Bilstein 5100 + OME 881 Question
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacoBlitz, Nov 1, 2010.
  1. Nov 30, 2010 at 6:38 PM
    #41
    NegroTundra
    NegroTundra Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    He didnt say OME's @ 2.5". He said billys set at 2.5" to OME's..didnt specify setting with OME's so I assumed zero. Anyway, I agree with your second sentence.
  2. Dec 2, 2010 at 2:59 AM
    #42
    Wreckless_71
    Wreckless_71 WRECKLESS for Life...
    Justin
    Pullman, WA.
    98 ext cab Tacoma
    3" Lift via OME 881's, Bilstein 5100's, Dakar OME 3" leaf packs, MBRP custom exhaust, HID headlights, CB, Canopy, aluminum wheels, upgraded sound system, full set of studded snow tires and wheels, auxilary lighting, more to come.
    I have 881's and the billies set at the second setting. Love it.
    98_3RZ_NIC likes this.
  3. Dec 2, 2010 at 11:50 PM
    #43
    99tacosupreme
    99tacosupreme Well-Known Member
    Kyle
    Southern California
    1999 Black V6 PreRunner TRD
    Pioneer Headunit, Infinity Kappa 6.5" speakers, Alpine Type R sub with Alpine M500 amp, 15% Tint up front 5% in the back, Deckplate mod, Debadged, Bilstien 5100s, Wheelers 1.5"AAL, DDM 55w 6k Lights
    Yea I was definatley implying the OME coils on the bilstiens set at 0". The ride is rough as it is. I would never get a lift spring and then preload it on the strut. I was Just wondering if the 881 coils on the bilsteins set at 0" where would give better ride quality then TRD coils preloaded at 2.5 inches? and by better I mean that they are worth every penny.
  4. Dec 3, 2010 at 4:30 PM
    #44
    NegroTundra
    Land of Enchantment
    Big time
  5. Dec 3, 2010 at 6:31 PM
    #45
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    did you need the dif drop kit for the lift the 881s provided?
    Is the AAL you have the one from wheelers off-road?
  6. Dec 3, 2010 at 8:01 PM
    #46
    NegroTundra
    Land of Enchantment
    No need for diff drop
  7. Dec 3, 2010 at 9:04 PM
    #47
    99tacosupreme
    Kyle
    Southern California
    NegroTundra, did you have the stock coils on the 5100s before you switched? also did you get a full 2.5" inches of lift with the new coils?
  8. Dec 3, 2010 at 9:21 PM
    #48
    RideFast
    RideFast on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
    if u change go with 5100's and 881's will you need to get some new UCA's?
  9. Dec 6, 2010 at 6:24 AM
    #49
    NegroTundra
    Land of Enchantment
    Nope, I had a crappy fabtech coilover set. I got 2.5 initially, but after 100 miles or so they are at 2.0" Perfect in my opinion
  10. Dec 6, 2010 at 6:25 AM
    #50
    NegroTundra
    Land of Enchantment
    Not necessary but if you have the extra $$$ then it's a nice set up.
  11. Dec 6, 2010 at 7:19 AM
    #51
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    I guess its your own call but I looked at the angle of the CV's before and after the D/D kit and there was a definate improvement of the angle of the boots and for only $10, and it save me from replaceing a boot as they were rubbing before the kit, it was an easy install. My $0.02
  12. Dec 6, 2010 at 9:16 AM
    #52
    NegroTundra
    Land of Enchantment
    IMO, the diff drop is worthless. I did it on my 03 Tundra and it doesnt really drop the diff. It only drops the front end of the diff, which in total has the effect of merely rotating the diff, front part down.. The rear mount is fixed, you can't drop that part. I had a 3" lift on the Tundra and ended up removing the diff drop because the front diff started producing a pulse-like vibration and associated noise. I suppose the diff did not like being roatated like that. Furthermore, I put about 60k on that Tundra with the lift and no diff drop and my cv's never batted an eye, and I'm not easy on my rigs when it comes to offroad. I studied the front diff on the Taco and it is the same as design the Tundra. Just my $0.02
  13. Dec 6, 2010 at 9:18 AM
    #53
    98tacoma27
    Ben
    Not Beech Creek
    Well said. X23476543 on the DD being worthless.
