read that a lot of members just pull the entire strut off and bring them to suspension shop and they would swap the coil for them for about $10-20.
  15. Mar 26, 2015 at 1:55 PM
    millertime89
    millertime89 Flatlander
    Erik
    Saskatchewan
    06 TRD Sport DCLB 4x4
    Yes sir
    If you don't do it yourself, stay as far away from a dealer as you can. Toyota would be more then happy charging $100 an hour for easy work, they'll just take their sweet time :D
  16. Mar 26, 2015 at 5:46 PM
    hyper15125
    hyper15125 Headlight Retrofitting Hobbyist Vendor
    NJ (609)
    I just started mine today, 5100's @ 1.75 with stock springs and the 1/4 ToyTec spacer (DRIVERS SIDE ONLY) to stop the drivers side lean (Taco Lean). I only did the driver's side so far, have to finish tomorrow. I used this video below. Pretty easy. I would make sure you have at least two floor jacks, two jack stands, and two wooden 4x4's to add to the jacks to increase the lift height.
    https://www.youtube.com/watch?v=vkVLBOnAifc#action=share
    1.75 leveled the truck, however it DID NOT look like it visually. The wheel wells measured 3/4 higher at the rear but the truck appeared nose high. I had to install one inch blocks, now it looks perfect. the I have 2013 DCLB Sport 4x4 with the 4 leaf pack.
    Call some friends over to help, you can do it.
    Make sure you mark your alignment cams so you can set them back to drive to the alignment shop.
    Good luck!
  17. Mar 26, 2015 at 7:13 PM
    TacoDeLaPlaya
    TacoDeLaPlaya Total Automotive Performance Sleeper Cell
    Bobby
    Del Mar, CA
    06 Silver Access cab
    Custom sotoshi deep dish grill 6112 front 5100 rear Leer 100xl
    Did you feel like the truck was gonna lift off the jack stands instead of compressing the spring? Shouldn't happen with stock springs but with other heavy weight ones it may.
    Had it happen with a civic and it was sketchy. Have to press down on the car or put some sand or salt bags over the fender...
    Still gonna try it that way myself lol.
  18. Mar 26, 2015 at 7:47 PM
    mistermanny
    Jalisco, Mexico
    05 AC 4x4 2.7 5spd
    OME 883/Nitros
    I did mine myself, and in hindsight I would have lifted only one side at a time.
    This way you always have 3 wheels on the ground, which is more secure.
    I also performed a swap utilizing a spring compressors and felt more comfortable using the vehicle as a compressor :)
  19. Mar 26, 2015 at 7:59 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    It's not bad at all just give yourself plenty of time and enjoy the learning process. Do your homework before you start. This site is full of good info. Make sure you have an impact, torque wrench, spring compressor, jack, jack stands, sockets and wrenches. It was fun for me.
  20. Mar 26, 2015 at 8:05 PM
    thelivestone
    thelivestone Well-Known Member
    paul
    Cape Canaveral, FL
    2017 Crewmax
    stock for now
    300 bucks is what i paid. 4 shocks, add a leaf and coils. If you not mechanically savy, then let a trusted offroad shop do it. That way if something goes wrong, then they fix it and they have all the tools.
