Bilstein 5100 Settings for dummies
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AZ_Taco48, Nov 13, 2019.
  1. Nov 27, 2019 at 12:54 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    That's odd, both mine and my sons ride great. Mine is on the 4th setting and sons is on the 5th. Both same set ups, diff drops, rear carrier drops, clamshell bushings, all the same. I sometimes think his rides better. My friends has the same truck and his has OME and we cannot tell a difference.
    71tattooguy likes this.
  2. Nov 27, 2019 at 1:01 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    It could be tire pressure and added/less weight that can dramatically effect ride quality.
    Heepspo likes this.
  3. Nov 27, 2019 at 1:03 PM
    VaToy
    Parts Unknown
    Maybe so, both our tacoma's run the exact tire and wheel set up too. Maybe he is running a E rated with 40 lbs. IDK.
    Grossomotto[QUOTED] likes this.
  4. Nov 27, 2019 at 2:21 PM
    Cankel24
    Cankel24 Member
    J.
    2017 TACOMA TRD OR
    really looking forward to how this turns out, im on the same boat.. keep us posted
    AZ_Taco48[QUOTED][OP] likes this.
  5. Nov 29, 2019 at 10:55 AM
    Shades_Of_Red
    Shades_Of_Red Well-Known Member
    Lou
    Pittsburgh, PA
    2019 Tacoma TRD Off Road Premium Cavalry Blue
    A few.
    Did any of you happen to take before and after measurements to see how close the amount of lift ended up being compared to specs on the instruction sheet?
  6. Nov 29, 2019 at 6:03 PM
    Rosshoss
    Rosshoss Well-Known Member
    2016 Tacoma TRD OR
    What offset is your wheels?
  7. Nov 29, 2019 at 6:34 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    -12
  8. Nov 30, 2019 at 1:13 AM
    OregontoBajaCA
    OregontoBajaCA 2025 DC OR High Bread
    2025 OR DC iF Max
    By making that comment you reveal yourself as someone who doesn’t know what they’re talking about to people who do know what they’re talking about regarding this subject.
    You have common misconceptions concerning coil-overs and the settings on ride height adjustable shocks and the reasons they don’t affect ride, spring length or rates.
    It’s safe and easy.
    For installation, the spring is compressed between the vehicle weight above it and the jack below it. Perfectly safe.
    The spring is the same length at all settings when the vehicle weight is on the spring. That’s a fact.
    Lift is created by lengthening the bottom portion of the shock by moving the clip upwards in small increments. That’s a fact also.
    Hank Heel, don’t make false and/or shitty comments for the world to read.
    Think and read about the subject a bit more. Learn something new and better.
  9. Nov 30, 2019 at 4:18 AM
    Smokinnuts
    Smokinnuts Well-Known Member
    HD
    2019 TRD Pro MT
    LED lights, Decked box
  10. Nov 30, 2019 at 4:33 AM
    Shades_Of_Red
    Lou
    Pittsburgh, PA
    A few.
    PapaBear15, SpokeWench and djgynee like this.
  11. Nov 30, 2019 at 10:22 AM
    Rosshoss
    2016 Tacoma TRD OR
    After reading & watching this I'm gonna go with 5100's in the front in back. I want 285\70\17 wheels & tires.
    VaToy likes this.
  12. Nov 30, 2019 at 10:29 AM
    VaToy
    Parts Unknown
    Your going to rub, plan on a CMC and the correct offset.
  13. Nov 30, 2019 at 10:47 AM
    Joe671
    Joe671 YouTube Mechanic
    Joe
    Washington State
    Correct me if I'm wrong, but if you adjust your bilsteins to the higher settings you compress your spring therefore adding a preload to the spring? This preload on the spring makes your ride... "Stiffer or harsh" because your spring doesn't have the travel it once had to "dampen" your ride? Serious question. Or am I we Todd did? OP, i would suggest getting a proper spring to match your 5100's. If you go with stock springs I wouldn't suggest going too high on your settings. If you go with 285/75/16's you are going to rub. It's just a matter of where you are going to rub and how much. So far with my lift and tires o rub only on the trim. Of course I haven't "flexed" my suspension as of yet so I won't know for sure. Good luck and post some pics.
  14. Nov 30, 2019 at 12:24 PM
    Shades_Of_Red
    Lou
    Pittsburgh, PA
    A few.
    If the bilsteins are valved for the stock springs, wouldn't using a heavier, stiffer spring throw off that valving?
    71tattooguy, Hoff and VaToy like this.
  15. Nov 30, 2019 at 12:37 PM
    #35
    Shades_Of_Red
    Lou
    Pittsburgh, PA
    A few.
    I personally have a set of all 4 5100's ordered and am planning to set the fronts at either the 2nd or 3rd setting. Im looking for 1 inch of lift. Anyone who has done the same and took measurements before and after install, setting, and alignment, how much lift did you end up with?
    fonzi42 likes this.
  16. Nov 30, 2019 at 12:47 PM
    #36
    808leo
    808leo Well-Known Member
    Kapolei, Oahu
    ‘21 super white dcsb 4wd
    5100 max setting, 285/70/17 ko2, FN 6 shooter, Subaru/kicker tweeters, JBL BassPro sub, nfabs, LED lights exterior/interior.
    I know this thread is about the bilsteins, but I have the eibachs on my T4R, stock coils on the max setting. To me, my other half and my dogs they all prefer that compared to my 2nd gen 5100s lowest setting with OME 885 coils. That’s just my opinion tho as we all know it’s subjective. I’ll just say I enjoy it so much when i get my 3rd gen I’ll be going eibach route again.
  17. Nov 30, 2019 at 1:31 PM
    #37
    DSMHokie
    DSMHokie Well-Known Member
    Caleb
    Charlotte, NC
    2019 Super White TRD Sport DCSB 4x4
    Bilstein 5100s on 3rd Setting (1.1”) TRD Pro Grille 17” SEMA Wheels 265/70r17 General Grabber ATX Custom Fabricated Sliders Lomax Bed Cover
    I just did them in the front earlier this week. I took measurements and the front was about 1-1/4” lower than the back in stock form. Had the shop set my 5100s on the 1.1” setting and it’s perfect. Nearly level and the nose wasn’t higher than the rear when I threw all my tools in the back the day after.
    I haven’t added anything to the rear. Hope this helps
  18. Nov 30, 2019 at 2:19 PM
    #38
    ctimrun
    ctimrun and junk
    Any pics?
  19. Nov 30, 2019 at 2:25 PM
    #39
    DSMHokie
    Caleb
    Charlotte, NC
    not any great ones but this is the closest one I have to it being on flat ground.
  20. Nov 30, 2019 at 2:44 PM
    #40
    Shades_Of_Red
    Lou
    Pittsburgh, PA
    A few.
    Hows the ride?
