Bilstein 5100 stem sitting high after 887 coil install
Discussion in 'Suspension' started by cementnotgray, May 19, 2020.
  1. May 19, 2020 at 9:19 AM
    cementnotgray
    cementnotgray [OP] Well-Known Member
    Denver, Colorado
    2019 TRD OR M/T
    35s, 5.29s, OVT
    I have a 2019 TRD Off-Road and I installed OME 887 coils with 5100's (set to stock notch) and the stem is sitting so high that when I screw down the top nut, it hits the bottom of the stem threads and doesn't compress the shock mount insulator or even the washer. I've had the 5100's installed with stock springs and didn't have a problem.
    Also, as you can see from the pics, the upper seat is warped after installing the 1/4in lean spacer, I'm wondering if any one else has seen that before or I messed up the install?IMG_3631.jpg IMG_3632.jpg
  2. May 19, 2020 at 11:49 AM
    LC7
    LC7 Well-Known Member
    Far Nor Cal
    2011 MGM DCLB 4x4 4.0L
    5100's w/885's, SPC LR UCA, Deaver U402 stage 1 w/Fox 2.0 RR, 285/75r17 Toyo AT III load C on SCS F5, Dynabeads
    Looks like maybe you forgot the metal washer and rubber bushing beneath the top hat? That washer keeps the shaft from going up too high.
  3. May 19, 2020 at 1:17 PM
    cementnotgray
    Denver, Colorado
    2019 TRD OR M/T
    35s, 5.29s, OVT
    Yeah that’s what I thought but I have it apart now and it all looks like it’s there
  4. May 19, 2020 at 1:40 PM
    cementnotgray
    Denver, Colorado
    2019 TRD OR M/T
    35s, 5.29s, OVT
  5. May 20, 2020 at 9:46 AM
    kevin_ryle423
    kevin_ryle423 Well-Known Member
    Did you find what was the problem?
  6. May 20, 2020 at 10:31 AM
    cementnotgray
    Denver, Colorado
    2019 TRD OR M/T
    35s, 5.29s, OVT
    No not the stem issue. I fixed the upper seat issue which was that the spring was compressing half of the inner lip of the rubber. As for the stem issue, the top hat and the lower cushion are all there so it doesn't make sense it would sit high. As you can see from I just smacked on a few extra washers on top from my old rear shocks. Whether or not it's a good idea, it works.
  7. May 21, 2020 at 5:58 PM
    matt2491
    matt2491 Well-Known Member
    Massachusetts
    2015 TRD Off-Road Supercharged
    I think you're missing the dust boot collar. If you decide to not run the dust boot covers (which is what it looks like in your pics), you still have to use the little collars they mount on to space the bushing washer up the correct amount.
  8. May 21, 2020 at 7:51 PM
    cementnotgray
    Denver, Colorado
    2019 TRD OR M/T
    35s, 5.29s, OVT
    Good catch man. It's unfortunate timing, I just got it re-aligned today. I might try to get away with marking the camber bolt location to avoid another re-align.
