Bilstein 5100 pics
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RyanBelliston, Aug 27, 2011.
  1. Aug 27, 2011 at 3:28 PM
    RyanBelliston
    RyanBelliston [OP] Well-Known Member
    Diamond Bar
    2005 PreRunner
    Retrofit OEMs w/ 5000K bulbs HID 4300 Fogs Fog Light Mod LED Gauge Swap (Blue/Green/White needles) -Jerez 10'' Kenwood Subwoofer 1500W Planet Audio Amp Debadged Tinted Windows Mudflap delete AFE ProDry S intake Engage front LT 8inch Kings with 2x2 King bump stops. Strapped at 16 inches Engage 4-Link rear 16inch King coil overs strapped at 22 inches Custom Engage bumpers LED reverse lights LED license plate lights LED dome and map lights Flyzeye-Design (blue/white)
    Looking to get the Bilstein 5100 for 05 dblcab. Any of you guys have this setup? if so, let me see some pics?? Looking to see if its what I really want before buying everything.
  2. Aug 27, 2011 at 3:30 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    Do a search. Lots of people run 5100's, including myself.
  3. Aug 27, 2011 at 3:31 PM
    tacomarotto
    tacomarotto Tempus Fugit, Memento Mori
    Jon
    Jacksonville, FL
    2001 DC 4WD TRD 2022 Lexus GX460
  4. Aug 27, 2011 at 3:32 PM
    tacomarotto
    Jon
    Jacksonville, FL
    welcome to TW!
  5. Aug 27, 2011 at 6:25 PM
    Bolt79
    Bolt79 Well-Known Member
    White Springs, FL
    2022 Lunar Rock Trail Edition
    Screen ProTech kit, JDMCAR center console organizer, JDMCAR Center Console Armrest Cushion, Toyota door sill protectors, Black Toyota tailgate letter inserts
    Here's mine--5100's front and rear. Fronts set to 1.75 height:
  6. Aug 27, 2011 at 6:29 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    you got a prerunner, so I am going to ask what are you thinking of getting the lift for ie larger tires, clearance.
    If your looking for off-road performance I would suggest looking in to Camburg 4" lift spindles. By far the absolute best suspension mod on the market for a prerunner. 4" of lift, no preload on the coilovers, great ride and a reliable way to get some great lift!
  7. Aug 27, 2011 at 6:45 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You gotta search... 5100's are just shocks and struts, you can put them on and have no lift over stock, just an improved ride. How much lift do you want and how much are you looking to spend? What do you do with your truck? Asking for pics of Tacomas with 5100's is a very general request.