  14. Dec 17, 2010 at 6:54 AM
    #54
    GOLFMAN845
    GOLFMAN845 Well-Known Member
    Nic
    2002 Black Double Cab 4x4 TRD
    Leather Interior, Hunter Bull Bar with 4" KC Driving Lights, Black Pro Comp 16" Alloy Wheels, Yokohama ATS Tires, OME 881 Coils with Bilstein 5100's set at 1", Rear Dakar Leaf Springs with Bilstein 5125's, Removed Rear Decals on Bed
    I think I saw at least one person with this set up. I just did mine like this. OME 881 Coils with the 5100's at middle setting (1"), I also put the Dakar rear leaf springs in with 2.25". Truck looks great! Ride seems better than my old worn out suspension. But my question to those who have this front set up, at about 30 mph there is a funny noise (could be vibration), I guess you would call it. But it comes and goes only lasting a second or two at a time. Do you think it is anything to worry about? This is my first build, and this is a new noise and I do not want to tear the truck up. Any thoughts on this?
    Thanks,
    Nic
  15. Dec 17, 2010 at 7:46 AM
    #55
    NegroTundra
    Land of Enchantment
    How much lift did you get with the OME's and billys @ 1"? If its >3", it's probably a bit too much. That noise probably is something to worry about. Switch it into 4wd and see if it still does it. If it goes away, your front diff isn't happy. Start with taking out the diff drop. If that doesnt help, I'd drop the coils down to the "stock" notch. The springs will settle so give it some time before you take this measure. Lastly, send pics of your cv's so we can help more. Good luck.
    Edit: I could also be your driveline...you may need to drop the carrier bearing. Do the test above and let us know what happens.
  16. Dec 17, 2010 at 12:45 PM
    #56
    GOLFMAN845
    Nic
    Okay I did all this on Tuesday night. I think I got about 3" to 3.25" of lift from wear the old sagging sagging springs and shocks were. When I measure before the drivers side was about 34.75 or 35" to bottom of fender flare, which I was an inch lower than stock dc like mine that sits in my work lot, now it is about 37.75 to 38 on drivers side. Passenger side is a little higher right now. From what I understand the coils will give me Approx. 1.75 inches of lift and the 5100's at the middle setting will give another inch, after everything settles. Does this sound correct. That is what my sources at TRDparts4u and DSM advised me. I am work right now so I will get some pictures up here as soon as I can in the next day or so.
    I am not familar with a carrier bearing drop. You know of any write ups on that?
    Thanks again for the help!
    Nic
  17. Dec 17, 2010 at 2:51 PM
    #57
    NegroTundra
    Land of Enchantment
    What about the 4wd test.
  18. Dec 17, 2010 at 2:56 PM
    #58
    GOLFMAN845
    Nic
    I've had it in 4wd but haven't had it up to 30mph. It was slower speeds, mostly in parking lots with the ice here. Main roads have been pretty clear. Is it okay to run it in 4wd at 30 mph on dry pavement?
  19. Dec 17, 2010 at 4:06 PM
    #59
    Snowman
    Snowman I have a problem for your solutionÂ…
    Craig
    Somewhere in Canada
    Check out my build
    Just drive straight. Turning is where any binding would occur.
    btw, what length 5125s did you put with the dakars?
  20. Dec 17, 2010 at 7:23 PM
    #60
    GOLFMAN845
    Nic
    Thanks I will try the 4wd in the morning on the way to work.
    Not sure what length the 5125's I gave the info to Down South Motorsports and they fitted it up, based on the amount of lift from the leafs. I talked to Marco, and he looked it all up.
    I am hoping that the noise is from the alignment. I know it was out just a little bit out, when I had it in for the tire rotation and balance in November they said it was but said since I was going to do new struts and shocks to wait. So I will see next week when I take it in.
