Bilstein 5100 install question
Discussion in '1st Gen. Tacomas (1995-2004)' started by JTacoma, Sep 14, 2011.
  1. Sep 14, 2011 at 7:45 PM
    JTacoma
    JTacoma [OP] Well-Known Member
    Washington
    1995.5 2.7 4X4 5 speed
    Bilstein 5100, 31x10.5 Michelin LTX AT2
    I need to replace my worn out shocks and I am thinking about Bilstein 5100s from Downsouth Motorsports. The site says that the shocks are made to be used with an AAL and may require modification to the compression bump stop on chassis if leaving the rear suspension stock. What modifications are needed? I don't want to lift my truck right now. Will the 5100s fit my stock suspension without much modification?
    Thanks
  2. Sep 14, 2011 at 7:49 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    I'm pretty sure those will fit with no modification at all. Havent heard of anyone having any problems with them fitting stock.
    If anything, give DSM a call. Sonny and Marco have always helped TW members, and even offer a TW discount if you end up buying the 5100's from them. :thumbsup:
  3. Sep 14, 2011 at 8:57 PM
    JTacoma
    Washington
    Or should I just go with the 5125 in the back and the 5100 up front? If so which 5125s?
  4. Sep 14, 2011 at 9:49 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    The RCD billie 5100s are designed for some lift. Most likely they are talking about extending the bumpstops so you dont over compress the shocks. Over compressing (the compressed length being the limiting factor during articulation) will damage them.
    I would suggest asking Mario or Sonny at DSM this question.
  5. Sep 15, 2011 at 12:06 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    yea you only need 5125s for the extended travel for lifted applications.
