Bilstein 5100 Settings for dummies
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AZ_Taco48, Nov 13, 2019.
  1. Dec 6, 2019 at 6:59 AM
    #61
    AZ_Taco48
    AZ_Taco48 [OP] Member
    Daniel
    ‘19 Tacoma TRD Off-Road
    Took the truck out for a short Offroad (sand, rocks, graded FR). There is a noticeable improvement to the dampening. Definite improvement over the stock suspension. I would recommend my exact set up for anyone trying to achieve what I explained in my OP. Thanks for the input all.
    wolf08gang, fonzi42, Atowns40 and 4 others like this.
  2. Dec 6, 2019 at 7:12 AM
    #62
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    This is very good input. Thank you for taking the time, and really exactly the kind personal explanation I have been seeking.
    Currently looking at Bilstein 6112's which are $679 set, and the 5160's are $189 each. After/during I will start my own post as well.
  3. Dec 6, 2019 at 7:13 AM
    #63
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    I just ordered that exact setup off Headstrong Off Road, best customer service I;ve had in awhile, and the best pricing I've found for assembled coil overs.
  4. Dec 6, 2019 at 8:20 AM
    #64
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Cool!
    Their price is nearly exactly the same as my local shop (Mule). I have been holding my tongue on bad mouthing the stock Sport (Hitachi) shocks, because they are actually quite nice on the street. But wow they absolutely SUCK on any whoops or even moderately bumpy dirt road. The truck gets uncontrollably bouncy even at low speeds and the shocks don't stand a chance.
    Kodiak420 likes this.
  5. Dec 18, 2019 at 10:29 PM
    #65
    Shades_Of_Red
    Shades_Of_Red Well-Known Member
    Lou
    Pittsburgh, PA
    2019 Tacoma TRD Off Road Premium Cavalry Blue
    A few.
    I purchased all 4 bilstein 5100s from headstrong ( best price i found shipped) and installed over the weekend using the no spring compressor method. After install and alignment it ended up giving me 1 1/4" of lift on the 3rd setting. My experience with lifts has been, with the exception of bodylifts and rear lift blocks, you can count on ended up with a little more lift than what is claimed. 1.1" turns into 1.25".
  6. Dec 26, 2019 at 12:03 AM
    #66
    Socialrafa
    Socialrafa Well-Known Member
    2020 Sport 4x4 DCLB cement
    Hi Pablo, did you ever make this change? How do you like your ride now?
  7. Dec 26, 2019 at 5:23 AM
    #67
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    No, saving money again. I just paid for my lockers, gears, etc........and Christmas! Probably will do early 2020
  8. Dec 26, 2019 at 8:41 AM
    #68
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Txs for that Caleb. Now that it's level, are you happy you didn't bother with the rear? That's what I've been looking to do without.
  9. Dec 26, 2019 at 9:28 AM
    #69
    DSMHokie
    DSMHokie Well-Known Member
    Caleb
    Charlotte, NC
    2019 Super White TRD Sport DCSB 4x4
    Bilstein 5100s on 3rd Setting (1.1”) TRD Pro Grille 17” SEMA Wheels 265/70r17 General Grabber ATX Custom Fabricated Sliders Lomax Bed Cover
    I’m still happy with it, it looks and rides great. However I am planning to do something to the rear in the future as I am planning on running 285s on the next round of tires.
  10. Dec 26, 2019 at 10:47 AM
    #70
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    And that is with the OEM springs too Caleb?
  11. Dec 26, 2019 at 11:11 AM
    #71
    DSMHokie
    Caleb
    Charlotte, NC
    Correct, I didn’t change out springs yet but will when I do something in the back
    Tocamo[QUOTED] likes this.
