Bilstein 5100 Questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by RubyTheRedTaco, Jul 3, 2020.
  1. Jul 3, 2020 at 7:30 AM
    RubyTheRedTaco
    RubyTheRedTaco [OP] Well-Known Member
    NH
    '03 Ext. Cab TRD Limited 4x4
    Trying to get rid of rust!
    Hey guys,
    I posted this in the "Bilstein 5100 Install" thread yesterday but didn't get any responses, maybe because the thread is old. If anybody could provide some help I'd really appreciate it.
    Sorry to revive an old thread and for the long post, but soon I'll be installing Bilstein 5100s with OME 881 coils along with all new washers and rubber bushings. I have a few questions:
    1. In the first photo, are the hardware components arranged in the correct order moving from bottom to top (washer, tophat with rubber isolator, 1/4" tophat spacer (for taco lean), rubber bushing, washer, nut)? Note the KYB aftermarket tophat does have the rubber bushing on its underside as shown in the second photo. This assembly would be for the driverside.
    2. I mock fit the 881 coils on the 5100s set at the lowest setting (third photo) and the shock is not centered in the coil as seen in the fourth photo. In order for the shock to be centered it seems as though the coil would almost have to move up on the left side? In the video from Youtube you can kind of see this and as I move the shock both the spring seat and the coil move up on the left side. Am I just being paranoid and will this not be a problem once the coil is compressed or is something very wrong here? Thanks guys
  2. Jul 3, 2020 at 11:53 AM
    Trev7
    Trev7 Well-Known Member
    Trevor
    Lehi, UT
    2001 2.7l prerunner Orange Xtra cab
    Icon 2.5 ext travel street valve, Icon 2.0 resi, rebuilt leaf springs, built right UCA's, single stage ppg Orange paint.
    Haven’t seen that kind of issue before... is it like that for both shocks and coils?
  3. Jul 3, 2020 at 2:12 PM
    RubyTheRedTaco
    NH
    Yeah it's like that for both shocks and coils. I tried interchanging them and it was like that (shock not centered) for both....
  4. Jul 3, 2020 at 4:41 PM
    cornbread_wy
    cornbread_wy Well-Known Member
    W
    San Rafael, CA
    98 xtracab 3.4l Sr5 4x4 - copper mica
    5100 w/ 881
    I think when you bolt on the top bushing it helps center the shock in the middle of the spring? 29BAB085-87E8-4A94-83FE-C6890DC28B11.jpg
    jammer and Rachelsdaddy like this.
  5. Jul 3, 2020 at 4:50 PM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    Tru dat
  6. Jul 3, 2020 at 7:47 PM
    RubyTheRedTaco
    NH
    Really? Well maybe I'll just have to give the assembly a go and see what happens, but I'm definitely scared that something could go wrong. @cornbread_wy is that a spring compressor you rented? I was planning on renting that same style one from O'reillys with the hopes it would work on the 881 coils
  7. Jul 3, 2020 at 8:39 PM
    cornbread_wy
    W
    San Rafael, CA
    5100 w/ 881
    yup - spring compressor from O’reillys is what I used.
  8. Jul 3, 2020 at 8:55 PM
    RubyTheRedTaco
    NH
    Ok cool, I'll take it slow and give her a go! Thanks
    cornbread_wy[QUOTED] likes this.
  9. Jul 3, 2020 at 9:06 PM
    taco03Trd
    taco03Trd 03 rig trd v6
    Carlos
    Riverside ca
    03 DC prerunner trd v6 2wd
    Ome 881 5100's jba's looking for more
    I have the same set up ill get u pictures tomorrow it if helps u .
  10. Jul 3, 2020 at 9:18 PM
    RubyTheRedTaco
    NH
    That would be great Carlos, thank you!
    taco03Trd[QUOTED] likes this.
  11. Jul 3, 2020 at 11:53 PM
    CNCist
    CNCist Active Member
    Tony
    Might just want to email OME or Bilstein and ask. When you do get full weight on it I dont think It will matter too much but when I installed mine on cheaper Eibachs they were not that far off.
    ETA: Maybe go to a local shop and ask to see a spring on the same spring base. Eliminate the OME spring variable then go from there. There's pictures of bilstein seats jumping the groove. I would not install them just yet.
  12. Jul 4, 2020 at 4:52 AM
    Rachelsdaddy
    Southern NH
    It’s most likely just the spring compressor causing you that issue. The spring isn’t getting equally squashed. You will be fine
  13. Jul 4, 2020 at 7:42 AM
    taco03Trd
    Carlos
    Riverside ca
    9DFAE42E-CB20-43AE-AF9C-B29F23B4601E.jpg Here you go driver side this were assemble by wheelers and they came mark driver an passenger . Lmk if u need more @RubyTheRedTaco pictsEFD2F913-D02D-48F9-BB53-43BCA345D34F.jpg 193957C9-DC28-4EF2-AC7D-82D67FBFB918.jpg
  14. Jul 4, 2020 at 8:10 AM
    RubyTheRedTaco
    NH
    Yeah that's probably a good idea. Unfortunately I didn't buy the shocks directly from Bilstein (got them on Ebay) but I did buy the coils from Wheeler's. But they should still be able to give some advice. Going to a local shop and asking about that would also be a good idea, hopefully a shop would allow me to do that. And right that's my biggest concern, is the seat jumping the groove/circlip since there's uneven pressure on it when I center the shock with my hands. It seems that there would be a ton of pressure on the right side and much less on the left.
    I haven't used a spring compressor on it yet, maybe that's all I need to do, I don't know haha. But I do know I don't want to loose any fingers.
    Thanks Carlos. I'm kind of wishing I bought everything from Wheeler's and had them assemble it. But I also like doing things myself and learning along the way
  15. Jul 4, 2020 at 8:17 AM
    taco03Trd
    Carlos
    Riverside ca
    No problem Ruby . I like also doing things my self but i was a good deal so i pull the trigger .
    Rachelsdaddy likes this.
