Bilstein 5100 setting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KrackerJ, Apr 7, 2014.
  1. Apr 7, 2014 at 4:15 PM
    KrackerJ
    KrackerJ [OP] Member
    Jeff
    Dallas, Ga
    13 Tacoma TRD Sport
    Bilstein 5100 w/885x coils, 285/70r17 Nitto Terra Grappler G2
    There might be something about this already but I have searched high and low and couldn't find the answer I was looking for. I have a 2013 DCSB 4x4 trd sport that is stock.I just purchased a set of bilstein 5100 shocks. I was wondering if I set them at the max setting, would I need to change out or add anything else in the front.
  2. Apr 7, 2014 at 5:00 PM
    MrShoehorn
    MrShoehorn Well-Known Member
    Justin
    North Augusta, SC
    12 DCSB TRD Sport Blue Ribbon
    From what i've read it's hit or miss with needed new UCA's.
  3. Apr 7, 2014 at 5:05 PM
    IronPig
    IronPig Well-Known Member
    CA
    08 PreRunner DC
    Toytech Ultimate Lift Kit, LR UCA's, T3 eyelids, 285/75/16 Nitto Terra Grapplers, FN Type X wheels, Debadged, Homer Taco Raptor Grill and lower valance grill, painted lower valance, blacked out skid plate, Flyze Eye interior light, LED interior lights, EZ down tailgate
    It is a little bit hit and miss. It also depends on tire/wheel combo as far as rubbing. Generally, if you are at 2.5" start considering them. Closer to 3" and you might as well get them. Light Racing UCA are not that expensive and will help with getting the alignment correct.
  4. Apr 7, 2014 at 5:06 PM
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    That's a ton of preload and will result in a real rough ride. Get some OME springs and set them to 0 for about the same lift and a much better ride.
  5. Apr 7, 2014 at 6:33 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Possibly adjustable UCAs. Other than that nothing 'needed' for the front. It'll be up to you if you think it rides rough. Mine are set at 1.75" on sport springs and it's not bad.
    You probably already realize, but 2.5" would be nose high with the rear left unchanged.