  12. Dec 29, 2019 at 9:05 PM
    #72
    cruxx
    cruxx Well-Known Member
    Huy
    2017 TRD Sport
    Hold on im no pro here, but you the spring length are not the same. The top hat does not move relative to bottom clip. The top hat is at a fixed location and when you move the clips up, you preload the spring. The preload is what gives you lift, or rather the spring is stiffer so the weight of the vehicle does not sag it as much. Now in terms of ride, the stiffer the spring, the stiffer the ride. What i am still confused about is what happens to travel when you preload the coil. The actual travel or the shock has not changed just because we preloaded the spring, only the reaction of the spring to weight to the travel. So it would take more weight to move a preloaded spring, hence less down travel under normal weight. I am not sure if up travel is affected In the same manner as the spring cannot be decompressed from its preloaded condition, so im thinking up travel is not affected. Anyone with real knowledge, please correct me if i am wrong
    just reading the comments, the spring length yes will be the same length with the wieght of the vehicle on all clips, because weather pressure from the wieght of the vehicle or from preloading, its just pressure from both sides of the spring, the spring is designed to be a certain length for the same wieght. That in no way means the spring will react the same because under preloaded conditions, you have created a stiffer spring, meaning stiffer ride. I think my thoughts on travel remain unchanged
  13. Feb 5, 2020 at 1:41 PM
    #73
    SmokeyTacoAZ
    SmokeyTacoAZ Well-Known Member
    2018 DCSB TRD 4x4 OR
    Just checking in to see if the OP has any updates. I appreciate the anecdotal step by step information. I've been starting from the opposite end with tires/wheels.
    I'm planning on going with a minor 1" lift so this setup sounds like a good option once my stock shocks wear out. I may need to look more into AALs since I want to maintain the factory take though.
    AZ_Taco48[OP] likes this.
  14. Feb 16, 2020 at 5:47 AM
    #74
    tdavistech
    tdavistech Well-Known Member
    Post 2 is about the most helpful response I've seen around here.
    Post 5 is the typical BS that has kept me in the dark to the answer to this question.
    AZ_Taco48[OP] and 02Duck like this.
  15. Feb 16, 2020 at 7:06 AM
    #75
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    C63E8117-03BD-423C-B715-BE9210B9EC7E.jpg Here she is 4th setting up front rear 1.5” lift. Factory rake. Rides excellent. Super stoked on my set up.
  16. Feb 16, 2020 at 7:46 AM
    #76
    drjkll
    drjkll Well-Known Member
    NC
    2019 DCLB TRD sport 4x4 cement
    I emailed Bilstein directly. See below:
  17. Feb 16, 2020 at 8:54 AM
    #77
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Amen. 71tattoguy this was what I was talking about.
  18. Feb 16, 2020 at 9:25 AM
    #78
    DC5275
    DC5275 Well-Known Member
    David
    Nature Coast Hernando, FL
    2017 Tacoma TRD OR DCLB Black 4.88 Gears
    @Douros
    This is the same setup I just installed on my 2017 DCLB OR with 28,000 miles at the end of January. The ride only changed due to the new valving difference of the 5100's. Alignment went perfect with a very minimal adjustment. Great setup for only $375 + $169 for lifetime alignment. Very easily done in the driveway in a couple of hours. It's a great setup to lift/ level the front. Good choice...
    I plan on installing my F5's 16x8 4.5bs on 255/85/16's once i get some more miles out of my factory tires. Killing me knowing they sit in the garage.
    The great misconception of preloading on 5100's is too funny. The loaded height of the factory coil remains the same no matter the clip setting. The only change is how much further the bottom of the shock extends creating the lift. How would the exact same loaded height become firmer or stiffer? I get a good chuckle every time I read it.
    mosccat, xJuice, 02Duck and 1 other person like this.
  19. Feb 16, 2020 at 9:27 AM
    #79
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Thanks so much for your help bro
    VaToy[QUOTED] likes this.
  20. Feb 16, 2020 at 9:32 AM
    #80
    drjkll
    NC
    EXACTLY ... The spring/coil raises the the truck and the shock is either longer or simply extends. The truck doesn't "push back harder to compress the coil" That'd be like saying you weigh more on the second floor.
