Bilstein 5100 setting question .085 or 1.75 front?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PPM, Mar 3, 2011.
  1. Mar 3, 2011 at 2:26 PM
    PPM
    PPM [OP] Well-Known Member
    Lake Conroe Texas
    Tacoma LWB TRD Sport 4x4 Silver Mica
    toyota skid plate, toyota hood shield, toyota stainless steel exhaust tip, tacoma bed mat, color keyed body side moulding, TSB done on rear bilstein 5100 all the way around front set at .085 more to follow
    I just had my 2010 Taco dbl cab lwb TRD sport get the TSB done with the 4 leaf pack 2 days ago, it raised the back about three inches and I understand it will settle some with time.
    My question is...
    I am getting ready to install 5100's all around this weekend and want to know which setting to go with .085 or 1.75? for the front.
    I will be hauling an aluminum 18' center console boat regularly and I don't want to be nose high, but I like the look with the 1.75 setting.
    I don't want to use rear blocks either.
    Any suggestions would be appreciated.
    picture after TSB
  2. Mar 3, 2011 at 2:31 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    With 1.75" setting, you should just be about even with the rear. Towing on the other hand will have you nose high. An AAL with the TSB spring is real stiff but great for towing and hauling.
  3. Mar 3, 2011 at 2:40 PM
    PPM
    Lake Conroe Texas
    Thanks for the input. I am scared the AAL will ruin the ride. Looking at .085 setting, I think
  4. Mar 3, 2011 at 2:44 PM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I have a 1.5" AAL with the TSB spring and it's stiff! If I wasn't towing or hauling, I would have used blocks. If you want a decent ride, skip the AAL and spend the extra money on leaf packs. I believe there's a 3 leaf one that gives you a 1.5" lift but you can try the blocks first since they don't cost too much.
    You should ask Chris4x4, he had blocks first and switched to AAL.
  5. Mar 3, 2011 at 3:15 PM
    PPM
    Lake Conroe Texas
    Thanks for the input. I will check it out
  6. Mar 3, 2011 at 3:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I never had blocks. Blocks can cause/exacerbate axel wrap, and wear your springs out faster. A Long AAL wont affect the ride too much, while the short ones will stiffen it up a bit more.
  7. Mar 3, 2011 at 3:22 PM
    tacopromatt
    tacopromatt Matt's Pro Taco (SOLD)
    Austin, TX
    2017 Cement Tacoma TRD Pro AT
    I've had blocks and now an AAL w/ the stock TRD OR Bilsteins and it's all stiff. I'm actually about to go down a tire size, remove the AAL and go from 2.5 to 1.75 up front.
  8. Mar 3, 2011 at 3:22 PM
    757southpaw
    757southpaw Well-Known Member
    Jay
    757
    07' DC LB TRD Sport 4x4
    BAK BakFlip Tonneau cover, 30% front tinted windows, AVS vent shades, Black Billet Grill,Pop& Lock, secondary air filter removed, Goodyear Duratrac's, Billies @ 2.5" on front, Billies on back w/ 1.5" AAL, Toytec Diff drop, NOKYA Hyper Yellow fog light bulbs, LaminX Weathertechs, Rear diff breather mod, BHLM
    Personally I'd set the 5100's in the front to 2.5" and install a 2" aal. GL with your decision.
  9. Mar 3, 2011 at 3:24 PM
    2010Tacoma4x4
    2010Tacoma4x4 "Man Ho"
    Dave
    Jacksonville, Fl
    2010 4x4 SR5
    Tinted windows, Bug deflector, Rain guards, Bed mat, Rear leaf TSB, Bilsteins front & rear (front set @ 1.75), 16x8 chrome Helo wheels, Toyo open country AT P265/75/R16 tires. CBI bolt on sliders. BSP color matched M1 Satoshi grill. BHLM. UWS low profile black powder coat crosover truckbox. Pioneer DVD/CD head unit - 4 channel amp - front mids & highs - 8" sub box.
    I have the TSB and 5100's set at 1.75 and like the way it sits. Hooked up my boat and I still looked level. Now I have an access cab and to me it looks like the DC's that are set at 1.75 look a little more tail heavy so you may consider .85 instead.
  10. Mar 3, 2011 at 3:25 PM
    trd888
    trd888 Well-Known Member
    set up 1.75 mine with TSB leaf springs...look good to me and no rake like it!!!
  11. Mar 3, 2011 at 5:07 PM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    My apologies. I thought I saw your write up for the AAL install with blocks on the truck. Might not have been your truck. Might not even be your write-up.
    Also, I have the Dakar long AAL and it stiff but I've only had it for about 2.5 weeks. Maybe it will soften up a bit.
    My fender lip to ground measures 38.25" fronts and 40" rear.
  12. Mar 3, 2011 at 5:11 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    Have the TSB and 5100s set at .85.
    i think that would be the best for you
    the TSB raised your back end 3 inches??
    the TSB raised my back about 1.5 inches
    and then it settled to about 1 inch
    hense why i went with the .85
  13. Mar 3, 2011 at 5:12 PM
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    Are those Moto Metal 950's on your truck?? Your wheels look sweet!!
  14. Mar 3, 2011 at 5:20 PM
    tegdog
    tegdog Taco Lover
    Indiana
    09 Tacoma Dbl TRD Sport
    ventvisors,seatcovers, bug shield,TRD CAI,TRD CAT BACK,blacked out emblems,bed extender, TSB leaf pack,Pro Dry filter, Grill craft upper, lower, & triangles, Hella 500 Black magics
    I have the same decision to make on my sport, anybody know if you can go any bigger with tires set @ 1.75 front & rear TSB springs on stock rims?
  15. Mar 3, 2011 at 5:20 PM
    PPM
    Lake Conroe Texas
    It really did raise the back three inches, but I know as soon as I haul a heavy load it will go down about 1.5 inches from what I understand.
    Still have the factory TRD sport wheels, bigger tires and new wheels will be the next mod.
    Thanks for all your input.
  16. Mar 3, 2011 at 5:30 PM
    2010Tacoma4x4
    Dave
    Jacksonville, Fl
    2010 4x4 SR5
    Thanks,
    They are actually Helo Maxx. I really like em.
  17. Mar 4, 2011 at 6:55 AM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    I have the Icon 3 leaf progressive AAL and I love the ride of it. It's was supposed to raise the rear 1.5" but it actually raised it 2 3/8". Hasn't settled any after 3,000 miles.
  18. Mar 4, 2011 at 6:58 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    That was my write up, but PackerfanXD's truck. I is much happier with the AAL instead of the blocks.
  19. Mar 4, 2011 at 7:48 AM
    dgr540
    dgr540 I've got the FUNK
    Friendswood, TX
    2013 Wrangler Unlimited
    XDs Trail grappler 35x12.5x18 Winch 8K lbs Front bumper 4in Lift
    I have the tsb with the 1.5 AAL I really didnt notice a difference from when I got the TSB to adding an extra leaf. I have front set to .85, but I am about to put coils on it.
  20. Mar 4, 2011 at 8:16 AM
    jgray
    jgray Well-Known Member
    josh
    boyds,md
    05 Ext.cab "murder was the case"
    Aero turbine sidepipe 3" pipe Murdered out 3"revtek leveling kit 33's
    Do 5100's give a smoother ride than toytecs??
