Bilstein 5100 Lift Questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2005Taco4X4, Jul 7, 2012.
  1. Jul 7, 2012 at 7:53 PM
    2005Taco4X4
    2005Taco4X4 [OP] Well-Known Member
    North Carolina
    05 Silver Tacoma 4x4 W/ 6 Speed
    All blacked out, Mbrp Off Road Exhaust, K&N intake Fog Lights Mod, Kenwood Headunit, Rockford Fosgate Speakers, 10 inch Kicker Comp Subwoofer, Bilstein 5100's, OME 884's with toytec spacers -3.5" 2 inch aal and 2 inch block 255/85r16 BFG KM2's Brush Guard with 100W lights, Blue LEDs inside
    I apologize for starting a new thread on this subject but i have some questions regarding my lift. I recently purchased four Bilstein 5100's with a 1.5 inch Toytec AAL that i have yet to install.
    My plan for the lift on my 2005 4x4 Access Cab is the 5100's set at 1.75 with stock SR5 coils, two 1/4 lean spacers one on each front shock to give me a full 2 inches of lift up front, and then a Toytec 1.5 AAL in the rear.
    Does anyone have a lift similar to this? If so could you put up a picture and did you have any problems getting it aligned? Also, is it a good idea to use the two 1/4 lean spacers or should i just leave the 5100's alone set at 1.75? Thanks in advance. :)
  2. Jul 7, 2012 at 8:11 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    At 2 inches you should still be able to get it within alignment specs. Honestly I'd save the money on the lean spacers (not much, I know) and save up for some Eibachs to go on those 5100's.
  3. Jul 7, 2012 at 8:17 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
  4. Jul 7, 2012 at 9:26 PM
    2005Taco4X4
    North Carolina
    If i were to get the Eibachs would i still be able to get it within the alignment specs if i jacked the 5100's up to .85?
  5. Jul 7, 2012 at 9:27 PM
    2005Taco4X4
    North Carolina
  6. Jul 7, 2012 at 9:59 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    The ride is fine but the alignment sucks on mine. I'm actually going to knock mine down to 1.75 because I just don't have the money for UCA's right now. I have zero caster so it wanders and camber at .7 which is going to kill my tires. So the truck will just have some rake back in it. No big deal.
  7. Jul 8, 2012 at 4:51 AM
    moondeath
    Pa, Gardners
    It wanders a bit because the caster is out.
    Has a firmer feeling set that high.
  8. Jul 8, 2012 at 5:23 AM
    Maticuno
    2011 Suburban 2500
    Eibachs with 5100s at .85 will be a beautiful ride and you should still be able to get it aligned without needing new UCA's.
  9. Jul 8, 2012 at 9:36 AM
    2005Taco4X4
    North Carolina
    Thanks, one more thing. How much lift would i get if i purchased the Eibachs and set them at .85?
  10. Jul 8, 2012 at 10:24 AM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    I believe that's right about 3".
  11. Jul 8, 2012 at 12:52 PM
    Maticuno
    2011 Suburban 2500
    If that's accurate then I was wrong and you'll probably need new UCA's to keep it in alignment. I have the fully adjustable spring perch on mine and just have it set to give me 2".
