Bilstein 5100 lift. When to replace UCA's?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CAS, Apr 24, 2015.
  1. Apr 24, 2015 at 5:47 PM
    CAS
    CAS [OP] Member
    09 double cab
    Installing a Bilstein 5100 kit on my 09 double cab. I'm setting the shocks at 2.5" and adding a 1" block in the rear. No top plate spacers. At what point do I need to entertain replacing my UCA's? What are the downsides of leaving the stock ones on it? Benefits of tubular replacements? Thanks in advance.
  2. Apr 24, 2015 at 5:55 PM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    You should be fine. If you can get the alignment in spec no need for new ones and as long as they clear whatever you're running for wheels/tires.
    Once you hit 3" they are usually needed to obtain proper alignment.
  3. Apr 24, 2015 at 5:58 PM
    CAS
    CAS [OP] Member
    09 double cab
    After a little research, was thinking Toyo AT II's, 265/75 R16. Wanted to go as large as possible without causing issues or cutting.
  4. Apr 24, 2015 at 6:02 PM
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    as soon as you are unhappy with the performance of your vehicle's alignment
