Bilstein 5100/ OME coil question
Discussion in 'Suspension' started by HusqyRider, Aug 25, 2010.
  1. Aug 25, 2010 at 9:35 AM
    HusqyRider
    HusqyRider [OP] Well-Known Member
    Adam
    La Mirada, CA
    01 Tacoma Prerunner SR5
    Bilsteins, HD Bakflip G2, Popnlock
    I have an 01 double cab 2wd prerunner that I want to level or bump an inch or so in the front. I have been told that 5100s with 880 coils will accomplish this. Is this correct? Anyone with 5100s and 880/881s that can chime in? How's the ride? I'll do some offroading, but nothing insane.
    TIA
  2. Aug 25, 2010 at 9:41 AM
    98tacoma27
    Ben
    Not Beech Creek
    The average lift from a 880 is 1.25-1.5"
    A 881 will bring around 1.75-2"
    You may want to stick with the OME90004 shock upfront as it is desinged to be used with the OME coils and will give you a "sportier" ride. Plus you may have to wait for the Billy's as they go on backorder at a regular basis.
  3. Aug 25, 2010 at 9:56 AM
    scocar
    scocar hypotenoper
    That sounds correct for "about an inch or so."
    I have an Xcab with 881s and Bilstein 5100s set on zero.
    This rides great. It is roughly a 2-inch lift, which leveled with the rear, which just got lifted 1.5.
    Note, however, that I have the 5100s set at zero lift.
    5100s were designed specifically to work with leveling (preloading) the stock progressive coils, which are a 375-lb rated spring.
    The OMEs are a non-progressive 500-lb spring. You really don't want to preload these for additional lift; it is the spring's height that provides the lift.
    So why did I use 5100s? I orignally thought I could just use the Billies to level, but realized I would need to max them out at the top setting, which would make the ride harsher. So I already had them in hand when I figured out I should just get new coils, too. The 5100s are a perfectly good shock in this application and work well set at zero lift with the 881s.
    Ideally, you could pair the OME Nitrocharger shocks with the 881s, beacause they are specifically designed for that application. I have no personal experience with that setup as a comparison, but it is popular. However, the Nitrochargers seem to be more expensive than 5100s. And, to further complicate things, front 5100s are increasingly difficult to get because demand is outstripping production.
    Back to your truck: the only difference between 880s and 881s is 10 mm of height. You have a 2wd DC...what engine? V6? The weight matters. Also, do you have any bullbar/winch stuff hanging off the front? This is a factor too. Dan at Wheeler's Offroad has a lot of experience advising folks on this. You may want to PM him or give him a call to discuss.
    Good luck. This was totally baffling to me until I did a ton of homework.
  4. Aug 25, 2010 at 10:00 AM
    HusqyRider
    Adam
    La Mirada, CA
    Thanks for the reply. I already have the coils and 5100s...i'm just having second thoughts. I've thought about returning all of it and just getting toytec or all-pro COs up front...or treturning the 5100 and getting OME fronts shocks to go with the coils...In any case, I want the best ride possible, and I find the stock setup too soft/bouncy...
  5. Aug 25, 2010 at 10:04 AM
    HusqyRider
    Adam
    La Mirada, CA
    it is a V6 btw, no other mods, but may get sliders in the future.
  6. Aug 25, 2010 at 10:04 AM
    HusqyRider
    Adam
    La Mirada, CA
    thanks scocar, that is quite helpful
  7. Aug 25, 2010 at 10:08 AM
    scocar
    scocar hypotenoper
    No prob.
    Yes, the stock ride was ridiculously bouncy and soft for me (at 101K miles). The new setup is solid, yet comfortable. Handling is vastly improved. I just finished about 600 miles of trans-Sierra roadtrip on all kinds of roads and speeds. I am VERY happy with the setup.
  8. Aug 25, 2010 at 10:27 AM
    ilove_taco_ma
    ilove_taco_ma Well-Known Member
    fresno, california
    95 tacoma 4wd LX
    nothing, all stock expect got a OE replacement air filter K&N.
    if i were you, i just keep it. it will be a hassle to do all shipping and calls back and forth. so far for the OME shocks, they are expensive. I cancel the OME struts so that i can use that extra $$$ for and bought the 5100 instead. money is tight nowadays
  9. Sep 1, 2010 at 12:20 AM
    HusqyRider
    Adam
    La Mirada, CA
    If I were to get a wheelers 5 leaf pack in the future, could I simply pop the billies to 1.25 (or 1) with the 880s and be level-ish with a decent ride?
    thanks for the feedback
  10. Sep 1, 2010 at 12:50 AM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    I run the ome 881's with a .5 spacer and factory tokico shocks. It gives me just under 2.8 inches of lift with my all pro bumper. Before I put the bumper on it rode a tad harsh, especially over speed bumps. I plan on adding a smittybuilt xrc8 winch and new factory shocks.
    With my toytec aal's and pro comp shocks in the rear, it sits perfectly level.
    I'm 200 lbs and can stand on the all pro bumper and it barely dips .5 so I think a 60 lb winch isn't going to hurt it any.
    Personally I think having 881's or 882's and billies up front is kinda a waste of money since your already getting the neccisary lift from the spring itself.
    I would go with the 881's and maybe a rancho 5000 shock.
  11. Sep 2, 2010 at 12:06 PM
    HusqyRider
    Adam
    La Mirada, CA
    Thanks for the input!
  12. Oct 8, 2010 at 2:39 PM
    YellowDog01
    YellowDog01 Well-Known Member
    04 4x4
    Anyone know if 882s are possible on top of my Bilstein 5100s? And how much lift would they give me?
  13. May 29, 2016 at 8:51 AM
    2002tacomaPDX
    2002tacomaPDX Active Member
    Southern California
    I am trying to get about a 1.5-2" lift and wondering which option is better in terms of ride quality. I want a soft, street-friendly ride. Nothing too harsh:
    1) OME 881 coils on STOCK Bilstein shocks.
    OR
    2) Stock Tacoma coils on Bilstein 5100 adjustable shocks set to 1.5"
    Anybody have experience with that?
