bilstein 5100 lift; are springs needed?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTuesday1, Aug 30, 2020.
  1. Aug 30, 2020 at 11:33 AM
    TacoTuesday1
    TacoTuesday1 [OP] Well-Known Member
    FL
    might be a dumb question
    am still researching and seeing lots of different opinions
    are springs needed to get a few inches of lift with 5100's?
    Or is the shock alone enough?
    It definitely is a price difference. Because if 5100's are ~$300,
    then adding front coils and rear AAL or leafpack makes it like $700+
    I see Toytec offers all 3. Either just 5100's, 5100 with spring and AAL, or more.
  2. Aug 30, 2020 at 11:41 AM
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    It can be done without springs, but it will be stiff as hell. Ask me how I know...
    If on a budget, just shocks and an aal will get you by.
    Alexely999 and Rob MacRuger like this.
  3. Aug 30, 2020 at 12:27 PM
    TacoTuesday1
    FL
    Ah shit.
    co-worker lifted his 4runner on 5100's and said as long as you don't max out the adjustment, it can give lift but still decent ride.
    I heard only at maxed out setting, does it put pre-load on the shock and compromise ride quality.
    Seller was kind enough to throw in a 13120 Pro-Comp AAL but it's small and ToyTec says the only way to retain rear ride quality is with a long AAL, not short.
    Read a few posts on here where people said a short AAL (although cheap) ruined their ride quality and they regretted not getting a whole OME Dakar leaf pack.
    In which case it's sounding to me like the way to do this is Dakar leaf pack (rear) and some kind of springs up front, whether they be from ToyTec, OME, etc
    was just hoping it's possible to get a few inches with 5100's alone and no springs
  4. Aug 30, 2020 at 12:46 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    if you are comfortable working on your car, use the stock springs in the front and put them on the highest setting and see how you like it.
    Then if you are not happy, take the spring and put it on a lower perch.
    I did this on my 6112 springs. had to play with the spring height till i found what i liked. takes about 20 min to readjust the height setting once you know what you are doing.
  5. Aug 30, 2020 at 12:55 PM
    ImMrCrash
    ImMrCrash Intermittent Error
    Utah
    07 DCSB ᴛʀᴅ ᴏʀ 4x4
    Bilstein 5100’s Dakar CS047R Supreme Suspension U-Bolt flip kit Sumo Springs Blue ADV Fiberglass Fenders 1st Gen Snorkel DV8 Apex Plate Bumper X-Bull 13k Winch KC HiLiTES 6x9 Trail-Gear Sliders 4x Innovations LCA Skids Spidertrax 1.25” Eagle Alloy 16x8 4” BS Fierce Attitude M/T 315/75R16 Bearcat 980SSB CB
    On 5100’s top notch and stock 2007 off-road springs I thought it was stiff but absolutely acceptable and bearable. I also had a small spacer on each side which net me 2.8in lift.
    Now I have a plate bumper and winch on the front, sitting at 2.5in of lift and it did soften up.
  6. Aug 30, 2020 at 1:04 PM
    TacoTuesday1
    FL
    Never did it but I'll learn. Not sure yet if the perch notch can be adjusted with spring still in vehicle (wheel off) or if I have to yank the strut out to compress the spring and re-adjust it.
    Already measured the FTG (Fender To Ground) heights and the truck seems to be up to 3" lower in front, and 0.7" lower on the left side "infamous Taco lean" possibly due to gas tank location.
    I already threw some 4600's in there and ride improved vs the stock pencil-thin "TRD" shocks, but it just still has the ugly ride height imo
    I always wondered how much OR springs help, because they're said to be progressive (soft at first) vs Sport springs being linear for car-like street handling (to an extent). OR springs are supposed to perform better off road due to the softness at first helping soak up small bumps at the cost of some body roll
  7. Aug 30, 2020 at 4:28 PM
    taco912
    taco912 Well-Known Member
    North of the Bridge
    2006 AC 4.0 AT 4x4 SR5 TRD OR
    I have been running 5100's on the 3rd perch with stock OR springs for 20K miles. Ride has always seemed normal. While I was just rebuilding the front end, all rubber parts, UCA, LCA, inner/outer rods, drop links, I thought what the heck I'll move the perch up to the 4th ring.
    I have steadily stiffened up the rear which was showing the weakness in the 145K original front end parts and thinking stiffer would be fine in the front while rebuilding. While the ride was noticeably stiffer, complemented the rear and all was good, the increased lift was not ok. The 4th perch leveled the front and rear with my set-up but with ANY load I would have bro lean = totally unacceptable. It seemed as if the 3/4" perch change raised the front about 1 1/2". I don't know if this is in keeping with others experience.
