Bilstein 5100 Series Update '05-'10
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Downsouth Motorsports, Jan 14, 2010.
  1. Jan 14, 2010 at 11:00 AM
    bdwsrjoe
    bdwsrjoe Well-Known Member
    Joe
    Rio Hondo, TX
    08 Tacoma Double Cab TRD Offroad 4X4
    K&N Cold Air Intake, Magnaflow Catback Exhaust, 3" ToyTec Lift Kit, JVC InDash DVD Player with Backup Camera, 2 10" JL Audio Subs, 8K HID Headlights, 8K HID Foglights, N-Fab Nerf Steps, In-Channel Ventvisors, springfield xd40v10, mossberg 500 12ga.
    did you mean that you would be carefull running the spacer with the stock shock or the 5100's?
    my ride actually isnt that bad.
  2. Jan 14, 2010 at 11:05 AM
    Downsouth Motorsports [OP] Downsouth Motorsport Vendor
    Lakeside, Ca. 92040
    2017 4-Runner Dirt King Long Travel King 2.5 Coil-Over / 2.5 Bypass Front and Rear ICON Rear Upper and Lower Arms ICON Rear 2" Springs 34" x 10.50" x 17 Toyo Tires on 17" x 9" RaceLine Wheels
    Both.....But if you say it does not ride bad....Run what you brung..
  3. Jan 14, 2010 at 11:06 AM
    bigguy78619
    bigguy78619 Well-Known Member
    san diego, ca
    07 TRD Off-Road PreRunner DC
  4. Jan 14, 2010 at 11:07 AM
    Lakeside, Ca. 92040
  5. Jan 14, 2010 at 11:12 AM
    JackedTaco
    JackedTaco Well-Known Member
    Johnny
    USA, Earth...
    07 Access Cab TRD Off Road
    Weathertech Mats, Thule rack custom install on bed caps. Foglite anytime mod. K&N air filter. Rear leaf TSB. Tinted passenger windows. TRD CAt Back exhaust. Bilstein 5100 front shocks at 1.75".
    PM sent.
  6. Jan 14, 2010 at 11:17 AM
    Lakeside, Ca. 92040
  7. Jan 14, 2010 at 11:35 AM
    tomonian77
    tomonian77 Well-Known Member
    Thomas
    Magnolia, TX
    2008 PR DC 4.0
    Painted Rims Black, Painted Emblems Black, Aftermarket Stereo, Grillcraft, BHLM, K&N CAI
  8. Jan 14, 2010 at 11:40 AM
    Outlaw
    Outlaw Well-Known Member
    Iowa City, Iowa
    2006 GX470
    Water Pump, Timing Belt, Sparkplugs, Plastidip Grill emblem
    I would like a pair of the rear 5100s. Pm Sent!
  9. Jan 14, 2010 at 11:41 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Great to see the awesome customer service and responsiveness from Downsouth Motorsports. There's definitely a reason folks always recommend you! :thumbsup:
    Free bump so others can see. :)
  10. Jan 14, 2010 at 12:05 PM
    Lakeside, Ca. 92040
    Got the PM's and Thank you to all of you.....We will keep you posted and
    We just upped the quantity of what we had on order so we should be all good...
    Thanks,
    Sonny
  11. Jan 14, 2010 at 12:08 PM
    kilgoja
    kilgoja Well-Known Member
    Alabama
    2009 regular cab 4x4 2.7L (silver)
    :mudding:
    ...i was thinking of maybe putting 5100s front and rear...just leave the rear setting at 0" and adjust the front to level it out...maybe 1.75" or 2.5"...which setting would level it out?...it would be ok if the front end was a lil lower than the back...i don't want the front higher than the back...lol...is it easy to make adjustments to the height?...or do you have to remove the shock to do it?...it is just as simple as removing stock shocks and bolting on new 5100s right?....or is it something i would have to get done at a shop?....i guess you can't lift the rear of the truck with just 5100s...would have to use a block or aal?...also how much would it cost for 4 5100 shocks?....sorry for all the questions...lol
  12. Jan 14, 2010 at 12:11 PM
    Lakeside, Ca. 92040
    In response to KilGoja
    1.75" front with stock springs and it will almost be dead level and the nose will still be down a hair.
    Highly recommend you have a shop do it with a wall mounted spring compressor to be on the safe side and you will need an alignment anyway because you are changing the ride height.
    You can only adjust the height while the shock is separated from the factory spring and top hat, not once it is installed.
    Spring rate on the factory springs is around 500 lbs and that is why I recommend you have a shop do it.If that spring decides to come out, it will be in a hurry..
    PM us for Forum member pricing so I do not get in any more trouble...HA,HA,HA
  13. Jan 14, 2010 at 12:17 PM
    kilgoja
    Alabama
    :mudding:
    ok thx for the info..i sent pm...hope it worked..lol
  14. Jan 14, 2010 at 12:21 PM
    Lakeside, Ca. 92040
    Pm sent back to Kilgoja...
  15. Jan 14, 2010 at 12:30 PM
    #35
    calicoupe
    calicoupe Well-Known Member
    pmd and thanks Sonny!
  16. Jan 14, 2010 at 12:40 PM
    #36
    Lakeside, Ca. 92040
    Got it....Calicoupe
  17. Jan 14, 2010 at 1:13 PM
    #37
    newfie8
    newfie8 Well-Known Member
    newfoundland
    09 tacoma
    Tinted windows all around. Fog lights. Intermittent wiper switch. Skid plate. Extra D rings. Grillcraft. Color matched grill. Hella 500ff HID behind grillcraft. Rcbs204 Lighting. 5100's up front. 265/75/16 Duratracs.Firestone riderites. Bora Wheel spacers. Tinted tails. De badged. Blacked out rims.
    pm sent.
  18. Jan 14, 2010 at 1:16 PM
    #38
    Lakeside, Ca. 92040
    Got it...newfie8
  19. Jan 14, 2010 at 1:48 PM
    #39
    RedOlaf
    RedOlaf Well-Known Member
    Los Angeles
    09 Tacoma 4x4 DBL CAB TRD
    Bilstein 5100s, Wet Okole Seat Covers, Anthracite TRD Wheels
    pm sent
  20. Jan 14, 2010 at 3:25 PM
    #40
    Lakeside, Ca. 92040
    Got it, RedOlaf and responded.
