Bilstein 5100 Shock's with 1.5" lift... VIBRATION
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RePHASE, Sep 1, 2010.
  1. Sep 1, 2010 at 3:38 PM
    RePHASE
    RePHASE [OP] New Member
    Idaho
    TRD Off-Road
    Bilstein 5100 shocks, 265/75/16 Yokahoma Geolander's
    So, I just had the bilstein 5100 shocks installed on my 06 tacoma. The shocks were set to have a 1.5" lift for the front to level it out. Immediately after install there was a vibration (like a tire rub or cyclical vibration of ridges rubbing somewhere) so I took and double checked the work and nothing was rubbing. Then I started systematically trying to determine where the issue was. As soon as I engage the 4WD the vibration stops, but when disengaged it does it again. I suspected that it might be the alignment, however just had it aligned a few hrs ago and no dice. Curious if any one knows or has any idea what might be the issue.
    Thanks...
  2. Sep 3, 2010 at 11:41 AM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    1.5 inches of lift? what?
  3. Sep 3, 2010 at 12:17 PM
    jackwithcorona
    jackwithcorona Well-Known Member
    Eastern Mass
    13 DCSB SR5 4x4
    bestop supertop, rubber bed mat, weathertech floor mats
    what size tire are you running?
    check the cv boot per chance
  4. Sep 3, 2010 at 9:03 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    He means 1.75" I'm betting.
    Are you sure everything is torqued down correctly?
