Bilstein 5100 Settings for dummies
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AZ_Taco48, Nov 13, 2019.
  1. Oct 10, 2020 at 2:50 PM
    #161
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Yeah my alignment has been a little wondering and still have slight negative camber bugging the shit out of me. So I bought the spc pricey but with it. I’ll be able to dial it in. I watched some videos on installs. Very cool. I was sold. I’ll post a pic no problem
    CBrob likes this.
  2. Oct 10, 2020 at 2:51 PM
    #162
    71tattooguy
    Dino
    Petaluma , Ca (707)
  3. Oct 10, 2020 at 4:23 PM
    #163
    D-Money
    D-Money Active Member
    Alberta, Canada
    2017 TRD Off Road ACLB AT
    BACKFLIP hard folding bed cover (modified from 1st gen to fit) TRD PRO style black front grille OVTUNE 2.0 Method 305 NV bronze wheels
    Why are you going with such heavy duty aftermarket spings on a light access cab?! Getting full steel armor all around?
    CBrob likes this.
  4. Oct 10, 2020 at 4:39 PM
    #164
    Hank_Mille
    Hank_Mille Well-Known Member
    PNW
    2016 Tacoma Limited
    I just put 5100's on all 4 corners of my Gen 3 2016 V6 Limited and kept everything at stock height - mainly because I didn't want to have to buy another trailer hitch receiver. The stock height was perfect and with the new shocks, it's still perfect.
    Only difference I have noticed is that they are just a bit stiffer than stock - probably because they are new and the originals had over 80,000 miles on them... Also, rebound is MUCH better.
    Well worth doing!
    :thumbsup:
    #4TOY4ME, 71tattooguy and Grossomotto like this.
  5. Oct 10, 2020 at 5:08 PM
    #165
    Pibbles99
    Pibbles99 One more cast
    Brian
    Southern NH
    21 OR dbl cab
    I figured I would change out the coils after 103 K . Would the 885 be less stiff? Or would I be better off just getting OME? Replacements
  6. Oct 10, 2020 at 5:15 PM
    #166
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    Im wondering the same thing sorta. Looking to do 1-2” lift with springs rather than just spacers.
  7. Oct 10, 2020 at 11:53 PM
    #167
    D-Money
    Alberta, Canada
    Guys, the Bilstein 5100's are valved and tuned for the *stock OEM shocks. They do not recommend running aftermarket *shocks. Its only the sales people you're buying from or your local truck shop that wants to sell you OME *shocks with your 5100 Bilstein shocks. I would highly recommend that you do not put 886 springs on your access cab! That is crazy!
    I recently put 5100's on my access cab with stock off road springs and the ride quality is improved. If you must run OME springs, do your research. The different springs are meant for additional weight above stock weight like steel bumpers and overlanding gear.
    EDIT: *stock OEM springs. ...*springs... *springs
    71tattooguy likes this.
  8. Oct 10, 2020 at 11:58 PM
    #168
    D-Money
    Alberta, Canada
    Also, did you guys see this from earlier in this thread?
  9. Oct 10, 2020 at 11:58 PM
    #169
    Shades_Of_Red
    Shades_Of_Red Well-Known Member
    Lou
    Pittsburgh, PA
    2019 Tacoma TRD Off Road Premium Cavalry Blue
    A few.
    The OME 886 Coils are not recommended to be run on bilstein 5100s period. That staight from Headstrong Offroad.
    71tattooguy and D-Money like this.
  10. Oct 11, 2020 at 12:05 AM
    #170
    D-Money
    Alberta, Canada
    Yup, I hope that nobody would ever do that. IMO that sounds like the stiffest ride known to man!
  11. Oct 11, 2020 at 3:30 AM
    #171
    Pibbles99
    Brian
    Southern NH
    21 OR dbl cab
    Exactly. Just wanna do a level off , but I would wouldn’t mind going heavier with extra leafs as such so when I put dirt or firewood I would feel more confident
  12. Oct 11, 2020 at 3:30 AM
    #172
    Pibbles99
    Brian
    Southern NH
    21 OR dbl cab
    Gotcha thanks VM for that
    mrjordan415 likes this.
  13. Oct 30, 2020 at 11:16 PM
    #173
    pte0616
    pte0616 Member
    Patrick
    San Diego,CA
    2020 Voodoo blue Toyota Tacoma SR5 DC SB 4x2
    Bilstein 5100 adjustable shocks @1.1 inch setting ARB OME 2 inch lift springs Camburg performance uniball Upper control arms 88rotors add a leaf package (brings to level) 17 inch Method 704 Matte black (0 offset) BfGoodrich AT KO2 285/70/17 TRD PRO GRILL Work done by 88rotors off-road in Los Angeles,CA
    Bilstein 5100 a 1.1 inch setting
    88rotors add a leaf package (brings it to level)
    Camburg performed uniball control arms
    BFG AT KO2 285/70/17
    Method 704 0 offset
    @88rotorsoffroad
    Los Angeles, CA
  14. Nov 2, 2020 at 5:15 PM
    #174
    zacncheese
    zacncheese New Member
    Zach
    2020 Toyota Tacoma OR
    Bilstein 5100 (4th notch) 265/75R16 Toyo Open Country AT3 Method Race Wheels 704
    Bilstein 5100 at 4th notch
    265/75R16 Toyo AT3
    Method 704
  15. Nov 3, 2020 at 8:39 PM
    #175
    YotaJoe
    YotaJoe ig @_yotajoe
    Darren
    Vegas
    2017 Tacoma TRDsport 4x4
    insta@_yotajoe : 5100s / spc uca, 34' cooper mts, allpro sliders/skids. sherpa roof rack. agency6 goodies, BAMF hybrid front bumper, BD lights/Hella spots.
    Just bought this set with eibach coils. I have a 3inch lift with spaces right now and want that same height. Anyone know what setting notch I should install them at?
  16. Nov 3, 2020 at 8:42 PM
    #176
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Imo just put a 1/2” top plate spacer and don’t preload the eibach coil. Eibach coil will give 2” and 1/2” spacer will give 1” of lift. How’s your alignment? You have upper control arms?
  17. Nov 4, 2020 at 6:25 AM
    #177
    YotaJoe
    Darren
    Vegas
    Man this preload topic seems 50/50 in this tread. One posted direct info from fox website backing this higher setting means more preload on spring. Others seem sure about the strut setting moving down/creating lift so spring stays the same. I’d be willing to bet bilstein claims the latter theory. Idk who to believe. I want to get 1” using clip settings since I’m going away from spacers I don’t want them. Stock UCAs and 285 tires have been fine with the 3”blocks. Probably will get spc or jba soon tho as it’s recommended.
  18. Nov 4, 2020 at 7:18 AM
    #178
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Happiness is in the eye of the beholder. Love my SPC’s
    CBrob likes this.
  19. Nov 4, 2020 at 8:02 AM
    #179
    CBrob
    CBrob Well-Known Member
    Rob
    stock 2003 and stock SR 2020
    not a single mod
    Look into the eibachs springs.
    Seem to be a sweet middle ground on spring rate and ride
  20. Nov 4, 2020 at 4:17 PM
    #180
    Pibbles99
    Brian
    Southern NH
    21 OR dbl cab
    Will do , thanks
