Bilstein 5100 set at 2.5, rear aal 1.5 3 leaf progressive W NO TSB 2ndgen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AUDIBIMMERBENZ, Nov 17, 2022.
  1. Nov 17, 2022 at 7:57 AM
    AUDIBIMMERBENZ
    AUDIBIMMERBENZ [OP] Member
    2015 trd or
    Anyone run this set up? Every where I see photos they have the TSB leaf in, I only have 3 leafs and would like to avoid a nose high look thanks
  2. Nov 17, 2022 at 10:24 AM
    twblanset
    twblanset Well-Known Member
    Todd
    Vacaville, CA
    2015 TRD OR
    Mild lift and some tasty bits
    I've installed this setup on a few friend's trucks. You should be fine. If it is a little nose-high, you can always slip in a spacer in the rear.
    AUDIBIMMERBENZ[OP] likes this.
  3. Nov 17, 2022 at 10:31 AM
    AUDIBIMMERBENZ
    2015 trd or
    How does a rear spacer for back work? I’ve seen them the smallest in 1 inch, that would be 2.5 in the rear and the Bilstein 5100 are only rated for 1 inch right?
  4. Nov 17, 2022 at 10:59 AM
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    I bascially have 2.5' lift in the front and have an after-market HD progressive 3 leaf pack on top of the stock overload (so 3leaf + overload) and my truck sits fairly level with an ever so slight positive rake.
  5. Nov 17, 2022 at 12:10 PM
    twblanset
    Todd
    Vacaville, CA
    2015 TRD OR
