Bilstein 5100 on 01 taco
Discussion in 'Suspension' started by tacomaholic, Jan 24, 2013.
  1. Jan 24, 2013 at 7:40 PM
    tacomaholic
    tacomaholic [OP] Well-Known Member
    Ok. i have the ome coils which said they would give me 3 in lift and i did add a leaf in rear. Can i put the 5100s up front and set at like 2.5 or 3 and 5100 in back set at like 1 and just pull my add a leaf out so the truck will be level again?
  2. Jan 24, 2013 at 7:45 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Adding 5100's with the OME coils? Rear Bilsteins don't give you lift.
  3. Jan 24, 2013 at 7:50 PM
    tacomaholic
    yes up front and then take my add a leaf out the back so the back has no lift and put 5100 in the rear.
  4. Jan 24, 2013 at 7:52 PM
    tacomaholic
    And would i need stock u bolts again to be able to make it stock?
  5. Jan 24, 2013 at 7:56 PM
    scocar
    scocar Patron of the Farts
    No.
    You care trying to get 5.5? Don't go above 3 in front, or you will have issues, and start blowing CV boots.
    If you have OME coils, you don't want to use the height adjustment on the 5100s, because the spring perches are not designed for the much higher spring rate OMEs (~500 lb versus ~375 for stock OEM coils). Ridewise, you are better off pairing some OME shocks with those coils. You can add some trim packers to the OME shocks for a little more height if you must.
    In the rear, as Tim says, 5100s are not adjustable. Your choices, from worst to best, are block, AAL, or leaf pack. Figure that out, then get shocks of the correct height to match so they don't bottom or top out (and break) at full flex.
  6. Jan 24, 2013 at 8:01 PM
    sirsaechao
    Tim
    CA
    Yep you can't stack lifts. If you run the OME's with 5100's leave them at 0".
  7. Jan 25, 2013 at 8:55 AM
    tacomaholic
    my coils sagged bad from when they were new. so would i just need stock coils and the front shocks?
  8. Jan 25, 2013 at 9:41 AM
    sirsaechao
    Tim
    CA
    You can use your stock shocks but it'll yeild you 2.5" in lift so if you really want 3"...you can also look into the Eibach/ToyTec springs and 5100's at 0" or new OME springs with 5100's and top plate spacer.
