Bilstein 5100"s ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fire Taco Fighter, Mar 2, 2012.
  1. Mar 2, 2012 at 6:30 AM
    Fire Taco Fighter
    Fire Taco Fighter [OP] Well-Known Member
    trd
    Hello all I got the Rear TSB done on my Tacoma and instead of a spacer I decided to go w/ the Bilstein 5100"s.
    Is $190 shipped a good price?
    Does anyone have a reccomendation on where to get them?
    Thanks
    Otto
  2. Mar 2, 2012 at 6:32 AM
    GuapOh
    GuapOh Well-Known Member
    Nor Cal
    2011 SR5 4x4 MT
    Skid Plate, Hood Protector, Wheel Locks, Snugtop XV, Yakima Rack, Weathertechs, Sick Speed Shifter, Avid Bumper, Avid Sliders, Bilstien 5100's, TSB Spring packs
    You're good.
  3. Mar 2, 2012 at 6:34 AM
    speedydave
    speedydave Got Boost?!?
    Dave
    Hickory, Nc
    Ecoboost
  4. Mar 2, 2012 at 6:35 AM
    CVYota
    CVYota Damaged Goods
    Andy
    Crescenta Valley
    '11 4X4 DCLB SR5 2.5 gen
    yes, downsouth motor sports or toytec, and let them know you are a member on this site.
  5. Mar 2, 2012 at 6:56 PM
    ranger mac
    ranger mac Well-Known Member
  6. Mar 3, 2012 at 9:12 PM
    Fire Taco Fighter
    trd
    I am guessing I need a spring compressor to remove the spring from the shock to switch out the old to new shock.
    Otto
  7. Mar 3, 2012 at 9:14 PM
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    should be able to take it to a local shop and have em do it for yah...usually they can do it fairly cheap.
    the rental kits for spring compression are pretty sketchy.
  8. Mar 4, 2012 at 7:18 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    DSM- shipped free and for about $300 you get a set of 2 adjustable fronts and 2 rear shocks. :cool:
  9. Mar 4, 2012 at 11:23 AM
    Fire Taco Fighter
    trd
    Here is a pic after TSB was done .You can see how much higher the rear is.
    I will more probably go w/ the 1.75" setting.
  10. Mar 4, 2012 at 11:44 AM
    friction
    friction Well-Known Member
    Charleston, SC
    '08 4X4 RC SR5
    Check the coupon codes on the DSM sticky in the link provided above too. I saved several bones with that...and yep, 1.75 should be right with the rear TSB.
  11. Mar 5, 2012 at 5:41 AM
    speedydave
    Dave
    Hickory, Nc
    Ecoboost
    I have the TSB and set at 1.75. It looks level, but by measuring the rear is 1" higher.
  12. Mar 5, 2012 at 5:45 AM
    SoJersey
    SoJersey Man.As.Prescribed
    Brandon
    08302
    '12 DC Offroad
    Pelfrey Armor Baja Designs Lights 6112/Camburg/Dakar Suspension ARE Z-Series More coming soon...
    For the front, yes. You can rent one from local parts store usually. I phase to leave a $50 there and got it back when I brought back the tool.
