Bilstein 5100 lifespan?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Logans2001, Jan 19, 2020.
  1. Jan 19, 2020 at 10:41 PM
    Logans2001
    Logans2001 [OP] What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    I’ve had the 5100s for 4 years now and I’ve had this ANNOYING crunch/creak sound whenever I go over speed bumps or just brake in general. Basically whenever the front suspension engages. I’ll mostly hear it just driving around like in a parking lot. Also cracks when turning.
    Should I suspect my shocks? Or could this probably be something else? I’m at 260k miles.
  2. Jan 19, 2020 at 10:45 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Leaf springs; what kind are you running? How old and what kind of leaf spring and shackle bushings do you have?
  3. Jan 19, 2020 at 11:28 PM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    As far as I know they’re the original
  4. Jan 19, 2020 at 11:46 PM
    UnderFire
    UnderFire Well-Known Member
    Shocks, balljoints, control arm bushings, leaf spring bushings, coil spring isolators, coil top hats, sway bar bushings. Really anything that moves could be making noise. I'd start by spraying things down with lube to see if it stops when you do something, but a lot of these things likely need attention at 260k anyways.
    whatstcp likes this.
  5. Jan 19, 2020 at 11:51 PM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    Ya I’m starting to assume that I won’t be able to narrow it down to a specific part but more that I’ll end up dumping my tax return into it to replace multiple things instead. Can’t wait! Lol
    CS_AR likes this.
  6. Jan 20, 2020 at 6:10 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    It is so easy to throw a bunch of money away on parts when you are chasing suspension noises.
    I was in this situation once and found that using a 6-channel "wired" chassis ear let me narrow down a noise that turned out to be caused by an Energy Suspension poly sway bar bushings. I replaced some good struts thinking they were noisy then the chassis ear revealed a creaking poly bushing.
    The wireless versions are handy. I bought a basic wired version for approximately $100. It would be great if parts stores would rent chassis ears.
    https://www.walmart.com/ip/Steelman...-6-Channel-Chassis-Ear-Listening-Kit/25927694
    https://youtu.be/CK7sbqJ1OxQ
  7. Jan 20, 2020 at 7:07 AM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    Wow I never knew these existed thank you!