    So I lowered back down to the 3rd perch and with the new totally rebuilt front end, the front was plenty stiff and solid going down the road in keeping with the firmness of the rear.
  8. Aug 30, 2020 at 11:48 PM
    TacoTuesday1
    FL
    getting warmer
    OME 884 supposedly 2" front lift, not sure if that levels it with TSB rear leafs
    but OME recommends 885 for the truck, which may be 2.5" front lift, though they also might recommend their rear Dakar leaf pack at the same time. So they probably want the whole kit (front and rear) done at the same time. Not just front alone.
    886 = heavier spring rate for armor, probably 620lb vs 590lb, and I'm not sure what 885X is though I've seen it done.
    Supposedly 885 runs the risk of needing adjustable UCA for alignments
    weird thing is I think OME says 884 is for lighter Tacoma's like access cab, etc.
    and suggests 885 claiming that double cab is heavier towards the front (might be)
    maybe 884 is a "hack" to start cheaper,
    keep the rear stock and lift the front 2" to level it
    OME 884 + Bilstein 5100 = basically about $300 to lift and level the front, hopefully
    versus the whole kit including Dakar leafpack, turns that into $1k+...
  9. Aug 31, 2020 at 2:36 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Stock front springs work well with the 5100s in my opinion after 5 years I have no complaints on ride quality. Have full set of steel skids underneath and a shell so added weight.
    Had to get the front up after adding rear ARB OME Dakars for loads/towing. Unloaded my Tacoma rear is slightly higher but loaded level as I wanted running stock size 265/70R16s. If you go up a few inches think about longer brake hoses (stainless) if you flex it or you may rip stock ones so more a safety thing to me.
    You can do whatever your budget can afford on the Tacoma.
  10. Aug 31, 2020 at 7:49 AM
    GeorgiaAsh
    GeorgiaAsh Well-Known Member
    Acworth, Georgia
    2019 Silver SR5 DCSB
    Anyone running 5100’s in the rear with AAL? I see they’re only rated for 1 inch, I’m not sure if I should get the 5125’s or not
  11. Sep 1, 2020 at 11:55 AM
    Greenedmc
    Greenedmc Well-Known Member
    Daniel
    Elizabethton TN
    2014 Silver Tacoma Trd Off Road Access cab
    I run the deaver single leaf from headstrong with my 5100s.. no issues yet lol
  12. Sep 1, 2020 at 11:56 AM
    GeorgiaAsh
    Acworth, Georgia
    Are you lifted more than an inch?
  13. Sep 1, 2020 at 12:01 PM
    Greenedmc
    Daniel
    Elizabethton TN
    The Deavers advertise 1.5 to 2 inches.. I never actually measured before and after.
  14. Sep 1, 2020 at 12:39 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Rock my stock TRD OR coils on the 1.75in setting and love the ride, A lil firmer than stock but that was much welcomed over the boat like ride from the factory.
    18tacotues and vtown like this.
  15. Sep 1, 2020 at 12:42 PM
    GeorgiaAsh
    Acworth, Georgia
    Either way, its out of spec lol any off-roading? how long have they been on?
  16. Sep 1, 2020 at 3:01 PM
    Greenedmc
    Daniel
    Elizabethton TN
    Close to a year now.. and just some fire tower roads and forest service roads... so nothing crazy.
  17. Sep 1, 2020 at 4:13 PM
    GeorgiaAsh
    Acworth, Georgia
    May the odds continue to be in your favor
  18. Sep 1, 2020 at 7:41 PM
    TacoTuesday1
    FL
    ordered 883's to start for now, "leveling spring" to add 1.6" up front to level it. Because I measured fender to ground heights at all 4 corners and found it's lower by about 1.5-1.6", which OME 883 would level out. Plus a 1/4 driver spacer to address crooked Taco lean.
    Maybe a spacer at rear left leaf spring can do that in the back as well.
    Held off on other stuff for now, might do it later. Given the parts involved, price, etc., I'd want to take more time to really figure out a good game plan before making a potentially wrong choice.
    Any higher than that adds cost. AAL appears to be $100/side, not to mention $500 for Dakar leaf pack. Although higher OME springs (884, 885, 886, and whatever "X" is such as in "885X" cost the same as 883, the supporting mods do not. For example if requiring new UCA's = more cost.
    will set the 5100's to 0 with 883's
  19. Sep 1, 2020 at 10:31 PM
    patos tacoma
    patos tacoma Well-Known Member
    Just did mine......
    Kept factory springs, Bilstein struts on 3rd ring.....up 2”......and truck leveled.
    And Bilstein shocks with no rear lift.
    Only add on was new strut mounts each side......
    Good ride, no bounces, can drive a little faster.
