Bilstein 5100 to soften Sport?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by chechare, Sep 20, 2019.
  1. Sep 20, 2019 at 7:34 AM
    chechare
    chechare [OP] Active Member
    cesar
    i just bought a sport DCSB 4x4 and want to soften the ride. The sport does not take bumps and potholes really well. OffRoad was not an option, all we get in Mexico are Sport. I was thinking of installing just the 5100s on 0 setting and later on, if I need lift or put on some weight, think about springs and leafs. Would that work?
  2. Sep 20, 2019 at 7:44 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    In my experience, the springs and shocks are good. It's the sway bar that sucks, esp for uneven bumps. Try pulling it off and take it for a drive? You have to pull it completely off as the end will hit and tear the CVs if you just disconnect one end link.
    G8R_Taco likes this.
  3. Sep 20, 2019 at 7:47 AM
    pditty
    pditty Active Member
    Pat
    2016 TRD Sport
    Hi, I have a sport and also didn't like how it took bumps and potholes. I installed 5100 in the 0 setting a little over a year ago and it has improved my overall ride. No regrets installing 5100s
    Thuguon2.7, TXTaco211 and tonered like this.
  4. Sep 20, 2019 at 7:59 AM
    Comb
    Comb Known Member
    2017 TRD Sport 4x4 DCSB 6MT BBP ABCDEFG
    OVTune Verified Purchase
    Speaking of the sway bar, do you know of anyone who has tried swapping the sport sway bar for the thinner offroad sway bar? I'm considering trying it if I can find a local offroad sway bar for cheap. Wondering how much difference it will make.
    tonered[QUOTED] likes this.
  5. Sep 20, 2019 at 8:01 AM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    Buy some TRD OR takeoffs. They’re softer and you can probably get them for cheaper than new 5100’s. My 5100’s ride comparable to a sport, they aren’t soft.
  6. Sep 20, 2019 at 8:05 AM
    TXTaco211
    TXTaco211 Well-Known Member
    Corpus Christi, Tx
    13 Pyrite Mica TRD Sport DCSB
    Kicker Speakers, 5100's with HS coils and HS AAL, Caliraised 30" LED light bar
    The 5100's was a night and day difference on mine. I don't get the hard jarring that I used to get with the factory shocks installed.
  7. Sep 20, 2019 at 8:07 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    No. I have not heard of anyone that tried it. Good idea though.
    I did get to drive an MT OR that had a stock suspension and honestly feel that it with the sway bar is pretty close to a Sport without one. Maybe a bit more brake dive, but that wasn't as bad to me as folks seem to say?
    A check ride without the sway bar is a $0.00 effort, but it convinced me for both on and off road ride and handling. Mallcrawling even! :D
    It is funny that on my last car (FWD turbo MT), I replaced a coat hanger rear sway bar with a 7/8in mutha. It made the handling neutral tending toward oversteer. Just perfect in that application other than when some exceptionally shitty Dunlops went to shit in the rain. That thing probably changed the weight distribution a bit also. Hahaha!
  8. Sep 20, 2019 at 8:07 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    5100s are yikes. way stiffer than my oem shocks.
  9. Sep 20, 2019 at 8:09 AM
    dbbowen2
    dbbowen2 Former Rock Crawler.
    TN
    2017 TRD OR Taco/2001 Land Cruiser/ 1976 FJ40
    too many to list
    Just get OEM TRD OR takeoffs for cheap. I have a TRD OR and hate how soft it is. That being said, I like stiffer suspension.
    tonered and TimC like this.
  10. Sep 20, 2019 at 8:16 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That is the funny thing. Sports have 700lb springs (oops!) that folks will install for lifts. :cheers:
  11. Sep 20, 2019 at 8:34 AM
    dbbowen2
    TN
    too many to list
    Hah thats crazy. I honestly think its the yellow bilstein shocks that make them so soft
  12. Sep 20, 2019 at 8:37 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Sorry! I fixed my post. That should have been springs.
    The ORs are supposed to be 650lb springs, I believe? I also don't know if the stock springs on either are linear or progressive.
  13. Sep 20, 2019 at 8:40 AM
    dbbowen2
    TN
    too many to list
    Ah I have no idea. I put 265/75/16s on my offroad and the shocks can barely handle them and they are not even a full inch taller than stock. Its squirrely. I cant imagine how it rides for folks who do the spacer route
  14. Sep 20, 2019 at 8:45 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That is interesting since I am considering 265/70R17s to replace the stock Toyos. Probably similar to 16s, there are more choices in that size.
    There is a lot of talk about the steering rack, but I was wondering about wheel bearings when running spacers and negative offsets. LT seems to be the proper route, but that is big $$$.
  15. Sep 20, 2019 at 10:35 AM
    chechare
    cesar
    :boom:you just opened up a whole different can of worms. So, the OF sway bar IS softer than Sport? if so, it might be a good compromise to removing it altogether.
    and back to the 5100, i will be doing some off roading to go camping. nothing extreme, no RTT or anyting heavy. im guessing 5100 are better than TRD OR shocks, without having to blow up my budget on fancy shocks.
  16. Sep 20, 2019 at 10:38 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yes. The Sport SB is much stiffer.
  17. Sep 20, 2019 at 11:25 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    5100s are still digressive though right.
  18. Sep 20, 2019 at 11:50 AM
    dbbowen2
    TN
    too many to list
    I could see the steering rack being a cause to the weirness in driving. My wife drives a 100 series land cruiser and its about twice the size as the one on the tacoma
  19. Sep 20, 2019 at 12:12 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I try to hold my tongue there because I am stoked to not have electric PS on the Taco. LCs are just designed and built differently though. I have a soft spot for the old ones.
    dbbowen2[QUOTED] likes this.
  20. Sep 20, 2019 at 12:18 PM
    dangeroso
    dangeroso Just float along and fill your lungs
    Jon
    Dallas, TX
    2018 Tacoma TRD Sport 4x4
    I would be hesitant to remove the sway bar altogether. You can install disconnects or go with a more flexible bar, but you don’t want to find yourself having to make an emergency maneuver at highway speeds with no sway bar.
