Bilstein 5100 rear question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 802hwl, Sep 9, 2017.
  1. Sep 9, 2017 at 5:40 AM
    802hwl
    802hwl [OP] Member
    Vermont
    2010 4x4 tacoma sr5 5speed 4-cyl
    I put 5100 ride height adjustable shocks on the front of my 2010 Tacoma a year or so ago. clip is in the middle position. The front now looks great, and despite some other opinions, I am confident that I did indeed feel a ride improvement over the OEM front susp.
    Now it appears that the rear sags lower that the front (again, clip in mid position).
    What do I need to do to raise the rear to level the truck?
  2. Sep 9, 2017 at 5:45 AM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    AAL (Add-A-Leaf), new leaf pack, blocks (not recommended by most here), or airbags are few options. All depends on your wants/needs.
  3. Sep 9, 2017 at 5:51 AM
    Fike
    Fike Well-Known Member
    2015 white Tacoma TRD Sport
    Not much so far
    Measure the front and rear height and compare. I just put the 5100s on a couple months ago. Set the front to 1.85" and it was perfectly level. After a couple of weeks the back had sagged and was a half inch lower. I didn't want to do AAL, and have the back up to high so I went with a 1" block. Very happy with the result
  4. Sep 9, 2017 at 8:55 AM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Progressive aal, or new leafpack.
    Oem packs are crap
  5. Sep 11, 2017 at 6:56 PM
    viking rexx
    viking rexx Well-Known Member
    jeff
    ct
    raceway blue dubl cab sb
    cap
    I fix that same problem with Tuff Country AAl.
  6. Sep 11, 2017 at 11:04 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Don't use air bags as a permanent lift. I got mine to level when towing a trailer and can confirm they will leak air over time. They are great for temp leveling, but not for permanent situation. I, too, added a one-inch block and it has worked for me. You will need longer u-bolts.
  7. Sep 12, 2017 at 12:17 AM
    nizzmont
    nizzmont Well-Known Member
    Brian
    S.E WA state
    2015 doublecab TRD sport
    in progress
    Progressive add a leaf or new spring packs
