Bilstein 5100 Series Discount Code "Fixed"
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Downsouth Motorsports, Jun 16, 2009.
  1. Jun 16, 2009 at 9:01 PM
    Downsouth Motorsports [OP] Downsouth Motorsport Vendor
    Lakeside, Ca. 92040
    2017 4-Runner Dirt King Long Travel King 2.5 Coil-Over / 2.5 Bypass Front and Rear ICON Rear Upper and Lower Arms ICON Rear 2" Springs 34" x 10.50" x 17 Toyo Tires on 17" x 9" RaceLine Wheels
    Good evening to everyone,
    Well it took me awhile, but I figured out what was wrong with the
    Promo code for the Bilsteins 5100 Series Pre-Load Adjustable Shocks
    for the '05-'09 Tacoma's.....It works now and again I apologize for any Inconvenience and the code is still the following for the set of "4"
    Shocks:
    BIL0509....and the "0" are Zeros.......
    You will need to register on the site first then place your Order and
    Plug in the code and you should be good to go.....
    Again sorry about.....I never claimed to be a computer wiz and it shows...
    Now off to 1st Gen Tacoma's section.......
    Thank you
    Sonny
  2. Jun 16, 2009 at 9:16 PM
    Lakeside, Ca. 92040
    Sorry one more thing.....Just a heads up....
    King just raised there OEM Replacement Performance Coilover Kit
    Retail Pricing and yes the Forum members still get a discount and you
    will need to contact us for the discount...I can not put it in print without
    having someone complain......
    Thanks,
    Sonny
  3. Jun 16, 2009 at 9:28 PM
    09TRD
    09TRD it is what it is
    Oakwood GA
    09 TRD Off Road
    Not yet,
    I thought I was doing something wrong with the promo code, I'm no computer genius either! Now I have to get the nerve back up again to place the order...lol.
  4. Jun 16, 2009 at 9:30 PM
    Lakeside, Ca. 92040
    I know sorry about that......But better late then never and
    there is a learning curve for me and computers....HA, HA, HA
  5. Jun 16, 2009 at 9:31 PM
    09TRD
    Oakwood GA
    09 TRD Off Road
    Not yet,
    I hear that...lol, how is the supply of the front/rear 5100's for the 2009's right now?
  6. Jun 16, 2009 at 9:33 PM
    Lakeside, Ca. 92040
    Thank God...Good right now and it looks like we should be o.k. for a little while...
    Now the First Gen Tacoma's...That's a whole different story....
  7. Jun 16, 2009 at 9:37 PM
    09TRD
    Oakwood GA
    09 TRD Off Road
    Not yet,
    I hate to hi-jack the thread but what you think I could sell the stock TRD Off Road bilstein's out from under my truck for? 3,000 miles on 'em.
  8. Jun 16, 2009 at 9:44 PM
    Lakeside, Ca. 92040
    You might get $100 to $150 for the set of "4"
    Craigs List and E-Bay is what I would recommend as well
    as Race Dezert....
  9. Jun 16, 2009 at 9:46 PM
    09TRD
    Oakwood GA
    09 TRD Off Road
    Not yet,
    Alright, that seems to be the consistent answer. I'll be another satisfied customer of DSM soon enough. Thanks for all your help. I know I've sent you ALOT of pm's trying to figure all this out. lol
  10. Jun 16, 2009 at 9:48 PM
    Lakeside, Ca. 92040
    No Problem.....That is why I am here to help and answer questions....
    Let me know.....
    Thank you,
    Sonny
  11. Jun 17, 2009 at 5:45 AM
    Simon2150
    Simon2150 Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
    <-- Satisfied customer right here. Got my billies installed last week and they're awesome!
  12. Jun 17, 2009 at 5:51 AM
    Negative1
    Negative1 Well-Known Member
    I just started considering putting 5100's on my 09, and Im not sure I understand how just a 'shock' can lift the truck 2.5"
    If my search skills are right, people are not putting in aftermarket springs, and are just using their stock springs with the 5100's in the front to get 2.5" lift.
    And for the rear, the 5100's don't give any lift, its more just to match up the ride stiffness... Right?
    I'll prob order a set, when I know more about this.
  13. Jun 17, 2009 at 7:25 AM
    Lakeside, Ca. 92040
    Good morning,
    I figured I would answer this one as best I could....
    The front shocks are lifting the truck because you are raising the lower spring Plate
    location and adding Pre-Load to the spring to change the ride height.
    That is why you are re-using your factory spring and Top hat and there is no need
    for an after market spring unless you chose to...
    The shock is not any longer then stock....
    The advantage is the valving in the shock, because it is set up to help with the added pre-load of the spring.....The front and Rear shocks are valved to work together and
    that is also what makes the shocks unique....
    The rear shocks do not lift the rear because of the leaf spring suspension you have.
    The only way to change the ride height on a leaf spring would be to add a AAL
    or a block and U-Bolt kit or Shackle or a new spring pack and so on.....
    Hope this helps...
  14. Jun 17, 2009 at 8:55 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    I went to the website, and created an account. I selected the bilstein 5100's, entered the discount code and no go. ...
  15. Jun 17, 2009 at 9:11 PM
    Lakeside, Ca. 92040
    Where are you located???
    I tested it again this morning and it worked.....
    You can place the order online and make a note in the year make and model section and I will modify the pricing on our end.....
    Back to the drawing board...
  16. Jun 17, 2009 at 10:55 PM
    ColtsTRD
    Scott
    AZ
    Thanks alot, look forward to doing business w/ ya!
