Bilstein 5100 + spacer = bad idea?
Discussion in 'Suspension' started by texastacobueno, Feb 25, 2010.
  1. Feb 25, 2010 at 9:15 PM
    texastacobueno
    texastacobueno [OP] Effin A Cotton, Effin A
    Andy
    College Station, Texas
    08 4x4 Sport
    Pop N Lock - Westin sportsman guard - Hella 500 fogs - extra D-rings - Mag Lite mounts
    hey I was cruising through here and got to thinkin, would it be a major no-no is if had billy 5100's set at .85" and decided to throw on 1/4" plate spacers on top of each perch?
  2. Feb 25, 2010 at 9:19 PM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
  3. Feb 25, 2010 at 9:20 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    As a general rule, stacking lifts = a big no no.
  4. Feb 25, 2010 at 9:20 PM
    TacoTron
    TacoTron Tacotronn
    Anthony
    Denver, CO
    07 Toyota Tacoma
    x2 :popcorn::
  5. Feb 25, 2010 at 9:31 PM
    texastacobueno
    Andy
    08 4x4 Sport
  6. Feb 25, 2010 at 9:36 PM
    senor taco
    Monterey Bay, Ca
    My tires are rubbing like a mofo I've been thinking of doing this ,or installing lift springs.
    I'm running 285's set at 2.5.
  7. Feb 25, 2010 at 9:36 PM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    There is no problem with it. Many lifts are sold that way. Old Man Emu which is highly respected combines the coil and a top plate spacer to get lift. It even has a trim packer preload spacer to combat the "Taco Lean". That's 3 types of lift on one side.
    The important rule is that you don't pass 3". Look at my hodge podge lift. I have small top plate spacers (1/2" on driver's side and 1/4" on passenger's side), 1.6" Eibach lifting coils, and 5100's set at 0.85". If you add it up, the claimed lift is over 3" but it actually is only 2 3/4".
  8. Feb 25, 2010 at 9:40 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    I added 10mm (5/8") spacer plates on top of the upper strut plate of my OME 886s. Had to put in extended length bolts to accommodate them. Also added a 5mm (3/8") spacer under the coil seat on the drivers side strut to help level out the "Taco lean".
    Anyway, I've had no, zero, issues with mine and have put it through some pretty solid off-road use.
    From this post it seems I'm riding the lightning, wooohooo! So I'll be sure to post up some pics when/if my whole front end sheers off :)
  9. Feb 25, 2010 at 9:45 PM
    senor taco
    Monterey Bay, Ca
    That's what I was thinking. So 5100's @ 2.5 w/ 1/4 top plate should put me at 3" right?
  10. Feb 25, 2010 at 9:48 PM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    You could do it but since you'd have so much preload with the 5100's @ 2.5", adding a spacer would only make a harsh ride harsher.
  11. Feb 25, 2010 at 9:53 PM
    senor taco
    Monterey Bay, Ca
    I'm running the sr5 springs right now and honestly, it a realy soft ride IMO. That's why I was thinking the 1/4 spcr wouldn't make a big diferance.
  12. Feb 25, 2010 at 9:55 PM
    ToucanV13
    ToucanV13 You think I was rollin out here naked?
    San Diego and Colorado
    Infideled out TRD Sport 4X4
    285/70 Hankook AT-M, Window vents, TRD CAI, TRD Cat-back exhaust with WickedFlow can, AFE Throttle Body Spacer, Billy 5100 @ 2.5 and 1" block rear, RBP nerf bars, Halo HIDs, 20% tint up front
    Spidertrax
  13. Feb 25, 2010 at 9:59 PM
    senor taco
    Monterey Bay, Ca
    Already installed.
  14. Feb 25, 2010 at 10:02 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2021 Jeep Rubicon
    On the same note, King coilovers set at "0" and a 1" spacer wouldnt be too bad right? I tried to email down south motor sports and explained to them that I wanted zero preload on the coilovers and they said if I used a spacer Id have to preload the springs anyways which made no sense to me.
  15. Feb 25, 2010 at 10:05 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    they are either preoaded on the way up or down^ i think spacer repload them down and new springs preload them up if that makes and sense at all.... :( sorry haha
  16. Feb 25, 2010 at 10:07 PM
    ToucanV13
    UCAs?
  17. Feb 25, 2010 at 10:13 PM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    I think there are quite a few people that run that 1/4" top plate spacer with their lifts.
  18. Feb 25, 2010 at 10:13 PM
    senor taco
    Monterey Bay, Ca
    It's rubbing on the inner wheel well. I probably just need to do a better job trimming. I've been too busy with work to get at it, by the time I get home it's already dark.
  19. Feb 25, 2010 at 10:16 PM
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    You probably need the cab mount chop done.
  20. Feb 25, 2010 at 10:21 PM
    senor taco
    Monterey Bay, Ca
    :eek:
