Bilstein 5100 Shocks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 08TRD Sport, Jan 31, 2010.
  1. Jan 31, 2010 at 6:27 PM
    08TRD Sport
    08TRD Sport [OP] ROOTIN AROUND
    Joshua
    Augusta, Georgia
    10 5th Gen 4Runner
    If I go Bilstein 5100 Shocks in the front and rear am I going to need anything else., I am already running 265.75/16 on stock height now. Or shoudl I just go with a full 3 inch pro comp suspension lift? The onyl thing is that I heard If I got 3 inchs or hghter I am goning to need a UCA (I think) Can someone please help me on this. I am not going to change the rims and tires out since I just got them. I was just going to get the Bilstein 5100 Shocks right now and bump it up to 1.75 just to give it a little bump up
  2. Jan 31, 2010 at 6:30 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    all you need is the 5100's.
  3. Jan 31, 2010 at 6:37 PM
    08TRD Sport
    Joshua
    Augusta, Georgia
    10 5th Gen 4Runner
    but then will that leve it out with the rear or do I still need a AAL
  4. Jan 31, 2010 at 6:37 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    did you have the rear tsb done?
  5. Jan 31, 2010 at 6:43 PM
    08TRD Sport
    Joshua
    Augusta, Georgia
    10 5th Gen 4Runner
    That exactly what I am looking at now
  6. Jan 31, 2010 at 6:55 PM
    flyingface
    flyingface Well-Known Member
    Zach
    Auburn, AL
    2013 MGM DCLB TRD Sport 4x4
    Soon....
    IMHO, if you do the 1.5" AAL I'd set them at 1.75 (3rd notch). I had them at 2.5 with that and it was level, but if I had to do it again I would do 1.75 to have the factory rake and it wont look goofy when the rear end is squatted down when towing or hauling heavy stuff.
  7. Oct 1, 2010 at 5:49 PM
    ElfDad
    ElfDad Member
    Drew
    Central VA
    2010 DC 4x4 TRD MGM
    Factory Roof Rack, Factory Side Steps, Factory Bed Extender, Removed Cigarette Lighter and Installed 2nd Power Port
    Sorry to be such a noobie but I too am looking at this currently and I don't understand about the rear TSB? Help a noob out with a lil info please!
  8. Oct 1, 2010 at 6:25 PM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Try searching the stickys :rolleyes:
  9. Oct 1, 2010 at 9:23 PM
    ElfDad
    ElfDad Member
    Drew
    Central VA
    2010 DC 4x4 TRD MGM
    thankx
