Bilstein 5100 Install Question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by albleezy89, Feb 22, 2022.
  1. Feb 22, 2022 at 12:12 PM
    albleezy89
    albleezy89 [OP] Member
    Albert
    Hello,
    I'm Installing new wheels and tires for my truck (Method 703 Wheels & BFG K02 285/70R/17). I am going to Install Bilseting 5100's all around with new Icon Delta UCA. My goal is to level out the truck and make room for the new tires. Do I need to replace the springs as well or keep it stock?
  2. Feb 22, 2022 at 12:15 PM
    tcjacado
    tcjacado Well-Known Member
    You can keep the stock springs and set the pearch on the second notch/ring to level the truck front to rear. Unless you plan on putting extra weight on the front.... steel bumper, winch or just want more lift.
    albleezy89[OP] and tonered like this.
  3. Feb 22, 2022 at 12:20 PM
    albleezy89
    Albert
    I plan on keeping stock for while. I do want to add a new skid plate in the near future. I do want to add steel bumpers all around but that's a year or two down the road. I'll probably put a new suspension with new springs, and leaf springs at that point.
  4. Feb 22, 2022 at 12:21 PM
    tcjacado
    The bilstein are a good starter kit, without breaking the bank. :thumbsup:
  5. Feb 22, 2022 at 12:41 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Be prepared to cut, chop, and hammer to fit those 285's. Not saying you are going to for sure, but most have to do so.
  6. Feb 22, 2022 at 12:46 PM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    You can and might want to keep the stock springs. They have a spring rate of 700 lbs.
  7. Feb 22, 2022 at 12:55 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Keep your factory springs so you don't loose the lifetime warranty from Bilstein.
    Siltaco56 and JJ Diablo like this.
  8. Feb 22, 2022 at 1:16 PM
    JJ Diablo
    JJ Diablo Well-known member.
    JJ.
    CT
    2021 Cement TRD Sport Premium
    BOSS HTX Snowplow, Bilstein 5100s, Vled reverse light kit, Vled interior lighting, FitCamX dashcam, Timbren SES
    This too.
    VaToy[QUOTED] likes this.
  9. Feb 22, 2022 at 2:25 PM
    Rivermaniac
    Rivermaniac Well-Known Member
    Question , are sport and or springs the same ?
