Bilstein 5100 set to 0 with spacers or OME springs?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by J011YGR33N, Mar 31, 2017.
  1. Mar 31, 2017 at 1:29 PM
    J011YGR33N
    J011YGR33N [OP] Active Member
    2016 Sport Double cab long bed
    I would like to level my 2016 tacoma double cab long bed 4x4 sport and I'm not sure what to get. I have looked on the previous posts that I could find on the subject matter and I know that most people run the 5100s maxed out with stock springs. I would like to maintain or improve my current ride quality due to back issues so I would like to keep the 5100s at the 0 setting. Would I be better off going with 2" spacers or 887 OME 2" springs?
  2. Mar 31, 2017 at 1:45 PM
    bubba433
    bubba433 Active Member
    SoCal
    Springs over spacers in my opinion
  3. Mar 31, 2017 at 1:47 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    x999999999999999999999
    bobrown14 and QuicksandTaco like this.
  4. Mar 31, 2017 at 2:15 PM
    J011YGR33N
    Thanks everyone, will the 5100s be long enough to support the 2" OME lift springs? Please excuse my ignorance if this sounds like a stupid question.
  5. Mar 31, 2017 at 2:17 PM
    EricU
    EricU Well-Known Member
    Englewood, CO
    I am not familiar with the 3rd gen suspension, but a handful of people run 887s on 5100s with no issues
  6. Mar 31, 2017 at 2:25 PM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
  7. Mar 31, 2017 at 3:00 PM
    kxed
    kxed Well-Known Member
    pittsburgh
    2017 DCLB TRD Sport Inferno
    I just installed 5100's and OME 887's on my truck 17 DCLB Sport. I was concerned about it being stiff as I really liked the factory ride. I'm happy to say the ride is very close to factory lust a little bit stiffer. You will also want to run something in the rear unless you like the pre runner look.
    bobrown14, vprgts and J011YGR33N[OP] like this.
  8. Mar 31, 2017 at 3:37 PM
    J011YGR33N
    Did you end up running a block or did you just extend the rear 1"?
  9. Mar 31, 2017 at 3:38 PM
    vprgts
    vprgts Well-Known Member
    Walter
    Centreville, VA
    Tacoma TRD Off Road Hybrid
    285/70/17 Nitto Ridge Grapplers, RRW wheels 17 x 8.5, Wescott designs pre collar lift, rough country power side steps, Truxedo pro x15 soft roll up bed cover, OEM bed mat, OEM bed swing out box, OEM Trd pro front skid plate, aftermarket pro grill, diode dynamics led fog lights, OEM sport hood, PPF and tint,
    Just installed 5100, ome 877 and a single deaver AAL in the rear on my 17 DCLB. Very happy! Call Marie at headstrongoffroad
    bobrown14 and J011YGR33N[OP] like this.
  10. Mar 31, 2017 at 3:38 PM
    kxed
    pittsburgh
    I'm running a block as I didn't want to stiffen the ride with an aal
    J011YGR33N[OP] likes this.
  11. Mar 31, 2017 at 3:42 PM
    J011YGR33N
    What is the advantage of the AAL vs block?
  12. Mar 31, 2017 at 3:43 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    Less axle wrap
  13. Mar 31, 2017 at 3:50 PM
    gottaToy
    JJ
    1985 Moped
    there is a standard AAL and a Progressive AAL. Progressive AAL are designed to maintain factory ride.
    a 1" block won't have much axle wrap and will maintain same ride quality. It would be fine, but progressive AAL aren't that much
  14. Mar 31, 2017 at 3:53 PM
    Clay7160
    Clay7160 Well-Known Member
    2018 MGM TRDOR DCLB 4x4
    GYEON ceramic coating
    Springs but ask @HeadStrong Off-Road , maybe a shorter OME might be a better choice to level unless you want to add a rear lift.
  15. Mar 31, 2017 at 4:00 PM
    vprgts
    Walter
    Centreville, VA
    For me personally speaking just say no to blocks! My friends rides with blocks are garbage. My 2 cents. And the single AAL was not that expensive.
    bobrown14 likes this.
  16. Mar 31, 2017 at 4:03 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    Just curious, what vehicle are they on and how are they garbage? My friend has them on his 01 F150 and his truck rides like a dream compared to ours.
  17. Mar 31, 2017 at 4:12 PM
    vprgts
    Walter
    Centreville, VA
    Nissan Frontier and 07-08? F150. My take is my new 17 Trd stock sport was too sloppy. The set up I have now again "for me" is perfect.
    DustStorm4x4[QUOTED] likes this.
  18. Mar 31, 2017 at 4:25 PM
    J011YGR33N
    Are you able to fit the coveted 28570r17 sized tires on your sport with that set up?
  19. Mar 31, 2017 at 4:32 PM
    vprgts
    Walter
    Centreville, VA
    That I wouldn't be able to answer. You'd probably need to get upper control arms. Just do yourself a favor and call Marie. She is extremely knowledgeable and knows her shit! In the meantime just look around on this forum and see what others are using with that tire set up.
  20. Mar 31, 2017 at 4:38 PM
    wirenut
    wirenut I like this place
    Andrew
    NH
    98’ T4R
    OME/5100 - 300lb 3.5” loft setup Prinsu 3/4 rack
    Ive got 887's on 5100's with dakars in the rear. Very happy with the ride. To level out i added a 1/2" spacer on the driver side and a 1/4" spacer on the passenger. 2.75" of lift and alignment is right there.
    Lowrange or Headstrong you can't go wrong with either one.
